steamdave | 17/05/2020 16:31:59 |
526 forum posts 45 photos | I've occasionally chalked files, particularly when working with aluminium. The stated wisdom is that it is supposed to reduce clogging of the file teeth. Coarse files don't clog as easily compared to the finer files, particularly on ali. castings. I haven't found it particularly effective to prevent clogging, but it does seem to ease cleaning the file (with a piece of flattened copper pipe) afterwards. Does anyone have any experience with chalked files and whether they can keep the file clean while using it? This question has come up because I'm working on aluminium castings at the moment. Dave |
old mart | 17/05/2020 16:36:07 |
4655 forum posts 304 photos | I was taught to chalk files used for aluminium at school, and it works quite well. If I file aluminium nowadays, I just wet them first with WD40 or AC90. We often had to fettle parts at work with 140MM Vallorbe No2 files, and if they got aluminium stuck in the teeth, popped them in a jar of caustic soda (NAOH) solution overnight. Edited By old mart on 17/05/2020 16:40:30 |
Ian Skeldon 2 | 17/05/2020 16:45:59 |
543 forum posts 54 photos | If my memory serves me correctly (and it may well not do) I was taught that only course files should be used on soft material and then to use a strip of emery cloth supported by the file, getting less course as nearing the correct size. I do remember using chalk but I am almost sure that was when draw filling, but I might be talking out of the wrong end, it was a long time ago. |
Martin Kyte | 17/05/2020 16:52:25 |
![]() 3445 forum posts 62 photos | School chalk or French? regards Martin |
old mart | 17/05/2020 16:55:10 |
4655 forum posts 304 photos | School chalk. |
Brian H | 17/05/2020 17:45:47 |
![]() 2312 forum posts 112 photos | I was taught to use chalk on files used on aluminium when I was an apprentice and we had some large cast aluminium valve covers to prepare to make the engines look nice! I don't use aluminium much for model making but if I do, I always chalk the files using the sticks of chalk that are sold for marking steels etc for cutting or welding. Brian |
mechman48 | 17/05/2020 19:11:36 |
![]() 2947 forum posts 468 photos | I've used both school chalk & French chalk, both seem to work well. George. |
Jon | 17/05/2020 19:12:30 |
1001 forum posts 49 photos | Its the individual job case whether to use or not. Most of the times the job will respond better to no chalking just merely using the file differently or choosing another file or even a rasp. Keep oils off files, biggest mistake you can make wont cut or not very well until burnt off.
