cross slide dept stop
larry phelan 116/05/2020 18:36:00
1346 forum posts
15 photos
Good evening all,,
I,m wondering if anyone can enlighten me as to where I am going wrong.
I have made a simple stop to limit the travel of the cross slide on my lathe in order to get consistent diameters each time.
It consists of a screw, fixed to the cross slide which meets a stop fixed to the back of the carriage, nothing fancy. In order to make it more useful, I fitted it with a rotating disc in order to fit three such stops.
It works fine, as a stop, but the results are far from consistent, anything from 2thou to 6 thou on all three diam,s.
I have tried locking the cross slide but it made little difference.
Any idea,s ? I have taken pictures which I will try to post
All help welcome.
AdrianR16/05/2020 18:47:04
613 forum posts
39 photos
Is that variation when you are cutting or with a DTI?
If you put a DTI on the tool post and set it against your work, does it show the same variation each time you hit the stop?
Could it be you are varying the force you are using against the stop?
The stop could be flexing.
The slide could be twisting.
Adrian
Andrew Johnston16/05/2020 18:47:52
7061 forum posts
719 photos
The obvious assumption is that the stop is not rigid enough, but pictures will help. For comparison I'd expect to hit a diameter to a thou or less just using the same dial reading on my cross slide.
larry phelan 116/05/2020 19:05:16
1346 forum posts
15 photos
First off, I did not try a DTI ,the variation is when I,m cutting, even with a very fine feed. I tried to be gentle when bringing the unit to the stop, which is made from a piece of 40x10 which happened to be to hand. Not much chance of it flexing. I will try the DTI in the toolpost
Andrew, I was hoping to avoid having to check the dial each time since I hope to use this thing when making a batch of small units. I did take pictures, but I,m still trying to work out how to get them from A to B, if you know what I mean
For now, it,s back to the drawing board.
larry phelan 116/05/2020 19:34:56
1346 forum posts
15 photos
Back again, I did manage to get those pictures into my album [don't even ask how ].
I hope you may be able to make it out, it is simply a piece of 10mm bar which carries a disc fitted with three screws which can be brought to bear against a piece of 10mm flat.. As I said, even with the cross slide locked, when two pieces are machined at the same setting, there is a variation and a lot more than 1 thou.
Tony Pratt 116/05/2020 20:10:11
2319 forum posts
13 photos
Something is flexing possible the angle bracket, it's suprising how much force you can apply with a screw.
Tony
bricky16/05/2020 20:16:48
627 forum posts
72 photos
Larry, I think the bracket may be flexing and that a block would give a more consistant result.
Frank
old mart16/05/2020 20:39:54
4655 forum posts
304 photos
I have never heard of a cross slide stop being used on a lathe. It would have to be extremely rigid to have much of a chance. I recon that the reason a stop is not used in that application normally is because it is so easy to zero the dial when taking the last cut on the first workpiece.
old mart16/05/2020 20:39:55
4655 forum posts
304 photos
Andrew Johnston16/05/2020 20:42:00
7061 forum posts
719 photos
I'd agree that the angle bracket is flexing; you only need it to deflect half of the diameter error. As to the error with the cross slide locked, that'll probably be down to something else. May tool or work deflection? Or the lock isn't that effective for the loads being applied?
Clive Brown 116/05/2020 21:39:33
1050 forum posts
56 photos
GHT published a cross-slide stop for the Myford. Here's my take on his design for a Boxford. It is really intended for screw-cutting when the cut is put on with the top-slide. It can be useful, saving mistakes, and repeats position quite well. As I recall, the tapped BSW hole was already in the cross-slide from new.
Chris V16/05/2020 21:57:40
313 forum posts
42 photos
Hi Clive, what book is the GHT design in please?
Chris.
Bazyle16/05/2020 21:58:37
6956 forum posts
229 photos
Several of the bigger industrial lathes have cross slide stops as standard, sometimes a T-slot along the edge of the slide.
There was a nice design for the Myford in ME about 30 years ago that incorporated a click detent on the adjusting knob so you could get close then make final increments on cut by feel more than peering at the dial. I have always remembered that feature and wanted to do something for a Boxford but the slide moves in a different way.
I wonder if Larry's problem is partly that the screw that allows the holder to turn to select 3 options implies some looseness that allows the whole ring to tilt.
Pete Rimmer16/05/2020 23:44:35
1486 forum posts
105 photos
Larry if you want to test if the stop or bracket is flexing simply put a dial gauge on the opposite side and run the cross slide up to it. The gauge will show any movement, which will be doubled on diameter as pointed out by Andrew Johnston
Hopper16/05/2020 23:48:10
7881 forum posts
397 photos
Hard to tell from the pics with nothing to give scale but the whole thing looks a bit small and flexible. Needs to be something of similar heft as the cross slide itself, more like the one in the pic Clive posted above. Your 3 bolts that form the actual stops would need to be at least 5/16" diameter I should think. I would make it 3/8 for good measure. And the body a good half inch thick or more. Basically, needs to be immovable as your cross slide screw exerts more force than you might realise.
Nigel Graham 217/05/2020 00:55:07
3293 forum posts
112 photos
Chris V -
With respect the photo is almost the design. You'd have to measure the lathe to ascertain dimensions. The Allen screw goes through a clearance-hole in the clamp-block, to a tapped hole that happened already to be in the cross-slide. (I wonder what that hole was intended for?). The stop action is thus by the underside of the cap-screw contacting the block.
Note the flexing-point for the clamp is the small hole near the top right edge; the cap-screw that actuates the clamp should be sufficiently far down for proper clamping action without an unduly weak wall between the thread and the block's underside. The clearance hole is just a tad generous, but not overly so if the Vees meet as they should.
Larry -
I would agree that stop as made is a bit too slender. The principle is very good and I am only surprised such stops are not more common. It does though, need to be very rigid and positive.
The bracket could be made far more rigid by welding or brazing a triangular gusset across both ends to make a Vee-box form, rather as many angle-plates are cast.
Or replaced by similar machined from a cube.
It's a bit hard to see details but the central shaft and whatever it fits in, look a little thin.
I have the essence of a 6-station saddle (rather than cross-slide) stop from an old industrial lathe, and the rotary part is a cylindrical sleeve a close sliding fit on a rigid stator. As far as I can tell, its central Allen screw pulled the back of the stator onto a spot-facing on the apron.
The trick is that the stop-screw carrier has as much bearing surface as possible for the rotary part of a unit probably little larger than yours, and it revolves on a part held in the most rigid way it can be. The stop-screws thus thread down inside the wall of the sleeve.
What you might consider is modifying / making new the bracket to be much more rigid. Then, if that does not entirely solve the problem, make the stop-carrier as above: a closely-fitting sleeve pulled back by a hefty screw to a facing on the bracket..
My industrial version had the extra luxury of a detent arrangement and operating-handle, as on a rotary tool-post, but that's for another day!
The length-stops themselves on my example - which I have not used - are square-head screws, 5/16-in BSF I think, with lock-nuts, that met a domed fine-adjustment screw in the end of a bar dimpled for coarse adjustment within its mounting-block. My Myford 7 certainly does not, and the Harrison L5 appears not, to provide for mounting this device.
Clive Brown 117/05/2020 09:06:19
1050 forum posts
56 photos
Posted by Chris V on 16/05/2020 21:57:40:
Chris.
Hi Chris, just a quick reply, Nigel Graham 2 has explained the device very clearly. The design was in ME back in the 'eighties.Don't know if it ever made it's way into a book. GHT later designed a retracting tool-holder which might be seen as a Rolls-Royce method of doing a similar job. I didn't make one of those.
Chris V17/05/2020 09:42:11
313 forum posts
42 photos
Thank you Nigel Graham 2 & Clive, yes that's clearer now in my mind!
Chris.
ega17/05/2020 10:10:56
2805 forum posts
219 photos
There have been various designs for lath cross slide stops eg Sparey's arrangement which occupies the space often taken by a DRO and Tubal Cain's rather different device to aid screwcutting. Incidentally, to be useful a cut-off slide will normally incorporate stops. Here is my shop-made version of the Boxford stop as fitted to my Willson slant bed:
And my own design for the Myford:
Both were intended as aids to screwcutting and have been effective; so far, however, neither has proved totally repeatable in use.
larry phelan 117/05/2020 10:28:41
1346 forum posts
15 photos
I don't know where to start when it comes to thanking you all for your input !
I am simply amazed that so many took the trouble over something so small.
Thinking the whole thing over last night,I came to the same conclusion ,that the whole thing was too light and flimsy.
I think that the angle piece is far too light, a solid block would be a better idea there and the screws need beefing up.
How was I stupid enough to believe it would work ? [Don't dare answer that !! ]
It is now a case of "Back to the drawing board ", but much wiser this time around.
I will build another one because it can be useful when making large numbers of items and if it works out better this time around, I will post some pictures of the Mark Two model.
Again, my thanks to everyone who replied. As they say, "Every little helps "
Take care everyoneblush
