Greensands | 14/05/2020 13:11:54 |
449 forum posts 72 photos | Can anyone on the forum suggest a possible source (and common name) for the waxy type of plastic sheet/block material used for test proofing of CNC software. I have a small piece left over from a previous job which is blue in colour and when cut gives a very clean and precise finish. Ideal for proof machining purposes. |
Adam Mara | 14/05/2020 13:22:28 |
198 forum posts 1 photos | Try Easy Composites Ltd, they list foam block for hand/machine carving. |
geoff adams | 14/05/2020 13:23:06 |
214 forum posts 207 photos | hi dont no what the material is but i use celotex which is wall insulation most builders skips have some off cuts in and its free if you are careful it can be measured i find this works to prove your G code hope this helps Geoff |
Former Member | 14/05/2020 13:36:16 |
[This posting has been removed] | |
Baz | 14/05/2020 13:38:13 |
1033 forum posts 2 photos | Try googling trycut wax. |
JasonB | 14/05/2020 13:41:57 |
![]() 25215 forum posts 3105 photos 1 articles | The waxy one is Trycut and you can also get Testfoam which is a low density form of the PU tooling board. College engineering do small amounts of both |
Roderick Jenkins | 14/05/2020 14:11:47 |
![]() 2376 forum posts 800 photos | Blimey, cheaper to use a lump of Ali. I wonder why it's so expensive. I think I'll stick to MDF offcuts. Stay well, Rod |
Mike Poole | 14/05/2020 14:25:25 |
![]() 3676 forum posts 82 photos | I think our training school just used polystyrene and wood but I suppose it depends what you are proving. Mike |
Former Member | 14/05/2020 14:41:13 |
Robert Atkinson 2 | 14/05/2020 15:07:50 |
![]() 1891 forum posts 37 photos | Driving a tool into a block of foam or wax is much less likely to wreck the machine than doing the same into a block of alloy. It's not the cost of making the material, it's what the market (big CNC companies) think it is worth. Even a minor crash that just needs re-alignment can cost thousands of pounds in lost production time. A easy to use test material can be a good investment Robert G8RPI |
Bazyle | 14/05/2020 15:12:19 |
![]() 6956 forum posts 229 photos | Look up 'machinable wax' made by dissolving plastic bags (LDPE) in hot candle wax. Not tried it myself. I imagine wax or plastic is a lot cheaper than aluminium when your program tries to run your last endmill across the table at the wrong height. |
Greensands | 14/05/2020 15:41:12 |
449 forum posts 72 photos | Barrie - I have sent you a pm |
JasonB | 14/05/2020 16:16:29 |
![]() 25215 forum posts 3105 photos 1 articles | If it is fairly flat the offcuts of UPVC facia board work well, thats what i did some of my first cut in. This was a black surfaced one which shows the cuts well Edited By JasonB on 14/05/2020 16:16:58 |
Ron Colvin | 14/05/2020 17:08:40 |
91 forum posts 6 photos | Machinable wax has one attribute that aluminium does not. You can collect your swarf, and cast it into new blocks to use again. |
Emgee | 14/05/2020 17:58:21 |
2610 forum posts 312 photos | Our now departed friend Lord John did an article on forming a machinable wax, he called in at my workshop once and couldn't fathom why I was still using aluminium for trial cnc runs, perhaps it was on this forum or in a ME mag, anyone know ? Ron, you can also collect al chips to reform into castings if you have the gear. Emgee
Edited By Emgee on 14/05/2020 17:59:58 |
John P | 14/05/2020 18:15:59 |
451 forum posts 268 photos | Posted by Greensands on 14/05/2020 13:11:54 Can anyone on the forum suggest a possible You could try this from Artisan Foundry Shop MOULD CASTING WAX 1KG FOR LOST WAX INVESTMENT CASTING It looks like the same wax that i use just a different colour .I collect the swarf John
Ron Colvin | 14/05/2020 18:29:17 |
91 forum posts 6 photos | Posted by Emgee on 14/05/2020 17:58:21:
Yes, if you have the right gear. With wax you can recycle it in a domestic oven, if the management is not looking. |
JasonB | 14/05/2020 18:37:05 |
![]() 25215 forum posts 3105 photos 1 articles | JS's cook book recipe can be found on Madmodder |
Greensands | 22/05/2020 17:37:40 |
449 forum posts 72 photos | Hi all - Just a thankyou to all those who took time to answered my query. Some food for thought. |
Former Member | 22/05/2020 18:15:10 |
