MC Black 2 | 05/05/2020 01:19:15 |
99 forum posts | I have realised in the last few days (when I have spent a lot of time in my shed-workshop) that I need a small Mill or Mill/Drill I have discovered that milling on my lathe with a milling slide is an uphill struggle. I have discovered that there are a number of suppliers who offer small Mills and it's almost impossible to choose between them. Can anybody pass on their experiences with particular models, please? Can anybody point out out pitfalls that I should try to avoid What have I forgotten to ask? I hope that you and your families are - and will remain - well. MC Black
Paul Lousick | 05/05/2020 02:23:14 |
2276 forum posts 801 photos | Hi MC, The size of mill will depend on what you want to machine. There needs to be enough headroom under the column for tooling and a vice, etc. Smaller mills are not as rigid as bigger ones and the column may flex under heavy loads. Do a search on this forrum, there have been many posts about selecting a mill and tooling. My first mill was a Seig SX3 which was just big enough for most of the machining that I did to make my traction engine. The parts that were too big, I took elsewhere. The SX3 had a variable speed, brushless DC motor which was quick and easy to change speeds. At slow speed, the torque was reasonable but not great. All was good until I started having problems with the motor speed control board which had to be replaced. Not cheap ! Also had to replace the power feed motor and controller for the table. I now have a RF-45 type mill. Slightly bigger and sturdier but with a standard AC motor and a gearbox. Something which I can repair myself if something should go wrong. Whatever you decide to buy, check if you can get it repaired and an idea of costs. Paul. ++++++++++++++++++++++++++++++++++++++++++++++++++ PS. To the admin staff: It seem that every week there is a query about selecting a mill or lathe and it would be a good if there was a section on the site that new members could easily find. Not everyone knows about previous posts or how to find them. Paul. Edited By Paul Lousick on 05/05/2020 02:23:46 |
Philip Burley | 05/05/2020 05:50:30 |
![]() 198 forum posts 1 photos | all I can add , is do not buy one with a round column . They are a menace when you lose the registration when you have to lift the head , I have a Sealey, makes a good drill except for the same problem , I have a small one with proper knee action , much better Phil |
not done it yet | 05/05/2020 08:27:25 |
7517 forum posts 20 photos | Hi Phil, I just looked at the pics of your mill. It looks like a very good, not over-used, or abused, machine. The lack of a quill is sometimes awkward (threading!🙂 ) but most certainly not a deal-breaker! There is now a mill section on the forum, should you wish to check it out and maybe make some input. Which do you use preferentially, if the workpiece is not too big for your small mill? Like, does the round column make you prefer the dovetailed rise and fall option? |
Bazyle | 05/05/2020 08:40:05 |
![]() 6956 forum posts 229 photos | Don't discount a round column mill if it matches your budget as lots of people have done a lot of good work with them. Over on another forum someone in the USA was just saying how he had bought one on offer for only $499. If only we had such prices over here I might buy a second one! |
Speedy Builder5 | 05/05/2020 08:59:09 |
2878 forum posts 248 photos | Here Here - this is what a typical search throws up, nothing about buying a mill:- Search Results for - millArticles View all results in Articles (17) These articles include the phrase 'mill' within the Title, Standfirst or Keywords |
Nick Clarke 3 | 05/05/2020 09:30:04 |
![]() 1607 forum posts 69 photos | I bought a micro mill SX1L from ARC because it was all I had room for. Although it is too small for some things I want to machine I have (normally that is) access to a larger mill at the club workshop, but the convenience of one here is great. I don't think my choice will be the same as yours, but the one thing you need to consider is tooling. While you can start to use a lathe with a single lathe tool and build up from there, with a milling machine you will need workholding, cutters, some way of holding the cutters and so on. It is easy to equal the cost of a machine if you start to want machine vices, a rotary table, collets, cutters, a boring head, parallels - the list, while not endless, can be very long! Add on the option of DRO which is possibly more applicable to a mill than a lathe and so on! |
MC Black 2 | 05/05/2020 10:25:18 |
99 forum posts | I think I have a similar situation to Nick Clarke 3 in that the smallest Mill - SX1LP - is as much as I have room for too. I have a Taig/Peatol lathe so am used to small machines. I have done some Milling on the lathe and now feel that the next step is a small Mill. I have read the St. Albans Club advice about Milling tooling. I inherited quite a lot of End Mills and Slot Drills. Nick - are you entirely happy with your Mill?
JasonB | 05/05/2020 10:25:28 |
![]() 25215 forum posts 3105 photos 1 articles | Depends how you search and that was even using the poor forum search rather than the one on the home page, searching "articles" of which there are very few on the forum won't give you many useful results unlike looking through the many forum posts. Dare I suggest beginners take a look at Neil's and my beginners series which will help them choose a lathe or mill and suitable tooling and then explain how to use it
A decent round column mill such as an EMCO can do very good work so don't discount one from your choices Edited By JasonB on 05/05/2020 10:28:26 |
Ron Laden | 05/05/2020 10:36:58 |
![]() 2320 forum posts 452 photos | Hi MC, I wont try and recommend a machine as that is a personal choice at the end of the day but you asked for our experience of particular models of small mills so here,s mine. I bought a Sieg SX2P second hand from a forum member (originally supplied by ARC) it was 12 months old, hardly used and in excellent condition so as new really. I have had the mill for 18 months and was a complete beginner when I bought it, I am about to move up to a larger mill but that in no way aims anything detrimental at the SX2, its just a size thing and I now want a mill with larger capacity. So what can I say about the SX2P, well its been 100% reliable and never let me down and it has done all I asked of it. Having said that I dont treat it with kid gloves but at the same time I dont push it to where its not happy. It is a 500 watt variable speed brushless motor and at times it has surprised me with what its capable of. It is not perfect it has its faults but you learn to live with those and appreciate its good points and thats the same with all small hobby mills. With most of the hobby machines you can make some improvements and add some mods which improve the performance and make them more user friendly. I changed the head balance spring to a gas strut, added a switch to give it reverse, fitted a budget spindle speed indicator and fitted a 3 axis DRO set, but you dont have to do any of that, its a quite a usable machine straight out of the box. So that is my experience of the SX2P, hopefully others will give you their thoughts on other small mills. Ron
MC Black 2 | 06/05/2020 00:54:21 |
99 forum posts | Very many thanks to everybody who has sent their comments. I was aware that there was fair choice of machines and I have heard of (in no particular order) Warco, Chester, Arc, Axminster. It would be helpful if any readers could point me at other suppliers which I missed. I have noted comments about good service provided by ARC. My recent experience differs! A serial tap that I bought from ARC disintegrated the first time that I used it; I wrote to ARC explaining that I was using Trefolex, reversing frequently to break the swarf, and they were NOT interested because the tap had NOT been used for over a year since I purchased it. I asked if they could suggest what I might have been doing wrong and have NOT received any response. In view of the compliments that I've read about ARC, I'm very disappointed. With best wishes and thanks again.
MC Black |
not done it yet | 06/05/2020 06:45:49 |
7517 forum posts 20 photos | ‘Disintegrated”? That seems unusual - they normally just break - usually at an inopportune time - and as a consumable, usually broken by the operator. Serial taps come in sets, so breaking just an isolated single tap is likely due to improper preparation, poor alignment, cheap quality or some other operator error. Some of my taps only get used for chasing, not making virgin threads because I know their limitations (from experience). Spending multiple pounds on a fourpence-halfpenny item does not seem like a profitable business and one reply likely cost far more than any profit on that item. Lastly, would you expect any other supplier to tell you how you are going wrong while using a tap bought a long time ago - likely without receipt and without the evidence of the broken parts for examination? I wouldn’t! |
MC Black 2 | 06/05/2020 09:19:20 |
99 forum posts | Thank you "Not done it yet" for taking the time to respond. When the tap (described as HSS) broke, I expected to have to start making the part again but decided it was worth grabbing the piece protruding with pliers and see if I could extract it first by wiggling. The part of the tap in the hole just disintegrated into tiny fragments. I still have the rest of it and a record of the Order on my computer. If I was a supplier, I would be interested in a product that failed in an unusual way. I have ordered a replacement set from another company. In contrast, I bought two spare blades for my previous bandsaw from a local company. When I replaced the Bandsaw (because the castings broke), I contacted that company to order a couple of spare blades and asked if they would like the unopened spares back (rather than throw them away). To my surprise and delight, they offered a straight swap and, consequently, now have a customer for life. |
SillyOldDuffer | 06/05/2020 09:38:49 |
10668 forum posts 2415 photos | Posted by MC Black 2 on 06/05/2020 00:54:21: ... I have noted comments about good service provided by ARC. My recent experience differs! A serial tap that I bought from ARC disintegrated the first time that I used it; I wrote to ARC explaining that I was using Trefolex, reversing frequently to break the swarf, and they were NOT interested because the tap had NOT been used for over a year since I purchased it. I asked if they could suggest what I might have been doing wrong and have NOT received any response. In view of the compliments that I've read about ARC, I'm very disappointed. ... I think that's expecting too much! Arc and the other hobby suppliers sell inexpensive tools : there's not much profit in them! If found faulty within the warranty or consumer protection period, the tool is replaced without holding a post-mortem! The guarantee starts when the tool is bought, not when it's first used. Though I've found hobby suppliers moderately helpful, buying from them doesn't include a course of instruction and full back-up service, particularly for easily broken consumables like taps! All is not lost - the Forum is good at answering "what went wrong" questions. A few possibilities:
Dave |
JasonB | 06/05/2020 10:18:42 |
![]() 25215 forum posts 3105 photos 1 articles | I think with something like a tap there are some people in the world who will try it on if they happen to break one (not saying you are one of them) and ARC are wise to this. From previous posts a single reported issue will be noted but may not be acted upon as you may have hoped, if more similar faults come to light then the line may be withdrawn or refunds/replacements offered. I know of a fairly recent item of tooling added to their range that was found to have a manufacturing fault, all those that had bought one (ARC keep good records) were contacted ( not waiting for any to complain) and offered a number of solutions that the buyer could opt for which I felt were all fair and reasonable. Edited By JasonB on 06/05/2020 10:20:07 |
Michael Gilligan | 06/05/2020 10:47:41 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 06/05/2020 06:45:49:
‘Disintegrated”? That seems unusual - they normally just break - usually at an inopportune time - and as a consumable, usually broken by the operator. Serial taps come in sets, so breaking just an isolated single tap is likely due to improper preparation, poor alignment, cheap quality or some other operator error. Some of my taps only get used for chasing, not making virgin threads because I know their limitations (from experience). Spending multiple pounds on a fourpence-halfpenny item does not seem like a profitable business and one reply likely cost far more than any profit on that item. Lastly, would you expect any other supplier to tell you how you are going wrong while using a tap bought a long time ago - likely without receipt and without the evidence of the broken parts for examination? I wouldn’t! . Wow ... Thanks for the MasterClass, ndiy Did you have a long and distinguished career in Customer Support ? MichaelG. |
Kiwi Bloke | 06/05/2020 11:44:48 |
912 forum posts 3 photos | Ouch. Getting back to the original question... There's nothing wrong with round-column machines, provided that there's a key (or keyway) along the column, to preserve alignment, as the head is moved vertically. The Emco FB-2 is such a one and is a fine, compact machine, and it's said that some of its oriental clones are tolerable. Used ones come up fairly frequently. Machines without any alignment-preserving feature are an abomination, regardless of whether some occasionally turn out acceptable work. |
Howard Lewis | 06/05/2020 12:41:38 |
7227 forum posts 21 photos | My Mill/Drill has a round column, so the head is locked very firmly before doing any machining. The easiest way to break a tap is to bend it whilst in use. (OK, you do get the odd dud! ) To my shame, I broke a M10 tap, and later a M3.5, both through sheer operator error! For tapping off machine, wherever possible, I use a tapping fixture (mine started life as the pillar for a pistol drill ) Think G H Thomas pillar tool, or the tool offered by ARC. The tap is held in a 3/8 capacity drill chuck, and the handle, to limit torque, is a short length of 6mm x 2 mm injection pipe. The tap is presented square to the work, in a small vice, and is not subjected to bending. So inviting trouble; tap breakages are rare. But why ALWAYS in the last hole on the final operation? Newton's Fourth law, perhaps. Howard |
SillyOldDuffer | 06/05/2020 13:18:00 |
10668 forum posts 2415 photos | Ron's point about buying the biggest machine you can is well made. (Unless specialising in miniature work.) Constrained by space and money, one does the best one can. Chaps often ask which is the best buy, hoping there's a simple market leader providing a well-made reliable machine with all accessories, extended warranty, brilliant customer service and bargain prices. Sadly, there is no such animal! The machines are similar, UK support is similar and prices vary. Turning questions upside down is often useful: are there machines that should be avoided at all costs? This too is difficult to answer, but I would duck buying a machine direct from abroad, or from an unknown private ebay seller. It's what happens if you get a dud that matters far more than the asking price, accessories, and optimistic advertising. Safer I think to buy from a UK company who cares about their reputation, honours Warranties, and is bound by UK Consumer Protection Law. With that in mind, almost anyone would do. With the possible exception of Arc Euro, all the vendors have dropped the ball at one time or another. But I've not had a problem with any of the 5 machines bought from Warco, who sorted out a lost in transit item without demur. Chester seem more likely to get a bad press on the forum, but they get good reports as well. Possibly the number of complaints is related to the number of machines sold. Amadeal also get good and bad reviews: as a smaller company, they're probably more vulnerable to intermittent staff issues. Several others about like Tool Co who don't get moaned about much or at all. But I've no experience of them. MachineMart are a box shifter; good in that they often display machines that can be eyeballed, and provide spares support, but don't expect the staff to know anything about machining. They sell it, you buy it, job done. My feeling is their machines are a bit basic, but I've not used one in anger. People do get results from them. My biggest regret is not getting into the hobby sooner due to working myself into a lather of indecision. Chaps still say Chinese machines are unacceptably bad, or just a kit of parts. Not my experience. Although my machines aren't as well-finished as a Myford Super 7, which itself is inferior to a heavy expensive industrial machine, they do everything I need, which is what matters to me. And what the flip are all those features for? Many may not matter much. There are some milling machine features I prefer and others I avoid:
All vertical mills can be used as precision pillar drills, and all can do precision filing work - edges, grooves, dovetails etc. But in the latter mode, motor power and machine rigidity matter. A small machine won't be a monster metal muncher, but given time it still delivers results. Basically, choose the size you need, going big rather than small, check prices for tax and delivery, check accessories included and look for offers, and then go for it. Ask the forum if there's a detail that concerns you: it may not matter at all. Dave
MC Black 2 | 06/05/2020 13:19:23 |
99 forum posts | Posted by Howard Lewis on 06/05/2020 12:41:38:
....... or the tool offered by ARC. .... Howard Thank you for taking the time to respond. While I have read about GHT's pillar tool, I should be most grateful if you would kindly clarify to which tool offered by ARC you refer. I have taken on board all the advice offered about tapping and hope that future tapping will be problem free. Will a Drill Chuck, with - I presume - three "jaws", grip a tap that has a square end? My gut feeling is that it will not. With best wishes and thanks again.
MC |
