Replacement hand wheel for mill
Hand wheel for mill
Jeremy Smith 202/05/2020 16:11:52
88 forum posts
15 photos
I recently acquired a used, import mill, but it is missing a handwheel. I’d rather purchase a replacement wheel than build one from scratch. The backside of the old handle had three little projections (like little teeth) sticking out. Where can i find a replacement wheel with these features? Most of the ones i see online only use a keyway to lock it to the shaft, which isn't what this unit uses.
JasonB02/05/2020 16:18:29
What machine is it. Some of the spares particularly for X axis handles have dog teeth on them so the handle can be disengaged
Pete.02/05/2020 16:19:30
910 forum posts
303 photos
Do you have picture? It's quite difficult to visualise your description
not done it yet02/05/2020 17:36:10
7517 forum posts
20 photos
Just because they have a keyway doesn’t mean you have use a key! Screw in some appropriate unthreaded studs (could use bolts and cut the heads off), of the appropriate size and in the appropriate places and you are “go”.
Howard Lewis02/05/2020 18:19:23
7227 forum posts
21 photos
Handwheels should be availoable from most importers.
Arc Euro and Chester offer handwheels, and would be surprised if Warco could not be able to supply.
Just measure the shaft diameter and length of engagement and then you are ready to start looking for a wheel of a diameter that takes your fancy. If it involves a key way, measure that as well, to add to your specification..
mechman4802/05/2020 19:37:23
2947 forum posts
468 photos
Have a look here..
George.
Jeremy Smith 203/05/2020 04:22:23
88 forum posts
15 photos
Jeremy Smith 203/05/2020 04:23:42
88 forum posts
15 photos
Gavlar03/05/2020 08:24:45
119 forum posts
I had a tatty Clark CMD1225 round column mill that used these hand wheels with the three protrusions. The same mill is sold with many manufacturers badge on it, Warco, Draper, Nutool, Pinnacle to name but a few.
Axminster also sell it, I think their model is the ZX30M
I replaced two of the handles on mine prior to selling it on with parts from Axminster, though they are not particularly cheap, about £15 each IIRC and Axminster quoted a 20 week lead time! In fact they were a little quicker but not much. I ordered them just before Christmas 2019 and they arrived this March
Prior to ordering from Axminster, I searched the net for spares for every manufacturer I could find without luck.
Bazyle03/05/2020 10:12:19
6956 forum posts
229 photos
That is the standard Warco etc round column mill so they are common but generally attached to their mill. The fixing screw you have was originally a roll pin, not a taper pin so there is a through hole in the shaft but this is just to hold the handle on. The drive however is taken through the dog clutch.
They aren't that common on ebay but may come up from someone converting to CNC.
I suggest while looking for one you make a simple crank handle and secure by drilling a slightly large hole aligned as best you can with the aforementioned through hole but only one side, then put on shaft and drill a tight hole through the shaft hole into the other side of the handle.
The other thing of course is don't bother because quite soon you will decide to make a power feed on one end of the x axis.
Martin Connelly03/05/2020 10:34:15
2549 forum posts
235 photos
I still have mine from before CNC conversion. What is the shaft diameter on the handwheel is to fit?
Martin C
PS. I also have an Align powerfeed from before CNC conversion.
Edited By Martin Connelly on 03/05/2020 10:36:02
Jeremy Smith 203/05/2020 19:24:42
88 forum posts
15 photos
I believe it is 5/8” shaft diameter.
Martin Connelly03/05/2020 20:33:44
2549 forum posts
235 photos
I've checked the bores on the three I have got and they are 17.1mm to 17.2mm.
Martin C
Edited By Martin Connelly on 03/05/2020 20:38:44
