Which Lathe???
I need a bit of help here.
Paul Smith 3705/04/2020 12:10:02
67 forum posts
Well this has probably been done to death, but ill ask the latest opinion.
Ive bought a Myford ML10 Metric a while ago, its a great little machine, but after a while i find myself hankering for a bigger unit. Its got a raft of extras with it, but i find myself being limited by what the unit can do. I hastily bought it without doing my research first. Im limited by the MT2 in the headstock.
The foot print of the lathe is great, small, compact and light. It makes a great finish and is very capable, to a point.
So my next route up is an ML7 with a big bore kit. Roy Milner has stopped making them, i messaged him a few days ago.Myford themselves make a big bore lathe based on the ML7 , wether they will sell me just a big bore headstock i i dont know.?They are closed at the moment. Do you know anybody else who makes one?
Roy was doing the headstock for £1500. Now you can buy a new lathe for that, but it will be chinese but 26mm capable.
I hear Warco and Chester gets good reviews, but also some terrible ones too. I prefer to stay English i think.
So i think ill change my route to an Myford ML7 and find the metric conversion for it, and try and find a big bore headstock .So the question is, which ML7?
One of the gearbox versions seems to be the way to go, whilst im changing over.
The other limiting factor is the space i dont have, the ML7 will fit, but a Boxford or similar toolroom lathe wont.
Im doing general fabrication of tools and log splitters,belt sanders etc for a hobby, i cant for one fit a 17mm shaft thru the headstock as its mt2.
Ive a 52 inch width available , slighty more if the unit can be pushed in at an angle then squared up afterwards due to a shelving support, which i could move if i have to.
Thanks in advance for taking the time to reply.
Your views are greatly received.
Edited By Paul Smith 37 on 05/04/2020 12:11:46
Journeyman05/04/2020 14:07:54
1257 forum posts
264 photos
See *** Journeyman's Workshop *** for my views on choosing machinery!
Paul Smith 3705/04/2020 15:48:53
67 forum posts
Thats a good and comprehensive read that. well put together !
SillyOldDuffer05/04/2020 16:35:49
10668 forum posts
2415 photos
Posted by Paul Smith 37 on 05/04/2020 12:10:02:
Ive bought a Myford ML10 Metric a while ago ... find myself hankering for a bigger unit.
The other limiting factor is the space i dont have, the ML7 will fit, but ...
Tricky one, but despite objections to Chinese, one of them may be the answer. Going 'English' reduces the available choice particularly if a good condition big bore must fit into a small space. It may take a while to find a suitable classic machine, especially if metric is also important. (Buying second-hand, condition is more important than make and model.)
Myford suffer from the name attracting premium prices. If money is no object Triona list a Connoisseur at the moment. It's said to be in unused condition. Price on Application; no harm in asking, but make sure your pacemaker has a fresh battery!
Health emergency apart an important advantage of new Chinese machines is they're available off-the-shelf in a wide range of different sizes. The machine that fits best into the available space can be picked out of a catalogue.
Edited By SillyOldDuffer on 05/04/2020 16:37:18
thaiguzzi05/04/2020 17:08:26
704 forum posts
131 photos
Posted by Journeyman on 05/04/2020 14:07:54:
Well put together website. Well done.
Enough!05/04/2020 17:19:13
1719 forum posts
Paul, you,of course, know your own needs but if "big-bore" is driving your choice make sure that you actually need it.
I started with an early Chinese lathe and then got an ML7. I kept the Chinese lathe as well because of the larger bore. I actually used that machine, I think, once in 7 years and then mostly "because it was there".
I finally sold that lathe and haven't missed it.
ymmv.
Paul Smith 3705/04/2020 19:37:01
67 forum posts
That connoisseur will be big bucks , fat end of 8k id say. But tanks for the heads up.!Im not a collector, i want to use it. Quite why you'd want to collect lathes is beyond me , watches are easier to store.
Paul Smith 3705/04/2020 19:38:35
67 forum posts
Ive also wondered about boring out the spindle and keeping a spare to swap back should i need to.
Edited By Paul Smith 37 on 05/04/2020 19:39:12
Paul Smith 3705/04/2020 19:42:13
67 forum posts
So what chinese lathes are any good?
Dave Halford05/04/2020 20:06:33
2536 forum posts
24 photos
Harrison M300, there's 4 on ebay in the UK, 2 might be OK, 2 are junk.
Prices are pretty much the same
Andrew Evans05/04/2020 20:19:05
366 forum posts
8 photos
My advice is go for something as big as you can fit in your space.
Clive Brown 105/04/2020 20:43:45
1050 forum posts
56 photos
Posted by SillyOldDuffer on 05/04/2020 16:35:49:
IIRC I noticed that same Myford a few days ago at £14K. Perhaps it was April 1st.
Paul Smith 3705/04/2020 20:49:31
67 forum posts
£14k crikey o riley. ill leave that there.
Thanks Andrew
Thanks Dave. ill check them out
Thanks Mr Banders
Thanks Mr Duffer
Hollowpoint05/04/2020 21:14:18
550 forum posts
77 photos
What about a Boxford with the rear mounted motor. About the same size as the myford but a better machine.
Paul Smith 3705/04/2020 21:15:14
67 forum posts
Posted by Hollowpoint on 05/04/2020 21:14:18:
Have you a model type? whats the spindle capacity?
Hollowpoint05/04/2020 21:43:03
550 forum posts
77 photos
Im not up on my Boxford models, but ME10 and CSB come to mind though ive seen models A, B, abd C with rear mounted motors too.
The underdrive models are CUD, BUD and AUD.
I believe the spindle bore is about 3/4"
Clive Brown 105/04/2020 21:49:47
1050 forum posts
56 photos
The standard Boxford passes 3/4", (3MT). Bigger bore versions were made but rare.
All are screwcutting except any designated "T" which are very basic.
Model A:- Screwcutting g/box., power cross feed & long. feed
Model B:- Power cross-feed & long. feed
Model C;-Power long. feed.
Hollowpoint05/04/2020 22:15:16
550 forum posts
77 photos
Thinking about it the under drive models probably take up less room than the rear drive models and not much more than a ML7. About comparable to a super 7.
I understand you said you don't have much room but the only difference is the cabinet rather than being bench mounted.
Paul Smith 3705/04/2020 22:31:35
67 forum posts
Im looking into the Boxford box lathes, they maybe very efficient in what they do, which is of course the primary goal, but lack the charisma of a myford super 7 style lathe. Or Is it me just being a tart?
Martin Hamilton 105/04/2020 23:17:23
188 forum posts
I have always thought Myfords have been way over priced, as an example Home & Workshop Machinery has a Myford Connoisseur big bore for a whopping £14000 + vat £16800 total.
