mike robinson 2 | 18/03/2020 13:54:23 |
38 forum posts 32 photos | I am machining bronze castings for the Bolton Marine triple expansion. Normally I can achieve good quality surface finishes using insert tooling (DCGT 070202 FL K10). The parts I am machining now are the 3 lower covers. For a reason I cannot determine the face surface finish has ripples about .125" apart with a depth of .00025" using a .003" cut. As the photo shows there is an interrupted cut. The insert is new and the "sound" of cutting is good and the top slide and carriage are both locked when cutting. The cross side is set correctly. I have power cross feed on my Super Seven and first thought that was the source given the regularity of the ripples, even if I had very successfully skimmed my face plate with automatic feed. I repeated the process and used manual cross feed and that result is what you see in the photo. I have never Any suggestions for understanding the cause and solving this problem is very welcome. (PS: I have not tried a standard HSS tool bit as yet. Thanks |
not done it yet | 18/03/2020 14:07:54 |
7517 forum posts 20 photos | Have you tried a different insert? No mention of the origin of the inserts - that might be pertinent. Suggest you try that HSS cutter and report back. |
Steviegtr | 18/03/2020 14:12:26 |
![]() 2668 forum posts 352 photos | This is the insert mike is using. Steve. Edited By Steviegtr on 18/03/2020 14:12:59 |
Jeff Young | 18/03/2020 14:28:11 |
![]() 9 forum posts | It may be just down to inexperience on my part, but I nearly always find it harder to get a nice finish with carbide tooling. I rarely have the same level of issues with HSS. |
Former Member | 18/03/2020 14:40:47 |
1329 forum posts | [This posting has been removed] |
JasonB | 18/03/2020 14:44:47 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Steviegtr on 18/03/2020 14:12:26:
This is the insert mike is using. Steve. Edited By Steviegtr on 18/03/2020 14:12:59 Doubt it as your link is for a different code. |
Howard Lewis | 18/03/2020 14:48:37 |
7227 forum posts 21 photos | Carbide inserts are designed to operate at speeds and feeds so that the metal/tip interface becomes so hot that the metal softens. Given the lower co efficient of friction than steel, this may be more difficult with copper based alloys. My suggestion would be to grind up a HSS tool and use that for the finish cut. Before going for the finishing cut, it might be worth checking that any drive belts are in good condition, and not sending any vibrations through the drive train. Single phase motors are also known to give similar problems if the conditions: speed / load/rigidity/tooling are not correct As ever, the devil is in the detail! Howard. |
JasonB | 18/03/2020 14:51:15 |
![]() 25215 forum posts 3105 photos 1 articles | Try a new tip just incase the one was damaged. Also swing the tool around say 10deg Pip on the end also suggests you are slightly low if same tool was used to face the spigot. |
Steviegtr | 18/03/2020 14:52:02 |
Well just tried again & got the exact same number as mike posted. |
JasonB | 18/03/2020 15:01:23 |
![]() 25215 forum posts 3105 photos 1 articles | Try reading his post again, the chipbreaker ref is FL not AL, Probably Taegutec as thats a common lower price brand that uses that suffix. |
Andrew Johnston | 18/03/2020 16:10:16 |
![]() 7061 forum posts 719 photos | Normally one would invoke the following equation: Ebay insert = crap shoot However the linked to Yamaloy insert (even if they're not the ones being used) are sold by Cromwell, albeit at a slightly lower price. But they're on 2 days which makes me slightly suspicious as Cromwell customers are most likely to be commercial machine shops, not used to waiting. From the picture the ridges seem quite obvious, but they're stated to be a bit over 2 tenths of the thou deep. At that sort of depth I don't think they'd be so obvious? Not sure it has a bearing on the finish, but 3 thou is a pretty shallow finishing cut. I've not really had a problem turning bronze or gunmetal with inserts so difficult to make suggestions. But the wide spacing makes one think of a machine related problem rather than the basic cutting process or, possibly, the casting itself? Andrew |
Mick B1 | 18/03/2020 16:32:22 |
2444 forum posts 139 photos | If you see that sort of rippled finish on longitudinal turning, especially by compound slide, it *can* indicate a little too much clearance in the slide gib, so my first thought would be to look for such in the crossslide gib. You may already have checked that, of course. |
Mick B1 | 18/03/2020 16:33:24 |
2444 forum posts 139 photos | Posted by Mick B1 on 18/03/2020 16:32:22:
Duplicate... Edited By Mick B1 on 18/03/2020 17:00:22 |
Tony Pratt 1 | 18/03/2020 16:34:34 |
2319 forum posts 13 photos | Maybe a machine issue? Difficult to tell. Tony |
not done it yet | 18/03/2020 16:36:23 |
7517 forum posts 20 photos | Posted by JasonB on 18/03/2020 15:01:23:
Try reading his post again, the chipbreaker ref is FL not AL, Probably Taegutec as thats a common lower price brand that uses that suffix. Yes, that’s what I thought. Less than £3 per tip in a packet of ten. Might even have been less, if bought from bang good! Could be anything - like a loose insert for instance. Let’s await some decent feedback. |
Clive Brown 1 | 18/03/2020 16:54:37 |
1050 forum posts 56 photos | My prime suspect would be the insert. Bronze is fairly tough stuff. The rather shiny finish shown in the picture suggests a degree of rubbing is taking place, despite the "good" sound. I'd go for a well sharpened HSS tool with some nose radius. |
John Baron | 18/03/2020 16:58:18 |
![]() 520 forum posts 194 photos | Posted by not done it yet on 18/03/2020 14:07:54:
Have you tried a different insert? No mention of the origin of the inserts - that might be pertinent. Suggest you try that HSS cutter and report back. I've seen that effect caused by drive belt thrash !
Former Member | 18/03/2020 16:59:57 |
Bazyle | 18/03/2020 17:26:23 |
![]() 6956 forum posts 229 photos | The pattern seems to repeat evenly, as the op said at ) 0.125 spacing. How does the insert know it has cut that much over and over again? If it were a random pattern maybe somehow but not a neat repeat. edit - just re-read the fist post and see he did manual feed in the end so 2 & 3 discounted. I'm impressed he has managed such a good finish manually as slight changes to hand pressure and feed rate show up. When I hand feed I use two hands and can get marks where I change grip, not necessarily at exactly one turn.
Edited By Bazyle on 18/03/2020 17:34:38 |
old mart | 18/03/2020 19:15:44 |
4655 forum posts 304 photos | I have experienced this before myself. Facing on the Smart & Brown model A, I was getting exactly that finish. Now I don't. The cross slide leadscrew was unevenly worn, especially in the middle and the nut was bad too. Backlash was possibly 0.025", maybe more. I bought a new leadscrew with two new bronze nuts on ebay which was sold as 8tpi, originally for some other make of lathe, but the threaded length meant it could be modified. Unfortunately it turned out to be 3mm pitch and the vendor kindly refunded me my money and said keep it. Eventually, I decided to use it on the imperial lathe, as there was little prospect of ever getting an imperial threaded leadscrew, especially a new one. The metric leadscrew now resides in the lathe with an additional modification using both nuts for superior antibacklash. It is set for 0.001" backlash over the 7" of movement. The new dial we made has 118 divisions instead of 125. The error per turn with 118 divisions is 0.0001102", which is not significant if you measure the size when getting close to the finishing cut. Checking the gibs would be worthwhile as well as leadscrew nut backlash, plus leadscrew axial play. Edited By old mart on 18/03/2020 19:19:43 |
