Toolpost question
Mark Braham12/03/2020 08:17:41
15 forum posts
I have a myford ml7 and thinking about a qctp, will a multifix type A fit or will i need the smaller Aa, i like the 40 point system, but any other recommendations greatly accepted. Cheers Mark
David George 112/03/2020 22:18:24
2110 forum posts
565 photos
Bump someone will answer.
Steviegtr12/03/2020 22:42:32
2668 forum posts
352 photos
Do you have a picture or link to the one you want. I have fitted the 250-111 or size 2 to my S7 which I guess will have the same compound. The reason was because I had quite a lot of cutters that were 14mm + To fit this one I had to get 4mm ground off the top of the compound & then I machined 4mm from the underside of the holders so I could get them low enough. All great now & glad I did the conversion. Look at you tube ,I think Steve Jordan did one on his ML7. The one I have will only take 1 holder at a time though. Just thinking about it , does your compound rotate for angle cuts or is it fixed.
Steve.
Michael Gilligan12/03/2020 23:15:33
23121 forum posts
1360 photos
Posted by Steviegtr on 12/03/2020 22:42:32:
Do you have a picture or link to the one you want. I have fitted the 250-111 or size 2 to my S7 […]
Possibly some confusion there ^^^, Steve
For reference: The original [Swiss] Multifix Quick-set is shown here: **LINK**
http://www.lathes.co.uk/multifix/
Mark is presumably looking for one of the modern clones.
Steviegtr12/03/2020 23:50:03
2668 forum posts
352 photos
Posted by Michael Gilligan on 12/03/2020 23:15:33:
Ah I did wonder. Doh.
Steve.
Nick Hughes12/03/2020 23:56:35
307 forum posts
150 photos
I have the Aa size on my S7.
The standard A size tool holder will not go low enough, BUT the genuine Multifix made some special A size tool holders for the Myford 7 lathes and I think the set was designated Am.
Nick.
Edit:- Even when using the Aa size with insert tooling, the 8mm square shank tools only just go low enough, to be on centre height (I use 10mm square, milled down to 8mm high, leaving them 10mm wide).
Edited By Nick Hughes on 13/03/2020 00:07:28
Mark Braham13/03/2020 08:54:32
15 forum posts
Found all the dimensions online and ordered the Aa size as its within spec for the toolpost base to chuck centre, chose the german multifix although i believe they all come from china. Anyway its a nice birthday present to me from my wife .
Michael Gilligan13/03/2020 09:51:06
23121 forum posts
1360 photos
Wishing you a Happy Birthday, Mark yes
Please let us know what you think of it.
Mark Braham13/03/2020 10:08:51
15 forum posts
Jusr had a lovely message from PeWetools in germany, telling me his story about his multifix toolpost and the devopments using china as his supplier, was a very i interesting read.
Lee Rogers13/03/2020 10:14:15
203 forum posts
I'll second that and please do post and let us know how you get on with it . I'm a Drummond user and tool post rigidity is key to getting these little lathes to work well. The M type is more capable in some respects than an ML7 but a rigid set up is vital.
Nick Hulme14/03/2020 10:27:45
750 forum posts
37 photos
I looked at Multi-Fix and found that almost none of the angles I wanted to set tools at were catered for by the 9 degree increments.
Mark Braham14/03/2020 10:57:10
15 forum posts
You can still turn the whole post if you wish, unless you pin it in position. Which obviously needs to be very carefully done to ensure its parrallel to the chuck.
Joseph Noci 114/03/2020 11:52:09
1323 forum posts
1431 photos
Posted by Mark Braham on 13/03/2020 10:08:51:
Interested to see what PeWetools had to say - My experience with the Chinese Create Tool holders was excellent - Instead of repeating it all , if interested the relevant posts are HERE
Peruse the whole page of posts, but maybe from 12/07/2017 is more to the point
Joe
Edited By Joseph Noci 1 on 14/03/2020 11:53:58
