John Weight | 07/03/2020 15:37:04 |
56 forum posts 14 photos | Good afternoon everyone, I have a spare fridge motor which I want to reuse as a small compressor. There are three pipes from it, one of which was attached to the thermostat, one is crimped off (which was used I believe to allow filling with refrigerant) and the third one is open. My question is which would be the proper one to use as the output as both have air coming from them. Any suggestions would be much appreciated, Many thanks, John Weight. |
bill ellis | 07/03/2020 16:08:06 |
71 forum posts 2 photos | Put your finger over the ends of the open tubes, one should suck, one should blow. Use the blow to fill your cylinder. If that is not the case I would suggest that your compressor is not well. |
Steviegtr | 07/03/2020 16:09:03 |
![]() 2668 forum posts 352 photos | Is it an old motor. It could be goosed. I remember dad making one using an old fridge comp & a fire extinguisher for the tank. It does need oil though in the sump. So not much good for painting without a good trap fitted. There should I am sure be only air coming from one port as it has a reed valve in there. To add, look on youtube as I think some have cut the outer body away which is only there for the refrigerant. Steve. Edited By Steviegtr on 07/03/2020 16:11:22 |
Bob Stevenson | 07/03/2020 16:20:54 |
579 forum posts 7 photos | https://www.youtube.com/watch?v=7cRS91c8f7w
....One of the best 'make a fridge compresser' vids |
martin perman | 07/03/2020 19:27:41 |
![]() 2095 forum posts 75 photos | Posted by Bob Stevenson on 07/03/2020 16:20:54:
....One of the best 'make a fridge compresser' vids What an excellent video particularly the filter made from a door knob. Martin P |
duncan webster | 07/03/2020 20:00:09 |
5307 forum posts 83 photos | Unless you know that the old fridge doesn't have Freon refrigerant please don't just chop the pipes on an old fridge and let the gas out, it causes breakdown of the ozone layer |
Nicholas Farr | 07/03/2020 22:00:37 |
![]() 3988 forum posts 1799 photos | Hi, a cautionary note, you should never put your finger or any part of you body, over an opening of compressed air. Compressed air or any compressed gas can pass through your skin and get into your blood stream, which is something you do not want to happen. Regards Nick. |
Robert Atkinson 2 | 07/03/2020 22:07:01 |
![]() 1891 forum posts 37 photos | I would add to Duncan's comment, Don't release the refrigerant from ANY fridge (or similar device). If it is a domestic unit it almost certainly contains CFC's. It is an offence to deliberately release CFC's as well as being bad for the environment and a potential health hazard. If it's not a CFC it will be ammonia which is a serious health hazard. For the OP, if the two ports do not have obvious suction and pressure (pressure should be at what you are calling the "thermostat" which I'm guessing is the expansion valve) Then the compressor is faulty. Most likely a valve failure, but could be a fractured pipe or badly worn. Any fridge compressor need oil for lubrication SAE 32 hdraulic oil used for nmany lathes e.g. Nuto 32, is fine.
Robert G8RPI. |
