Silvers soldering
Peter Simpson 122/02/2020 14:25:36
206 forum posts
9 photos
When silver soldering what is the best method of ensuring that other parts in close proximity to the "joint" does not get soldered. I have made a jig to make some lifting arms. I do not want the arms getting soldered to the jig ?
Jim Nic22/02/2020 14:44:59
406 forum posts
235 photos
I use a coat of Snopake typing correction fluid where the solder is not to flow. (Note that this fluid will not correct machining errors!)
Jim
Former Member22/02/2020 14:58:42
1329 forum posts
john fletcher 122/02/2020 15:27:50
893 forum posts
Lamp black from a candle will also work. When plumbers used lead pipe they used a substance in a Yellow tin called "Plumbers Black" to keep things tidy. They used an old paint brush, dipped it some water, gave it a shake, scrubbed around on top of the black cake and painted it around the pipe, forming a neat band, which prevented solder from going where it wasn't needed. Under ground cable jointers did the same. I have been searching for a supplier for "Plumber Black" for quite some time. It would seem plumber now use plastic pipe where ever possible. John
Former Member22/02/2020 15:48:34
1329 forum posts
HOWARDT22/02/2020 15:58:50
1081 forum posts
39 photos
Off topic. Some years ago I was told by one of the copper fitting manufacturers, one reason for solderless fittings was having to have a fire Marshall standing by the plumber in refurb buildings during naked flame soldering.
Speedy Builder522/02/2020 16:13:32
2878 forum posts
248 photos
Bill, are gas pipes plastic and compression fittings these days as well ?
Steve Skelton 122/02/2020 16:17:15
152 forum posts
6 photos
I find a little jewellers rouge made into a paste with water and painted onto the surface works best for keeping silver solder from spreading where it isn't wanted.
Steve
JasonB22/02/2020 16:18:47
If you use correction fluid as I do it should be the solvent based one.
Nick Clarke 322/02/2020 17:55:05
1607 forum posts
69 photos
Wondered what 'Plumber's black' could be so did an internet search.
First few results were local plumbers followed by a whole stream of XXXXX adult websites.
The world we live in today!
Former Member22/02/2020 18:15:34
1329 forum posts
Peter Simpson 122/02/2020 18:38:19
206 forum posts
9 photos
Jason which one should I look for. Not sure which ones are solvent based.
JasonB22/02/2020 19:25:29
The one they call Tipp-ex rapid like this
Dave Halford22/02/2020 19:31:43
2536 forum posts
24 photos
Posted by john fletcher 1 on 22/02/2020 15:27:50:
Phone cables were poly and already being jointed with epoxy back in the late 60s, that boat left a very long time ago along with all the lead cables
Paul Lousick22/02/2020 21:31:15
2276 forum posts
801 photos
Jason,
What do you use to remove the Tipp-ex after soldering? I find it difficult to clean up after it has burnt on.
Paul
Hopper22/02/2020 22:46:40
7881 forum posts
397 photos
You can paint on Milk of Magnesia and let it dry. The solder/braze will not stick to the dried magnesium powder.
Jim Nic22/02/2020 23:10:04
406 forum posts
235 photos
Paul
I don't know how Jason removes Tippex, but I find that what I use easily comes off along with any burnt/dried flux residue in the pickle bath and after with a scrub with a toothbrush. (Don't let on to the better half whose toothbrush you use for this.)
Jim
JasonB23/02/2020 07:00:44
My pickle removes it along with HT5 flux in about 1/2hr, I use Feb brickclean that contains hydrochloric acid
Dennis R24/02/2020 19:24:05
76 forum posts
16 photos
Tipp-ex rapid double pack is on offer at £2.99 in W H Smiths today, seems very good value.
Dennis
Peter Simpson 127/02/2020 18:08:47
206 forum posts
9 photos
Bill this a photo of an embryo lifting arm mounted on the jig prior to silver soldering jig.jpg
