TE winter storage
David GW26/01/2020 09:39:44
32 forum posts
I’m fortunate in having very few ferrous parts actually on my TE but I still spent a fair part of yesterday out in the garage wire-wooling surface rust of the wheel strakes and other machined surfaces before wiping them with an oily rag which had me wondering how others dealt with this and if they had any good winter storage tips?
Bob Rodgerson26/01/2020 09:48:14
612 forum posts
174 photos
Spray with ACF 50 prior to storage. When ready to take out of storage simply wash off and dry prior to using again.
It works for my motorcycles and prevents salt corrosion when riding on salt treated roads.
Andrew Johnston26/01/2020 10:01:05
7061 forum posts
719 photos
I keep my part built engines (which are mostly steel and cast iron) in the house.
not done it yet26/01/2020 13:24:07
7517 forum posts
20 photos
Relatively warm, dry and surface coated. Not much different than machine tools in workshops - of which there are several threads for their protection.
Edited By not done it yet on 26/01/2020 13:24:40
David GW26/01/2020 13:40:58
32 forum posts
Posted by not done it yet on 26/01/2020 13:24:07:
If I had a warm dry place for my TE it wouldn’t rust, unfortunately my TE lives in a garage, a garage of the bog standard up & over door variety with an interior climate not unlike the exterior one.
Bazyle26/01/2020 14:37:18
6956 forum posts
229 photos
My biggest worry would be freezing, especially small pipes if not the boiler.
Next I would be concerned about soot residue in the tubes, firebox and smokebox. Ash and soot contain sulphur compounds which in damp turn to acid.
Whenever you look at an old machine tool, or lawnmower for that matter that was left in a shed or garage unattended since the owner died there is a film of rust on the top of the handles most noticeably not the bottom. This shows that it has bee subjected to falling dew, just like outside but still possible inside just in a smaller way. Yes dew falls inside your shed by the same mechanism as outside. So after your rust treatment be sure to cover with a cotton sheet or wool blanket using sticks to keep it off surfaces where possible. Don't or plastic or synthetic sheets/blanket. The natural fibres absorb the moisture and return it to the atmosphere when conditions improve.
When you read the machine rust related threads as suggested above you will notice that I always recommend clear Waxoyle or equivalent car uderbody wax diluted with white spirit.
Vidar26/01/2020 17:06:00
57 forum posts
I've had to keep some large shiny cast iron items outside for years where they were exposed to all the climate has to offer - rain, snow, ice. Oil and various protective spraybox covers failed - they tend to get washed off leaving unprotected spots or areas. After spending lots of time and money on applying such products I gave up on that. I then raided the foodstore and bought plenty of what google translate claims is "lard" in English. Basically acid-free fat.
I melted it and brushed it on in several thick layers (it hardens as you brush it on cold metal so very easy to apply). That basically made an all covering acid free water and oxygen proof cover that was very effective at keeping rust away. It worked for years outside - when removed the cast iron was still shiny.
I figured a general tarp would help preserve the fat layer so I had that on too. That strategy had to be improved to a new tarp with some centimeters distance off the surfaces: The first tarp, fat layer and cast iron setup were all viciously attacked by large flocks of tiny birds with increasingly flat beakers. (I admit that was a surprise I didn't see coming!).
Edited By Vidar on 26/01/2020 17:07:26
Dalboy26/01/2020 17:36:49
1009 forum posts
305 photos
Cover it up and place something like this HEATER under the cover so that it does not touch anything it has a thermostat. Low consumption. I have one in my workshop and not had any problems with rust.
JasonB26/01/2020 17:45:58
Along similar lines is to make an insulated box and then put a low wattage light bulb in the firebox which I have heard people use.
Like Andrew all my engines live inside, this chap had the right idea
not done it yet26/01/2020 17:48:51
7517 forum posts
20 photos
Posted by David GW on 26/01/2020 13:40:58:
Parked in a corner? 100mm of insulation all round and over, if not some underneath as well. Minimal heating required and some form of desiccation would be an advantage.
That is a bit like my ~12m^2 workshop. Nothing on concrete floor and has a fairly close-fitting, insulated, steel entrance door and some small gaps at floor level. It gets about half a unit of leccy per day most of the time and three quarters when ‘wintry’. A little more if I am working in there. The leccy is for running a desiccant dehumidifier for 2 or 3 hours per night. Ceiling height is 2.2m.
David GW26/01/2020 18:54:42
32 forum posts
Right ok, a bad idea all round then, I think the easiest solution is to bring it in the house next winter where it’s guaranteed warm & dry, it’s only 3 foot long so hopefully she won’t notice wink
peak426/01/2020 20:44:11
2207 forum posts
210 photos
Here's an interesting review in the bike press, which doesn't rate ACF-50 too highly.
Note the methodology though, involving spraying salt water and repeatedly hosing down to simulate riding a bike over winter.
That said, I've been using ACF-50 on Landrover(s) and bikes OK, and it is designed for aviation.
I also like Motorex 645 "Protect and Shine", though I think it's been re-marketed as MotoProtect
The latter goes on nicely as a fine spray and doesn't seem to attract too much dust; when allowed to dry, it's barely noticeable. I've been using that on the bare alloy wheels on the Marlin kit car, and have only polished them properly a couple of times in the last 10 years or so; yes they still look OK, though I tend to avoid using it on salty roads.
Bill
Steviegtr26/01/2020 21:18:36
2668 forum posts
352 photos
On my boat I used to have a large box with a compound in it. Some say it was salt, not sure. It absorbed the humid air & filled eventually with water. Simple to empty, dry out & re-use. In my garage I have a dehumidifier running 24-7. Set on a medium setting. On high it runs continually & costs a fortune in electric. My garage is 9M x 4M so quite big. I made it from 100mm insulated walk in fridge panels. Still get about 1/2 litre a day from the water catch box. Even my floor is painted onto concrete. Damp winter months eh. Do you have a cover for it. I know a few biker friends that vac bag there bikes for winter.
not done it yet27/01/2020 08:51:06
7517 forum posts
20 photos
I collect about 1/2 litre for about 8p worth of leccy (3 hours run time). The heat is likely as useful as the humidity reduction. I don’t consider that too much to protect my kit.
Running any dehumidifier continuously, when not required, would be an obvious waste of money.
