Painting
Garry Coles25/01/2020 10:36:49
121 forum posts
100 photos
Hi, I'm going to be priming some of the parts of my 2 in scale D & NY Traction Engine that i'm building. Some of the sheet steel plate has a grey finish to it, and is very hard to get off. I was wondering if this has to be removed before I prime. (The primer I am using is Phoenix Precision 2 pack etch primer.) It seems to be part of the protection for the steel plate when it comes out of the foundry. Can anyone advise me please.
Garry
vintage engineer25/01/2020 11:07:37
293 forum posts
Sounds like zinctec steel.
Garry Coles25/01/2020 11:21:25
121 forum posts
100 photos
No, it's just ordinary sheet steel that EKP supplies. No zinc involved.
Jeff Dayman25/01/2020 14:09:07
2356 forum posts
47 photos
Might be wise to ask EKP what it is, to make sure the paint you use is compatible. Just food for thought.
Neil Wyatt25/01/2020 14:26:41
19226 forum posts
749 photos
86 articles
Posted by Garry Coles on 25/01/2020 10:36:49:
Garry
If it is standard rolled steel plate it is just an oxide film that can be left, or you can get it off with brick cleaner.
JasonB25/01/2020 16:08:22
Yes as Neil says just a thin mill scale, probably a bit of S275 steel. If I'm doing a lot of work on a part I will strip it off with brick cleaner(acid) first if not just leave it on as it adds a bit of texture which often siuts teh fabricated "castings" that I make.
Garry Coles26/01/2020 07:40:23
121 forum posts
100 photos
Thanks everyone.
Dell26/01/2020 09:16:40
230 forum posts
44 photos
Hi
you don’t have to etch steel as today’s primers have very good bonding to steel .
Dell
Speedy Builder504/04/2020 09:55:00
2878 forum posts
248 photos
What paint do you use for your Steam Locomotive and who supplies it?
Garry Coles06/04/2020 07:49:11
121 forum posts
100 photos
Hi there Speedy. Here is the paints I've been using.
Phoenix Precision Paints.
2 part etch primer PQ31 & PQ32.
Pre paint metal cleaner PQ17
This gives a lovely smooth hard surface.
Yourspraypaints.com
Loads of colours and finishes to choose from, and then they fill the spray cans for you.
Hope this is of some help for you.
Garry
bernard towers08/04/2020 23:50:59
1221 forum posts
161 photos
If the parts to be primed are steel why are you using etch primer. Etch primer has been specifically designed for hard to bond materials and steel is not one of them. Much better to use a zinc chromate.
