Here is a list of all the postings Garry Coles has made in our forums. Click on a thread name to jump to the thread.
Thread: BR 2-6-4 Tank Loco |
11/06/2023 19:14:30 |
Hi,I was wondering if anybody out there is or was building a BR 2-6-4 Tank engine to the Doug Hewson design. If so, I would like to make contact and discuss a few things. Thanks Garry |
Thread: Boiler construction |
25/01/2023 16:33:34 |
I live in Jersey and as far I know there are no model boiler inspectors over here. |
25/01/2023 14:43:24 |
Hi, I want to buy a copper boiler for a 5in gauge loco that I will be building. I've had various quotes that have ranged from £3100 for TIG welded to £6500 for silver soldered. My question is, what are the pros & cons for silver soldered or TIG welding. Which would you recomend. Garry |
Thread: Model engineers |
05/01/2023 17:07:28 |
Hi, Can anyone help me please. Do you know of anyone over here in Jersey that makes steam engineering models, such as stationary steam engines and steam locomotives. I would really like to meet someone with the same interest. |
Thread: Stuart No 4 |
01/01/2023 10:51:47 |
Thanks for the info on bumping & the postion of the lubricator. Garry |
01/01/2023 08:11:18 |
bump ??? |
31/12/2022 07:58:19 |
Hello I'm building a Stuart No 4 and would like to know if a displacment lubricator can be fitted directly to the side of the valve chest. Or does it need to be connected to the steam inlet. |
Thread: Stuart No 4 valve timing |
25/10/2022 22:02:51 |
Thanks Jason, that's what I thought. |
25/10/2022 18:49:36 |
Hi, I'm building the Stuart No 4 and I'm in the middle of making the two eccentrics for the reversing gear. The two of them are pinned together at 33 degs/66 degs apart. I was wondering how critical is the timing for the running of the engine. I am finding it difficult to get it exactly right. So if it's a degree or to out will it make much difference to the running. When I was machining the eccentrics, I lost the middle line reference. So that's why i'm finding it so difficult. Can anyone advise me on this please. Thanks Garry |
Thread: Magnetic bronze |
30/09/2022 15:59:13 |
Thanks. Never realised that the bronze family had so many variations. |
30/09/2022 14:04:22 |
Hi. Many years ago I obtained two 12 in X 1 in diameter bronze looking round bar. I didn't know what sort of bronze it was, so it was not going to be used on any thing important. I thought it would come in handy for something one day. And today it did. I am machining up some pipe flanges for a globe valve. The bar machines very nicely. Now, when I was cleaning the lathe afterwards I noticed that a magnet that I had close by had some of the bronze on it. On closer inspection I found it to be only very slightly magnetic. Can someone enlighten me as to what this sort of bronze is. Thanks Garry |
Thread: Traction Engine Castings |
26/08/2022 07:47:25 |
Hi Bill, it's definitely Durham & North Yorkshire castings as I have just finished building mine this year. Garry |
Thread: Displacement lubricator |
02/08/2022 17:10:50 |
Hi. I have a question about the position of the Displacement lubricator on a stationary engine. I have seen many pictures on the net with the Displacement lubricator mounted on the side of the steam chest. Does this position work. I thought the idea was to have it in the steam supply pipe so the passing of the steam drags some of the oil with it. Thanks Garry
Thread: Painting gloss |
25/06/2022 08:44:42 |
Hi. Have just finished building my Stuart No 9 and I am in the middle of painting it using the Stuart gloss paints. The instructions on the tin says to leave for 24 hours before overcoating. But with gloss you usually should rub down inbetween coats to create a key for the next coat. But with such small parts, you can't get to all the surfaces. So, will the paint adhere to the first coat as the paint is still fresh. Garry |
Thread: Governor drive belt |
19/06/2022 22:11:56 |
Thanks for the ideas. I have ordered some "O" ring and will try this first and if that is no good I will try some of the other ideas. Garry |
17/06/2022 13:18:19 |
Thanks for the "O" ring idea. I will try that and see what happens. |
17/06/2022 08:04:07 |
Hi. Regarding the Stuart Turner governor spring belt. Once you screw the ends together, how do you get them apart again. It seems that when you screw them together the spring opens up slightly, but it seems impossible to unsrew because the spring tightens up. And is there other types of belt that will work as well on this sort of Governor. Thanks Garry |
Thread: Pipe lagging |
05/04/2022 06:59:47 |
Thanks, have now got a few ideas on what to use. |
04/04/2022 18:47:09 |
Hi, I want to lag some of the 3/16 copper pipe coming out of my stand alone boiler, and was wondering what sort of material you guys use. Any ideas please. Thanks Garry in SUNNY jersey !! |
Thread: Piston ring grooves |
17/01/2022 18:37:37 |
Thats helpful, thanks for your replies. Garry |
