Rod Ashton | 20/01/2020 08:27:43 |
344 forum posts 12 photos | Hi - I am looking for advice in respect to CNC cutting some kind of model board with a high rev. 60 deg V cutter, such that I can detail bricks in OO/OH gauge. Your advise appreciated. |
Tony Pratt 1 | 20/01/2020 08:36:13 |
2319 forum posts 13 photos | You need to be more specific. Tony |
John Haine | 20/01/2020 08:41:54 |
5563 forum posts 322 photos | If you mean something like high quality mdf then you could try Valchromat. |
Martin Kyte | 20/01/2020 10:00:17 |
![]() 3445 forum posts 62 photos | Trespar, or extruded rail to build a frame. regards Martin |
Rod Ashton | 20/01/2020 10:33:57 |
344 forum posts 12 photos | Gentlemen - Thank you. Just to clarify. I tried cutting in normal MDF but even at 24000 rpm and a medium feed it was tearing out. Had to sand back very carefully with superfine paper avoiding the very shallow mortar grooves. Would like to find some board with a finer surface.
Rod Ashton | 20/01/2020 10:42:59 |
344 forum posts 12 photos | Have applied for a sample of Valchromat and contacted Trespar. They are not cheap sadly I am! |
Michael Gilligan | 20/01/2020 10:47:39 |
![]() 23121 forum posts 1360 photos | Thanks for the clarification, Ron [ you have the tools, but you need a suitable board to work with ] It’s a big step-up in price, but Traffolyte or similar would seem to be the obvious choice. https://en.wikipedia.org/wiki/Traffolyte Millions of Signs, Labels and Dog-Tags have been made from it. MichaelG. . https://traffolyte.com/traffolyte-sheet-material/
Edited By Michael Gilligan on 20/01/2020 10:53:35 |
Martin Kyte | 20/01/2020 10:58:29 |
![]() 3445 forum posts 62 photos | My apologies for not reading your original post correctly. I though you wanted to build a CNC router and were looking for framing material. You can probably forget trespar for the brick material. It's essentially a modern version of tuffnell and used for Lab benches etc. It's very rigid, can be machined with wood cutting machines and very flat. Ideal for building small machines, router tables etc. regards Martin |
John Haine | 20/01/2020 11:36:49 |
5563 forum posts 322 photos | I've vgot quite a lot of Valchromat bits, black and blue. I could spare some, how much do you need? You might also try this stuff on MDF to seal the surface before milling. It gets soaked up like rain in the desert into MDF, apply several coats (outside) and allow to dry thoroughly. Binds the fibres together in a resin matrix. Edited By John Haine on 20/01/2020 11:52:33 |
JasonB | 20/01/2020 12:58:31 |
![]() 25215 forum posts 3105 photos 1 articles | one of the PU model/tooling boards that are used to make patterns from may be an option and should not be as fluffy as MDF Though you don't say what grade of MDF you used as there are specific ones for routing that have a denser surface layer. This is a pattern cut from PU board Edited By JasonB on 20/01/2020 12:59:00 |
Rod Ashton | 20/01/2020 13:11:45 |
344 forum posts 12 photos | Thank you guys. I am exploring all recommended options. John I would need max 10"x12" or anything smaller. The hardener suggestion is very interesting I am obliged to you.
Rod Ashton | 20/01/2020 13:14:06 |
344 forum posts 12 photos | Seem`s the PU modelling board is minimum 50mm thick. Seeking something around 4/6mm |
John Haine | 20/01/2020 14:04:15 |
5563 forum posts 322 photos | Rod, have PM'd you. |
vic francis | 10/04/2020 15:48:12 |
125 forum posts 21 photos | Hi if you can locate someone with a laser engraver, it gave super results when I used one for detailing brickwork and mortar, ok it was in 1/8 scale, but I was able to do the same for loco shed gwr )windows using acrylic , it was also super quick as well ... err i even reproduced a few cracked panes ... bah vandals! The mortar line is also much finer than vee cutter.... regards vic |
