terry callaghan | 19/01/2020 15:20:45 |
237 forum posts 10 photos | hi chaps, today I took out a battery locomotive I am trying to sort out. I have fitted a 750w motor which works well. However the old bevel gears which look like they came from an old hand drill make a lot of noise and have a lot of wear. Can anyone please let me know of a company that I can purchase new gears from. Also is it normal for bevel gears to make a sort of rumble noise when in use, which is a bit to noisy for my liking. Thanks |
larry phelan 1 | 19/01/2020 15:30:37 |
1346 forum posts 15 photos | I think I saw such gears offered by a supplier called Belts-on-line. They offered all sorts of gears in many different sizes. Might be worth a try. |
JasonB | 19/01/2020 16:04:00 |
![]() 25215 forum posts 3105 photos 1 articles | It's actually belting online they are quite reasonably priced and gears will be fine for your use. |
not done it yet | 19/01/2020 17:25:06 |
7517 forum posts 20 photos | Another that might be worth checking out? HPC Gears. **LINK** Edited By not done it yet on 19/01/2020 17:25:53 |
Neil Wyatt | 19/01/2020 17:30:12 |
![]() 19226 forum posts 749 photos 86 articles | Posted by terry callaghan on 19/01/2020 15:20:45:
hi chaps, today I took out a battery locomotive I am trying to sort out. I have fitted a 750w motor which works well. However the old bevel gears which look like they came from an old hand drill make a lot of noise and have a lot of wear. Can anyone please let me know of a company that I can purchase new gears from. Also is it normal for bevel gears to make a sort of rumble noise when in use, which is a bit to noisy for my liking. Thanks Depending on size, replacement angle grinder ones are helical bevel gears and stupidly cheap, and although most angle grinders 'shriek' they are pretty quiet at loco-driving speeds. Neil |
noel shelley | 19/01/2020 18:20:21 |
2308 forum posts 33 photos | Duval stock gears ! A vast stock. Noel |
larry phelan 1 | 20/01/2020 14:43:02 |
1346 forum posts 15 photos | Thank you Jason, I stand corrected ! and you are right, they are quite good for price and range. |
