Chris TickTock | 31/12/2019 15:35:10 |
622 forum posts 46 photos | Hi Guys, I thought I would try to make a small precision graver for making very fine undercuts on my Sherline lathe. So I cafeully set up my 4 jaw chuck for the first time and drilled a 1/4 inch mild steel bar with a 3mm bit after using a centre drill. i am sure to many of you more experienced it would come as no surprise that the 3mm tungsten carbide bar did not fit in its hole (too tight). The idea was to put a flat on the bar and use a small grub screw. This is to make a tiny very fine knife like cutter. Now obviously one way is to sacrfice the drill bit and use this to make the graver but is there another method such as using slightly oversized drill bits or emery papering the tungsten carbide?? Chris Well red faced having taken the square stock out of the lathe yes the bar fitted the hole. Obviously I was not holding the bar dead straight whilst trying it on the lathe. However rather than just editing out the post the question still is valid in terms of can you expect a 3mm hole and bar to fit and what tolerances must you have? for an application like this a good sliding fit is required as I may well have to replace the fragile engraver as it inevitably breaks during use. Chris Chris
Edited By Chris TickTock on 31/12/2019 15:47:00 |
Robert Atkinson 2 | 31/12/2019 15:41:28 |
![]() 1891 forum posts 37 photos | You could try heating the 1/4" bar to expand it and then let it shrink onto the carbide. Robert G8RPI. |
Brian Wood | 31/12/2019 15:43:26 |
2742 forum posts 39 photos | Chris, There are drill sets that increase in increments of 0.1 mm diameter that with care could open the female hole up to just snugly fit the cutter tip. Regards Brian |
Frances IoM | 31/12/2019 15:44:03 |
1395 forum posts 30 photos | to what 'precision' are you working - did you measure the carbide - did you ream the hole or just use a nominal 3mm drill (+ is the hole actually circular ?) - a useful measure for small holes is a set of drill blanks from the number sequence used in conjunction with your micrometer. |
Martin of Wick | 31/12/2019 15:50:00 |
258 forum posts 11 photos | 1 redrill leaning on the drill or try another make of drill (they are not all the same) if fails measure accurately carbide bar then - 2 use a 3.1mm (or larger drill to suit carbide tool) put a flat on the bar (as in grind with carbide (green grit) wheel I would suggest) You wont get very far using emery paper on carbide. |
Chris TickTock | 31/12/2019 15:50:07 |
622 forum posts 46 photos | Thanks Guys, I think the drill increments are worth noting. how many thou becomes too tight a press fit for small objects? Chris |
not done it yet | 31/12/2019 15:57:17 |
7517 forum posts 20 photos | Look up shrink fitting tolerances. That will provide some useful information, particularly if there are press-fit tolerances, too. If too slack, use loctite! |
JasonB | 31/12/2019 16:03:54 |
![]() 25215 forum posts 3105 photos 1 articles | A drilled hole usually comes out over size rather than undersize, what make of drill bits are you using? What does the carbide measure, you won't be the first to have bought 1/8" stock sold as 3mm One option is to grind the end of your rod at an oblique angle and then use that as a home made reamer to open the hole up to the required size. Then loctite the carbide in place, you won't get much of a thread in the 1.6mm wall left in your 1/4" bar for a grub screw. |
Martin of Wick | 31/12/2019 16:06:28 |
258 forum posts 11 photos | Try this link for table BS shaft tolerances - scroll to bottom to get descriptive chose the one you want and look up on clearance/diameter tables
Nick Hulme | 31/12/2019 16:29:21 |
750 forum posts 37 photos | You can sharpen one drill flute manually with a stone to give the tip slightly asymmetric geometry, this will then drill a slightly larger hole than a symmetrical grind. |
SillyOldDuffer | 31/12/2019 16:31:34 |
10668 forum posts 2415 photos | Posted by Chris TickTock on 31/12/2019 15:35:10: ...can you expect a 3mm hole and bar to fit and what tolerances must you have? for an application like this a good sliding fit is required as I may well have to replace the fragile engraver as it inevitably breaks during use. ...Q. Can you expect a drilled hole to fit? A. Not very well. Twist drills tend to produce slightly oversize holes, which conveniently is usually what's wanted for a sliding fit, perhaps fixed with Loctite. How much too big a twist drill cuts depends on several factors: how sharp it is, how closely the edges are equally ground, depth of hole, type of drill, the material and how much pressure the operator applies. All rather variable and out-of-control. If a hole must be exactly to size, it's drilled slightly small and then opened out with a reamer or bored. It's reaming / boring that provides tight control of hole sizes, not twist drills. There are various classes of fit, and I recall Machinery's Handbook taking 20 or 30 pages describing them all. That's for repeatable manufacturing. For ordinary workshop fitting purposes, by varying hole/shaft sizes slightly it's easy enough to arrange a:
Perhaps a clockmaker will comment please; my experience is with larger objects than clock parts and I wouldn't want to confuse Chris! Dave
Chris TickTock | 31/12/2019 16:37:34 |
622 forum posts 46 photos | Posted by JasonB on 31/12/2019 16:03:54:
A drilled hole usually comes out over size rather than undersize, what make of drill bits are you using? What does the carbide measure, you won't be the first to have bought 1/8" stock sold as 3mm One option is to grind the end of your rod at an oblique angle and then use that as a home made reamer to open the hole up to the required size. Then loctite the carbide in place, you won't get much of a thread in the 1.6mm wall left in your 1/4" bar for a grub screw. Like that idea Jason (reaming) Take your point on thin wall but might just try using a 2mm grub screw if they are available and your bang on the walls are 1.6mm and min thickness is usually at least 1 times the dia but its light use so possibly 2mm set screw. Chris Edited By Chris TickTock on 31/12/2019 16:52:55 |
Cornish Jack | 31/12/2019 17:05:00 |
1228 forum posts 172 photos | Jason's suggestion is the 'tried and true' method and for 'how-to' words and music look up D bits. To stay 'in-house', try http://www.stubmandrel.co.uk/workshop/29-d-bits rgds Bill |
JasonB | 31/12/2019 17:17:59 |
![]() 25215 forum posts 3105 photos 1 articles | I was not actually thinking of a D bit, more like this where you use it like a reamer, the top one is a bit too steep an angle Edited By JasonB on 31/12/2019 17:18:42 |
old mart | 31/12/2019 18:02:07 |
4655 forum posts 304 photos | You could hold the carbide tip in a chuck or collet and use a diamond file or lap to reduce the diameter slightly. I would go for a sliding fit and use Loctite or epoxy glue to secure it. A small flat would stop a hydraulic lock while assembling. |
Bazyle | 31/12/2019 18:18:48 |
![]() 6956 forum posts 229 photos | Just to complete the picture. As Jason mentioned drills are most notorious for drilling oversize especially when they are not sharpened symmetrically which always happens when done manually by those 'I don't need no stoopid drill sharpening jig' experts. Wood of course is another matter. There is a post on here somewhere from the late John Stephenson talking about how when he worked for a piano manufacturer he had to spend hours selecting drills to give the precise end result required, not even getting the same result from two drills of the 'same' size. |
Watford | 31/12/2019 21:31:51 |
![]() 142 forum posts 11 photos | Posted by Bazyle on 31/12/2019 18:18:48:
drills are most notorious for drilling oversize especially when they are not sharpened symmetrically which always happens when done manually by those 'I don't need no stoopid drill sharpening jig' experts. Not quite always Bazyle, there are a very few of us who were actually taught how to do this at the start of our apprenticeships. Having spent more than a solid week (45 hour week then) grinding drills from about inch and a half down to 1/16" one does sort of get a bit of a feel for it. Happily it is a bit like playing a musical instrument that once acquired the skill never leaves one, and sixty-seven years later I still have it. I can still remember the feeling when the instructor put a fresh-ground inch drill into a lathe and drilled a hole with it and to see the two identical spirals of swarf coming off the tip. We had made drill angle gauges from gauge plate and calibrated them with a vernier height gauge - I still have mine. I am set to wonder about some (most) of the so called apprenticeships today, and if such instruction and knowledge is passed on. Yes, I know that there are machines to do this particular task, but these are not always available at the time and place that a drill needs sorting. I doubt whether many are taught to file these days either, and again it is an extremely useful skill on occasion when other resources are not to hand. Perhaps there are not too many instructors any more??? So dear Baz I would prefer it if you did not call me 'stoopid' - - not too often anyway . Compliments of the season to you. Mike
Edited By Watford on 31/12/2019 21:34:50 |
