Noise Isolating Platform
Neil Wyatt10/12/2019 21:16:57
19226 forum posts
749 photos
86 articles
Over the years ME and MEW have carried various tips on isolating machinery to reduce noise.
I came across this great concept used by drummers - especially for playing electronic kits indoors on wooden floors, as youc an wear headphones but still need to reduce the floor noise.
With perhaps some simple adaptations it could be a great way to isolate a fairly hefty machine...
Howard Lewis10/12/2019 21:49:35
7227 forum posts
21 photos
I won't make the obvious comment about bit being a load of, but decoupling the source of vibration from the surroundings will reduce transmission greatly over a wide range of frequencies.
A very nice solution, using easily obtainable materials.
Just wonder how many would be needed for a 300Kg machine? i e what is the load bearing capacity of a tennis ball
Mark Rand10/12/2019 23:24:37
1505 forum posts
56 photos
To be honest, I'd just get anti-vibration mounts from WDS Ltd. The same as I did for the wall mounted speakers, wall mounted transformers and wall mounted dust extractor in the shed...
Daithi24/01/2020 22:52:37
9 forum posts
Might work very well for a compressor housing?
Mike Poole25/01/2020 00:44:48
3676 forum posts
82 photos
On a smaller scale squash balls can be used to isolate a platform.
M8ke
I.M. OUTAHERE25/01/2020 03:20:15
1468 forum posts
I watched this a few days ago and thought the idea was interesting
Forward to around 1minute 45 second mark .
https://www.youtube.com/watch?v=xpi7L2po_VM&feature=share
Ed Duffner25/01/2020 05:11:13
863 forum posts
104 photos
I have 20mm thick or so rubber strips under my milling machine (WM-16) stand and also between the stand and mill. I believe it does reduce noise but I think it introduces bounce when interrupted cuts are taken, similar to flexing of the column.
The rubber was apparently an experimmental one used where my Brother used to work in the 80's, for a test on heavy grinders.
Ed.
HOWARDT25/01/2020 07:24:04
1081 forum posts
39 photos
Isolation mounts are available in all sorts of forms, from simple rubber feet or pads to bonded metal and rubber types. Used to use a fair few in machine builds for reducing harmonic vibration in drive motors.
