Roger King 1 | 05/11/2019 14:16:45 |
38 forum posts 2 photos | Had a very successful weekend - Daz and Pete came down from Nott'num and spent 4 hours going right through my newly-purchased Super 7, which was an education in itself. The first thing Daz did was wind the topslide out of the way and say, 'yep, it's one of mine' - recognizing his own scraping on the slide from 1980. He pronounced it a very nice example, which has had little use and needed nothing replacing apart from the spindle wick and the bed scraper felt. Even the tailstock height was within a thou. So - now I'm ready to start using it more. Question one: what is the best type of cutting tool to use, and where's the best place to get them? I have a few of Dad's old HSS ones, and a box of things somebody sold him with small trapezoidal screw-in tips, which he didn't like at all, and I've not had much luck with, either. Nearly all of my work is with mild steel. All suggestions welcome! |
Brian Oldford | 05/11/2019 14:30:14 |
![]() 686 forum posts 18 photos | Do you have their contact details please?
Roger King 1 | 05/11/2019 14:49:47 |
38 forum posts 2 photos | They've not changed: Darren Boden - [email protected] 07790 364189 |
Lainchy | 05/11/2019 15:18:47 |
![]() 273 forum posts 103 photos | My experience (albeit very little as a noob) is the insert tools are great for roughing out, but for finishing and fine cuts, a nice sharp, well ground HSS tool bit is miles better. |
John Haine | 05/11/2019 15:53:02 |
5563 forum posts 322 photos | I use mainly insert tipped carbide for general turning and boring, and a Diamond Tool holder with HSS bit when I fancy a change. Also a TC insert parting tool. Modern tipped tools work well and give a good finish if you keep the speed up - that includes for parting too. What do you mean by "mild steel"? Quite a lot of stuff that goes by that description never seems to turn to a good finish. |
Roger King 1 | 05/11/2019 16:12:20 |
38 forum posts 2 photos | Thanks - where's the best place to buy HSS bits? By 'mild steel', I mean the stuff outlets like Metals4U sell as 'bright mild steel'. Probably not best quality, I'm guessing. |
Howard Lewis | 05/11/2019 16:18:04 |
7227 forum posts 21 photos | A Super 7 is barely going to be fast or rigid enough to use carbide tips to their maximum. Wait for the howls! HSS will work quite well. A Tangential Turing tool (Such as the Diamond tool sold commercially - There have been at least two shop made examples in articles in MEW ) will work extremely well. The toolbit is HSS, and once you have made a Centre Height Gauge, setting the tool to centre height is an absolute doddle. Grinding is the same, since there is only one face to grind, rather than three on the normal knife tool. The only thing that you can't use it for is boring! Howard |
SillyOldDuffer | 05/11/2019 16:53:54 |
10668 forum posts 2415 photos | Posted by Roger King 1 on 05/11/2019 16:12:20:
Thanks - where's the best place to buy HSS bits? By 'mild steel', I mean the stuff outlets like Metals4U sell as 'bright mild steel'. Probably not best quality, I'm guessing. Nothing to do with 'quality', but ordinary mild-steel is a structural steel, not bad but not particularly good for machining. You can do better. When buying metal look at what the specification has to say about machinability. Of the mild-steels EN1A is about twice as machinable as ordinary mild-steel, and EN1A Pb is roughly three times better. More broadly, something like EN9 is about 3 times harder to machine than mild-steel, and many stainless steels are evil. Bright mild-steel is useful when the stock being finished off the shelf saves time by reducing the need to machine it. Otherwise Black mild-steel is the same composition, but has slightly different physical properties due to not being processed further to make BMS. It's cheaper and has fewer locked in strains to cause warping when cut. Given there's at least a 3:1 range in the machinability of metals that might be called "mild-steel", and even more problems across the full family of steels, my advice is to avoid unknown scrap. Painful experience taught me it's a bad mistake to assume a lathe or milling machine will happily cut any old metal! My HSS mostly came from ArcEuroTrade. It's fine. Enjoy your Myford! Dave PS. Personally, I think it extremely unlikely that steel made in the past can be better than the same steel made today. Not least because Metallurgy is better understood today and steel makers generally have more advanced plant. Rose-tinted glasses apart, anyone own 1970 TV that's better than a new one? |
Michael Gilligan | 05/11/2019 17:59:22 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 05/11/2019 16:53:54:
[…] PS. Personally, I think it extremely unlikely that steel made in the past can be better than the same steel made today. Not least because Metallurgy is better understood today and steel makers generally have more advanced plant. Rose-tinted glasses apart […]
. I think I must disagree, Dave [depending of course upon where on the timeline we choose to put “in the past”] ... Modern ‘general purpose’ steels will inevitably contain significant percentages [no, I don’t know the numbers] of recycled material of variable origin. Whilst I have no doubt that the best modern material is more tightly specified than in days of yore ... the general purpose stuff is probably getting progressively worse. MichaelG. . Edit: I’ve just found some ‘bedtime reading’ ... if either of us is up to it. Edited By Michael Gilligan on 05/11/2019 18:10:07 |
Neil Wyatt | 05/11/2019 18:20:54 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Howard Lewis on 05/11/2019 16:18:04:
A Super 7 is barely going to be fast or rigid enough to use carbide tips to their maximum. Wait for the howls! HOWL! Just down to the choice of tool. Any carbide tool that works with a mini lathe (and there are plenty) will be fine on a S7. Neil |
not done it yet | 05/11/2019 19:05:19 |
7517 forum posts 20 photos | Can this model not run to excess of 2000rpm? Plenty fast enough for carbide on most diameters. Perhaps not on much less than 10mm with cheaper inserts.? Maximum efficiency may not be attainable, but let’s face it - it is not a commercial machine (for high production rates. Motor power might be a large factor in not being able to ‘maximise’ some of these inserts, but there are other positive attributes, so no need to condemn them entirely. But, at the same time ‘barely’ does mean ‘just’ in my book, so not a total fail. |
Roderick Jenkins | 05/11/2019 19:48:39 |
![]() 2376 forum posts 800 photos | On my S7 I now use ccgt tips for 90% of my turning. The exceptions are rough interrupted cuts or large reductions in diameter. Rod |
Bazyle | 05/11/2019 21:14:10 |
![]() 6956 forum posts 229 photos | Don't over-think it and get drawn into expensive tools until you have done a lot of reading round the subject. Talking about black iron is all very well but where do you get it outside some old stockists in the midlands. Most of the ME suppliers only stock mild steel of undefined type. |
IanT | 05/11/2019 23:21:50 |
2147 forum posts 222 photos | Hi Roger, Your Super 7 sounds in much better condition than mine - and I use both Insert & HSS on mine with no problems. Everyone here has their own personal experience and preferences - so you will often get apparently contradictory advice. I use my Eccentric tool holder (on the S7) for a lot of my ferrous work and it's very easy/simple to keep the tool sharp. I use insert tooling for parting, boring and screw-cutting (all things where tool grinding can be tricky) but HSS (and indeed carbon steel) for just about everything else especially non-ferrous work. The best advice I can give you with respect to using HSS is to use small tool sections (I use 3/16th square) as it is much easier to shape and keep sharp than larger sections (1/8th is even easier but 3/16th is a bit stiffer). I used to use small section HSS only on my smaller lathes and "bigger" stuff (1/4" upwards) on the Super 7. I now have 3/16 tools set up in simple steel blocks and regularly use them on the S7 as well as my shapers (also in suitable holders). Most of my work is on the small side by the way but not all of it... Which brings me to my final point. Everyone here has different interests and needs. Someone building 6" scale traction engines or repairing cars will have a different view of things from someone making clocks. So your Super 7 will be viewed as a (very expensive) 'baby' lathe by some and the height of luxury by others... Anyway, I'm more than a bit jealous to hear your S7 is in such nice shape - I wish mine was as good. Maybe it will be one day... Regards, IanT |
Nigel McBurney 1 | 06/11/2019 09:50:18 |
![]() 1101 forum posts 3 photos | The S7 was designed in the early 1950s when the world used Hss tools and learned to grind them correctly,their performance was more than satisfactory ,never saw carbide tools on small lathes,when machining fine work Hss tools cut accurately with fine finish,and are a lot cheaper than carbide tips and HSS can be ground easily into any shape or form. Using high speeds with carbide will cause higher wear on a small lathe,remember you are not earning a living so why thrash the lathe to death. On my Colchester I use carbide tips on stainless steel,long roughing runs on steel and finish off with HSS tips also have efficient chip breakers which reduces the large amounts of curly swarf.most of my turning is with HSS.I do have a set of Myford brazed on carbide tools ,purchased in good condition cheaply,I use these when roughing out ,iron sand castings and non ferrous sand castings,as these can ruin the cutting edge of HSS tools.and I also keep the lathe bed clean as the swarf from castings can abrade the bed. I feel that there is a tendency to use carbide tip tooling as a lot of lathe users do not know how to grind and sharpen HS,just take a look at some of the second hand hss bits on auto jumble stalls,the previous owners must have clueless when grinding these tools.. |
Roger King 1 | 06/11/2019 10:09:26 |
38 forum posts 2 photos | Thanks to all for all the really helpful advice. I think for now I will stick with the HSS, as that's what I am familiar with on Dad's old ML10 (although by no means an experienced machinist!). Like everything it's practice, practice - and I will search out a good guide on sharpening. I have a couple of Myford-specific books, and a list of a few more to get. I also need to do a bit of thinking around what metal I use and the above advice will help with that too. Sorry to make you green, Ian! |
Andrew Johnston | 06/11/2019 11:10:39 |
![]() 7061 forum posts 719 photos | Posted by SillyOldDuffer on 05/11/2019 16:53:54:
Rose-tinted glasses apart, anyone own 1970 TV that's better than a new one? No, but as the quality of the picture has gone up, the quality of the programmes has gone down. Sure doesn't run into the Shannon-Hartley law limitations. On the plus side it means I spend more time in the workshop rather than on the couch. As SoD hints, of the low carbon steels En1A turns very well and the leaded version, EN1APb is even better. However EN3B has a propensity to tear and needs some experimentation to get a good finish. I use a lot of EN3B as most hot rolled steel is essentially EN3B, and is cheaper than cold drawn. I also find that EN1A rusts easily, often overnight, whereas EN3B is much less prone, even in a damp environment, like a kitchen. Andrew |
Michael Gilligan | 06/11/2019 11:18:55 |
![]() 23121 forum posts 1360 photos | |
Vic | 06/11/2019 12:42:05 |
3453 forum posts 23 photos | I use a Tangential tool for much of my turning and inserts for specific jobs. I particularly like the polished inserts and find they work really well on my little 8 x 14 lathe. I gave up using insert parting tools as I found the tips didn’t last long so I use the T shape HSS parting blades as they’re far more economical. |
Roger King 1 | 06/11/2019 13:28:54 |
38 forum posts 2 photos | OK, I've googled 'tangential tool' and discovered that it's one that basically points upwards. What's the advantage of this over a horizontal tool? |
