engine tightness
Philip Burley12/10/2019 09:26:02
198 forum posts
Hello , I have built a ST no I engine , 2 in X 2 in, Thing is , how tight should it be ? It turns over , but not freely . run it in on the lathe for half an hour and runs on air . It has home made iron rings . Previously made mill engine and a beam engine turn much more freely . . I just wondered if the piston fit or, the rings are too tight Can any one with a similar engine tell me how easily there's turns over
regards
John Purdy12/10/2019 18:37:11
431 forum posts
252 photos
Philip
I have just completed a ST#1 (see my post of 21 Aug. in the "work in progress" thread) and it turns over with some drag which I put down to the ring friction in the bore, but I wouldn't call it tight. It uses the supplied ST rings and are fitted with an approximate 3-4 thou gap. During initial testing I assembled it without the rings and it that state it just spun over easily and if the flywheel was given a good spin it would coast for 2 or 3 revs. Try assembling yours without the rings and see how it goes, it may be just the ring to bore friction that is causing the tightness. How thick are your rings? The ones from ST in mine are .0955 thick, which are by all accounts considerably thicker than optimal. The wall pressure may be higher than optimal. I found that I could remove the rings without disassembling the whole top end by removing the the top cover, and with the piston at TDC the nut could be undone and the top half of the piston unscrewed. Lowering the crank to BDC then left the rings in the top of the cyl. and could be removed. With the crank back up at TDC the piston could the be re-assembled. I must have done this a half dozen times!
Edited By John Purdy on 12/10/2019 18:40:52
JasonB12/10/2019 19:26:42
Is your bore just the turned finish? honing will give a smoother bore with less initial friction but with still enough of a surface for the rings to bed into. A good oiling and running on air for a while will also help, just watch where the black oil coming out of the exhaust goes.
Neil Wyatt12/10/2019 19:28:01
19226 forum posts
749 photos
86 articles
Ring pressures for steam can be VASTLY lower than for IC engines.
Philip Burley13/10/2019 19:14:08
198 forum posts
my piston isn't made in 2 halves so not quite to easy to remove the rings to check it without the drag of them , but I will dismantle it and check . The bore wasn't lapped , but it has been run on the lathe for half an hour well oiled , Thing is , should the engine spin over a couple of turns , or is that expecting too much ? . It certainly wont at the moment . but it turns with a finger in the fly wheel , Not having anything to compare it to is the problem
regards
Philip Burley14/10/2019 11:50:41
198 forum posts
I think I am worrying too much !! after all it works , so cant be much too tight , its just the newness !!
regards
mark costello 114/10/2019 20:19:48
800 forum posts
16 photos
Why does steam get less ring pressure?
mark costello 114/10/2019 20:20:10
800 forum posts
16 photos
Why does steam get less ring pressure?                Please delete.
Edited By mark costello 1 on 14/10/2019 20:20:57
