Pultra 10mm Collet Blocks
Phil P | 05/09/2019 15:33:45 |
851 forum posts 206 photos | OK I know this is a long shot, but before I set to and make some, has anyone come across any commercially available ones. What I am talking about are the four and six sided blocks to hold collets, they are typically available for ER and 5C etc. Those are too bulky for my needs, and I would like a set to take my 10mm Pultra 1770 collets for doing really small work on the Boley jig borer. I have every imaginable size and shape of collet, so it makes sense to use them on more than one machine. Thanks Phil |
Michael Gilligan | 05/09/2019 17:19:34 |
![]() 23121 forum posts 1360 photos | I've seen nothing commercially available, recently, Phil A few years ago RDG did have a few 'bench' collet holders for 10mm Pultra collets, but I missed out Hearsay was that they were specials made for BAe, but I don't know for sure. If you do locate any, do please let me know. MichaelG.
Bazyle | 05/09/2019 18:03:55 |
![]() 6956 forum posts 229 photos | I've only ever heard of them for 5C. I kept suggesting to the late John Stevenson that he make some for 3C since there are so many of those collets around for Boxfords. 6, 8, 10mm sizes would also be logical developments of the theme. |
Phil P | 05/09/2019 18:19:34 |
851 forum posts 206 photos | As I suspected. The only thing I have managed to find is on this website, he calls it an upright collet holder but it is not really what I am after. Looks like I will be making my own then. Phil |
Michael Gilligan | 05/09/2019 23:04:05 |
![]() 23121 forum posts 1360 photos | Posted by Phil P on 05/09/2019 18:19:34:
As I suspected. The only thing I have managed to find is on this website, he calls it an upright collet holder but it is not really what I am after. . That's very similar to the one I mentioned ... useful, but not what you are looking for. You presumably want something more like the ones I pictured on this thread from 2017: https://www.model-engineer.co.uk/forums/postings.asp?th=131257&p=2 MichaelG.
Phil P | 05/09/2019 23:52:14 |
851 forum posts 206 photos | Yes Michael That's the sort of thing, in fact I have just this minute finished drawing a set up in Solidworks 3D CAD. Watch this space !! Phil |
Phil P | 06/09/2019 11:14:30 |
851 forum posts 206 photos | OK, if anyone is remotely interested, here are my Solidworks drawings in JPG format. Just bear in mind that I have not actually made them yet, so they may possibly change. The plan is to bore the 10mm collet hole and taper in the square and hexagon raw materials, then use a mandrel to hold them in the dividing head to finish the flats to size on the milling machine. Phil |
Michael Gilligan | 06/09/2019 11:18:18 |
![]() 23121 forum posts 1360 photos | Many thanks for sharing that, Phil MichaelG. |
JasonB | 06/09/2019 11:25:04 |
![]() 25215 forum posts 3105 photos 1 articles | The one thing I'm always wary of with the 5C blocks is that when you use them vertically they are stood on the end of the collet as it and the nut stick out the end, not a problem with ER blocks. I wonder if this could be avoided if the block were made a little longer and a recess cut for a "nut" that could be tightened with a two pinned spanner so nothing stuck out the back. Possibly make a second larger flanged nut too for when you want that to act as a stop as discussed previously in Michael's linked thread. |
Phil P | 06/09/2019 11:34:07 |
851 forum posts 206 photos | Jason Fair comment. I have made the nut so it is machined on both sides and also so that the collet cannot poke out of the end for that very reason. I did wonder about a recessed nut, but thought it over complicated the design. Phil |
Michael Gilligan | 06/09/2019 11:38:00 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 06/09/2019 11:25:04:
The one thing I'm always wary of with the 5C blocks is that when you use them vertically they are stood on the end of the collet as it and the nut stick out the end, not a problem with ER blocks. I wonder if this could be avoided if the block were made a little longer and a recess cut for a "nut" that could be tightened with a two pinned spanner so nothing stuck out the back. Possibly make a second larger flanged nut too for when you want that to act as a stop as discussed previously in Michael's linked thread. . [my emboldening] Jason: If you scroll down Phil's recently linked page: **LINK** http://www.wefalck.eu/mm/tools/attachments/attachments.html ... to 'Upright Collet Holder' You will see that's exactly what was done [albeit on a much smaller scale than 5C] MichaelG. |
malcolm hollins | 22/11/2021 16:34:43 |
38 forum posts 20 photos | Hi Phil I have some Pultra 10 collets so I am interested in making the collet blocks' The problem I have is getting the correct size taps to make the nuts for the collet. Could you give me the Tap size and where could I get the Taps from. Cheers Malcolm |
david bennett 8 | 22/11/2021 20:41:58 |
245 forum posts 19 photos | Posted by malcolm hollins on 22/11/2021 16:34:43:
Hi Phil I have some Pultra 10 collets so I am interested in making the collet blocks' The problem I have is getting the correct size taps to make the nuts for the collet. Could you give me the Tap size and where could I get the Taps from. Cheers Malcolm Be careful here. Pultra 10mm collets are not the same as Pultra10 collets, which are probably 8mm collets.
JasonB | 22/11/2021 20:53:41 |
![]() 25215 forum posts 3105 photos 1 articles | If you are making the same as Phil's then the thread size is on the drawing . M10 x 1 which is quite common as it is a spark plug thread The 8mm collets have a thread 0.268" dia x 40tpi, I think I have seen this size tap somewhere as several collets use the thread. Shouldalso be able to single point them on the lathe with a small tool. |
Colin D | 19/06/2022 06:27:48 |
22 forum posts 12 photos | Phil P -- thanks for posting your excellent and very clear drawings. I am thinking of making a pair of these collet blocks, and maybe a third one in a cylindrical form. Can I ask - did you make them, and did you make any changes that were advantageous? I was thinking of using Jason's idea of making recessed nuts, for instance. Thanks Colin |
bernard towers | 19/06/2022 08:04:38 |
1221 forum posts 161 photos | I am in the process of making some er16 blocks so they can be used in the sherline. My only complaint with my er25 blocks is that I find them a bit on the short side a problem I hope to get over when doing the er16 version. |
