petro1head | 29/07/2019 12:44:12 |
![]() 984 forum posts 207 photos | Is there any way to stop getting a lip when parting off |
Phil P | 29/07/2019 12:56:13 |
851 forum posts 206 photos | Yes, you can grind the nose of your perting tool so it has a very slight angle to it. That way the leading edge will break through first. You will then leave the lip behind on the parent bar. And then follow through with the cut to remove it. Phil |
petro1head | 29/07/2019 13:04:32 |
![]() 984 forum posts 207 photos | Ah right, thanks I use index tools so I think I will not be able to grind it |
JasonB | 29/07/2019 13:07:40 |
![]() 25215 forum posts 3105 photos 1 articles | You can buy left hand, neutral and right hand inserts, expect you have neutral (GTN) so get the others GTL or GTR depending on what side you want a cleaner parting cut. Just be aware that if you have a lot of the holder extended then the angled cutting edge can throw the blade off to one side.
Edited By JasonB on 29/07/2019 13:09:52 |
petro1head | 29/07/2019 13:33:24 |
![]() 984 forum posts 207 photos | I managed to gring an angle on a tip. Works a treat. This is just for parting delron Thanks Edited By petro1head on 29/07/2019 13:33:43 |
mechman48 | 30/07/2019 08:39:04 |
![]() 2947 forum posts 468 photos | I have a HSS one specifically ground as Phil P mentions, works a treat on all jobs / material. I also use an insert tip tool, 2mm for majority of jobs and a small grooving tool 1mm tip that I ground up on a small 8mm HSS piece of tool steel. George. |
Howard Lewis | 30/07/2019 13:21:55 |
7227 forum posts 21 photos | I grind my parting tool at a slight angle. The advantage is that the back of the work should be free of a pip or "sleeve". But it does impose a sideways force on the tool, and the swarf is wider than the groove that is being made. This can lead to swarf jamming., and dig ins With the tool mounted inverted in a back toolpost, this is less of a problem, as the swarf tends to fall downwards. Howard |
AdrianR | 30/07/2019 15:43:41 |
613 forum posts 39 photos | This is a good video about parting tools, **LINK** I find all Joe's videos worth watching |
