Wire for connecting electronic components
Speedy Builder5 | 06/04/2019 10:40:53 |
2878 forum posts 248 photos | Many years ago - well, nearly 40 years ago, we used a fine solid copper wire which was insulated to make connections on 'Spot board'. There was no need to strip the insulation off when soldering as the heat of the solder melted the insulation and didn't seem to upset the solder joint to a component. Anyone know what it is called and can you still get it ? BobH |
not done it yet | 06/04/2019 11:03:01 |
7517 forum posts 20 photos | Were ‘bread boards’ not just plug in as temporary circuit arrangements? The insulation would not pass through veroboard holes, where the conductors were soldered on the back side of the board. Never came across a ‘spot’ board. What did I miss? |
peak4 | 06/04/2019 11:06:18 |
![]() 2207 forum posts 210 photos | Try "Solderable enamelled coper wire". for instance this one from Farnell
Bill |
John Haine | 06/04/2019 12:05:09 |
5563 forum posts 322 photos | Note that it needs a very hot iron to self-flux. If you have a variable temp iron remember to turn the temp down afterwards as excessive temperature seems to kill bits. |
Mike Crossfield | 06/04/2019 12:13:09 |
286 forum posts 36 photos | A search for “self bonding copper wire” will give you dozens of hits. Many self bonding enamelled wires are directly solderable. |
Georgineer | 06/04/2019 12:19:22 |
652 forum posts 33 photos | I forget the name of it, but the stuff we used in the seventies gave off toluene di-isocyanates (TDIs) when heated, which could cause lung sensitisation and breathing problems. I hope the new solder-through insulations don't do things like that. Mind you, the resin flux (colophony) wasn't very lung-friendly either. I look back in amazement at the perpetual fog in the wiring shop and think of the effect it must have had on the wiremen and women who were in it all day, every day. George |
larry phelan 1 | 06/04/2019 19:11:41 |
1346 forum posts 15 photos | Might explain why some of us have breathing problems now !! Workshop conditions in those far off "happy" days were far from ideal. H&S ? Who are they ? |
Mike Poole | 06/04/2019 20:13:06 |
![]() 3676 forum posts 82 photos | Kynar was a wire I have used that could be soldered without stripping. Mike |
Boiler Bri | 06/04/2019 20:21:50 |
![]() 856 forum posts 212 photos | I think these days wire strippers are very advanced and do the job so well. No need to poison yourself just get a good set of strippers.
Bri |
JC54 | 06/04/2019 20:27:29 |
![]() 154 forum posts 14 photos | Posted by Boiler Bri on 06/04/2019 20:21:50:
Bri I think the wife might complain.. |
Speedy Builder5 | 06/04/2019 20:59:28 |
2878 forum posts 248 photos | Thanks guys, found small reels on A bay at an acceptable price. BobH |
Bazyle | 06/04/2019 22:53:27 |
![]() 6956 forum posts 229 photos | I knew it a Verowire. I wonder how long the insulation lasts as I still have some. |
Rik Shaw | 07/04/2019 09:25:19 |
![]() 1494 forum posts 403 photos | I have not used my breadboard in thirty years since I made my first metal detector. I used to strip the thin multi coloured wires from telephone cable and solder a Veropin on each end - very handy those colours when identifying what goes where! Rik |
