Stress Relieving Rolled Mild Steel
Stewart Hart05/04/2019 08:17:16
674 forum posts
357 photos
I want to machine a part from cold rolled mild steel bar from experience I know that the part will warp out of square and this would be a no no, also for what I have in mind hot rolled bar would not be suitable
So has any one tried stress relieving rolled mild steel bar?. I thought about sticking it in the oven but our ovens max temp is 240 C I don't think this will be hot enough as far as I can find out you stress relieve at around 600 - 700 C I,ve also considered putting it into a barbeque but that would be a bit hit and miss.and I don't want to scale the bar
My other option would be to rough the part out and let it sit for a week or two to let the stresses work on to part, then to finish machine it but I'm unsure if this will be effective enough.
Any ideas views enlightened
Stew
Nicholas Farr05/04/2019 08:55:59
3988 forum posts
1799 photos
Hi Stewart, this graph shows heat treatment ranges if it is of any help.
Regards Nick.
Tony Pratt 105/04/2019 09:04:54
2319 forum posts
13 photos
600 deg C is about the right temp for stress relieving mild steel so the oven is out, barbeque will do it but not sure how you monitor the actual temperature?
To prevent scaling the part can be placed in an airtight tin or wrapped in stainless steel foil with something combustible to burn off the oxygen.
Tony
Stewart Hart05/04/2019 09:05:58
674 forum posts
357 photos
Hi Nick
Thanks for the useful graph, as I thought it shows the temp for stress relieving to be around 600 C our oven won't be hot enough.
Cheers
Stew
Stewart Hart05/04/2019 09:11:24
674 forum posts
357 photos
Thanks Tony
The trick with the air tight tin/foil would do the trick to prevent scale, thanks for the tip
I have enough bar to have a couple of tries so I think I'll try rough machining first to see how much it warps.
Stew
JohnF05/04/2019 09:40:30
1243 forum posts
202 photos
Stewart, take a skim off all round the bar and you will find warpage will be minimised, stress reliving is of course better but you do need to achieve the correct temperature. Depends on size of the job and the tolerance you wish or need to achieve.
There is heaps of info on the net if you look but 600 to 650 deg C is about right for steel.
How big is the piece and where are you?
IanT05/04/2019 09:41:31
2147 forum posts
222 photos
Stewart,
Mentioned this recently on another thread - but don't be tempted to use kitchen foil - it will melt.
I know!
IanT
Hopper05/04/2019 09:47:41
7881 forum posts
397 photos
Ask your steel supplier about buying normalized cold rolled bar. The makers do the faffing about with torches/furnaces for you.
IanT05/04/2019 10:00:17
2147 forum posts
222 photos
There was a thread about cast iron 'chill' - and it's treatment recently Stewart. Not the same problem I know but perhaps a similar solution.
https://www.model-engineer.co.uk/forums/postings.asp?th=138364
I've placed both suspect castings and mild steel in my incinerator overnight to help with these things. I won't repeat everything again (as it's all in the previous thread) but I do feel it helps.... but I would also do a wee bit of roughing first too
IanT
Stewart Hart05/04/2019 10:00:30
674 forum posts
357 photos
Thanks for your input chaps
the part is 1”x5/8x21/2” with the middle bit removed so it’ll bend like a banana putting the ends out of square which I want to avoid
I’ll see what roughing it out first does to it I may be able to live with the results
cheers
Stew
John Olsen05/04/2019 10:33:49
1294 forum posts
108 photos
I would get out the propane torch and heat it up to a good red heat, keep it there for a while, and then let it cool as slowly as possible. A few chunks of firebricks around it to make a rudimentary furnace would help keep the drafts off. There will be some scale but not as much as with the old way of putting it in the embers of the fire overnight. There is very little danger of accidently getting it too hot, you won't melt it with anything you are likely to have at home.
If you don't have a propane torch, it is a really worthwhile thing to acquire, since you can also use it to harden bits of silver steel, or drill rod if you like. (or gauge plate.)
Ian S C06/04/2019 12:36:35
7468 forum posts
230 photos
After heating, the quench should be quick and for a rod or bar it should go in vertically, put it in sideways and you have a fair chance of getting a bend in the article.
Ian S C
Andrew Tinsley06/04/2019 12:44:20
1817 forum posts
Hello Ian, I thought that treatment was for hardening? Do you not want a slow cooling for stress relief? Quite happy to be shot down over this as the memory is not too sharp these days.
Andrew.
IanT06/04/2019 13:12:36
2147 forum posts
222 photos
That's right as far as I know Andrew (other Ian here)
My incinerator treatment builds up a deep ash bed and the bits inside are still very hot even 12-15 hours after the night before. I leave them there until I tip the whole lot out. So fairly prolonged high heat, followed by a slow cool. Not too scientifically controlled in my case perhaps - but I don't have the equipment to do anything else...
IanT
