ChrisH | 29/03/2019 11:22:55 |
1023 forum posts 30 photos | Does anyone know anything about non-drip gloss paints? Chris |
Emgee | 29/03/2019 11:26:19 |
2610 forum posts 312 photos | Chris, best advice I can offer is bin it. Emgee |
Brian Oldford | 29/03/2019 12:15:12 |
![]() 686 forum posts 18 photos | I'd bin it anyway. I can never get a good finish from non-drip paints.
SillyOldDuffer | 29/03/2019 12:22:59 |
10668 forum posts 2415 photos | Paint is a subject as wide as it is broad! However, most paints have a shelf-life and delicate storage requirements. If you stir a non-drip paint it becomes an ordinary paint and will drip with the best of them. Generally chemical products that quietly change state when used don't store well. Glue, Paint, Varnish, Flux, Rubber etc all suffer from old age. Degraded paint may not brush, stick, harden properly, produce an acceptable finish, or last long. Your time is valuable - if the job matters, replace the paint. Dave |
ChrisH | 29/03/2019 12:46:18 |
1023 forum posts 30 photos | These replies generally reflect my thoughts! Suspected stirring a non-drip paint would turn it into an ordinary paint. Hate non-drip paints anyway, can't get on with them. Only kept this one because of the colour. It will likely get binned! Thanks all, Chris |
Andrew Johnston | 29/03/2019 13:01:55 |
![]() 7061 forum posts 719 photos | I don't see why stirring a non-drip paint should turn it into ordinary paint, at least not permanently? When non-drip paints first came out the buzz word was thixotropic, ie, the paint thins when subject to a time dependent shear. So when the paint is sheared by application with a brush it flows easily, but once the shear is removed it reverts to being viscous, so it doesn't drip or run. So if you stir a non-drip paint I'd expect it to thin, but don't see why it wouldn't thicken over time afterwards. In a wider sense non-drip paints are one type of non-Newtonian fluid, analysis of which involves tensors. I've got a tin of non-drip gloss at home, at least a year old and it worked fine when I used it a couple of weeks ago. In due course I'll have a look at the tin and see if it says anything about stirring. If nothing else I'm an expert at pot stirring. Andrew |
Harry Wilkes | 29/03/2019 13:08:27 |
![]() 1613 forum posts 72 photos | Opened a tin of satin finish on Tuesday with the liquid floating on top gave it a stir used it no prob H |
ChrisH | 29/03/2019 13:52:29 |
1023 forum posts 30 photos | I've noted over the years Andrew that you are very good at many things; stirring being one of your most amusing ones! |
SillyOldDuffer | 29/03/2019 14:15:56 |
10668 forum posts 2415 photos | Posted by ChrisH on 29/03/2019 13:52:29:
I've noted over the years Andrew that you are very good at many things; stirring being one of your most amusing ones! Good news - you're in the glorious position of being able to test what happens when you stir a pot of non-drip paint! If it thins permanently, I'm right. Otherwise Andrew scores a brownie point. Actually, stirring one tin of paint may not prove much. It's possible we're both right, depending on how the paint was made. Even so, experiment always beats theory. Reminds me I was going to comment on the thread asking about drilling ball bearings, where answers ranged from 'no problem with an ordinary HSS drill', to 'EDM'. Very contradictory. Actually, everyone was telling the truth - ball bearings come in a variety of hardnesses from softish steel up to harder than carbide. The softer ones can be drilled, the harder ones can't. Dave |
Former Member | 29/03/2019 14:56:37 |
1329 forum posts | [This posting has been removed] |
Dave Halford | 29/03/2019 16:33:34 |
2536 forum posts 24 photos | As Andrew has said above Non drip paints are thixotropic like tomato sauce, you can stir them and they go runny, let them stand for a while and they will revert back to nondrip again.
The brown oily stuff poured away was the resin that sets the solids normally suspended in it and imparts the gloss finish. When the solids settle like those described you need to stir them back in again. Pouring off the resin means the paint may remain forever tacky like anti climb paint even if you stir it all day. |
AdrianR | 29/03/2019 16:34:56 |
613 forum posts 39 photos | I stir non drip gloss to get a better finish. As long as it is not too hot/cold, you can get it so that it brushes on and spreads just enough to remove the brush strokes, then re-gels and stops the runs.
ChrisH | 29/03/2019 22:06:04 |
1023 forum posts 30 photos | Have stirred said tin this evening whilst in a "oh sod it " mood, will see what it's like tomorrow. If it was to be binned anyway not much to loose....... Chris |
Chris Trice | 29/03/2019 23:52:37 |
![]() 1376 forum posts 10 photos | Most paints separate over time since they consist of finely ground pigment mixed into a carrier base and one is usually heavier than the other. Can't think of any paint offhand that doesn't say shake or stir before use. |
duncan webster | 30/03/2019 00:40:05 |
5307 forum posts 83 photos | After years of resisting it the last decorating I did I used water based undercoat and gloss. Must say I'm impressed, goes on very easy and brushes clean very easy. Finish is acceptable, not up to coachpaint standard but it's only the bedroom woodwork. Edited By duncan webster on 30/03/2019 00:44:57 |
Andrew Johnston | 30/03/2019 11:08:58 |
![]() 7061 forum posts 719 photos | Oh dear, I've boo-boo'd, turns out my tin of gloss paint isn't non-drip at all. The instructions on the tin say stir thoroughly before use. Can't say I've noticed it dripping, but it's only been used for skirting boards, so you don't need a lot of paint on the brush. Having bought it about 18 months ago for the main bathroom refit I used it recently for the kitchen refit. This time around I didn't read the tin and came unstuck. I thought gloss paint, therefore white spirit for the brushes. Got it all set up and after painting dropped the brush in and it went 'orrid. The brushes can be washed in water even though it's a gloss paint. Andrew. |
pgk pgk | 30/03/2019 11:29:38 |
2661 forum posts 294 photos | << Can't think of any paint offhand that doesn't say shake or stir before use. >>
As someone who hates painting most of my woodwork is stained or varnished. The very limited gloss stuff I find best to do with modern water-based low odour paints and small gloss rollers for all but the edges - all of which I mask off with low-tack tapes so I can slap the stuff on and get it done.- finish is excellent. pgk |
Pat Bravery | 30/03/2019 13:26:25 |
![]() 96 forum posts 24 photos | Has anyone tried to get rid of a half full tin of paint at the local dump, ours in Caister will not take the tin unless it is completely empty. When I asked why all I got was a shrug of the shoulder, and I thought that it was a recycling centre, so what do we do with these tins, put them in the household rubbish? Pat |
Dave Halford | 30/03/2019 13:33:33 |
2536 forum posts 24 photos | Lowestoft dump is the same, would only take dried out tins. |
Nick Wheeler | 30/03/2019 16:46:01 |
1227 forum posts 101 photos | Stir a load of sand into the paint, and leave the lid off until it sets. |
