Peter Spink | 22/02/2019 20:01:56 |
![]() 126 forum posts 48 photos | Fed up with twiddling handle so have fancied one of these for some time: Any disadvantages e.g. lack of self eject? Possibility of mounting some sort of depth indicator?
Meunier | 22/02/2019 21:42:32 |
448 forum posts 8 photos | Peter, my ML7 has the Cowells rack-feed tailstock (already fitted when bought in 1973) and find it very useful. When drilling from tailstock it is easy to take 'pecks' and pull back to clear chips without twiddling handwheel and force applied is better sensed than with a wheel and possibly reduces drill breakages. With benefit of having used it, if starting from scratch today would (gulp - how much) still feel it was well worthwhile. From pics I've seen believe CornishJack/Bill has the same unit. Can't see if the Myford unit has graduated collar, mine has a resettable collar to show advance of quill in 1/8in increments. When ejecting 2MT inserts, just lock tailstock and quill and use a length of 1/4ins rod with a ball on the end and so far have not needed to resort to a hammer. |
Hopper | 22/02/2019 23:34:40 |
![]() 7881 forum posts 397 photos | There was a thread on here a while back about making your own lever-operated version that provides a similar result for a lot less money, if budget is an issue. Geoff Walker did an article about one in MEW a couple of years back with full drawings etc. Edited By Hopper on 22/02/2019 23:35:18 |
Ian Parkin | 23/02/2019 07:11:21 |
![]() 1174 forum posts 303 photos |
HasBean | 23/02/2019 10:27:53 |
141 forum posts 32 photos | I've had one for a few years now (bought from the 'old' Myford) and prefer it to the handwheel. Mine has a friction collar graduated in MM and sliding stop at the rear with a locking screw. It's a bit of a pain having to use a knocking bar to eject tooling, especially as I'm short of room to the right of the lathe, but I've been meaning to make up a combined drawbar/ejector to get over this (the bits for this are sitting on my bench, have been for four years Paul
Edited By HasBean on 23/02/2019 10:28:26 |
Georgineer | 23/02/2019 11:49:23 |
652 forum posts 33 photos | Having worked extensively with self-ejecting tailstocks, I regard them as a fiddly nuisance. My home lathe has a lever-operated tailstock, and a 'bopper' of mild steel rod with a lump at the end to give more mass, and stop it sliding right through. It's so much easier and quicker to use when changing tooling. George |
Nick Clarke 3 | 23/02/2019 14:17:20 |
![]() 1607 forum posts 69 photos | Posted by Georgineer on 23/02/2019 11:49:23:
Having worked extensively with self-ejecting tailstocks, I regard them as a fiddly nuisance. My home lathe has a lever-operated tailstock, and a 'bopper' of mild steel rod with a lump at the end to give more mass, and stop it sliding right through. It's so much easier and quicker to use when changing tooling. George Plus one for non self ejecting tailstocks. they can eject at the most inconveniently with a single moment's inattention and the next time you can't get the *******ing tool out no matter how hard it is wound back in. Worst thing for me is using lathes at home and in the club workshop which are all different, and if the ejector has moved a bit when you are just trying to get the last bit of a hole cleared by pulling the drill out - the scale on the tailstock spindle says it is ok, but no it isn't! Edited By Nick Clarke 3 on 23/02/2019 14:19:29 Edited By Nick Clarke 3 on 23/02/2019 14:20:53 |
Peter Spink | 23/02/2019 16:02:28 |
![]() 126 forum posts 48 photos | Thanks chaps for all your replies, my mind is made up and I have a birthday coming up! My tailstock taper is worn (probably because of self ejecting at the wrong moment), so was due for attention. Will need to break out the grey paint though 😄 |
martin perman | 23/02/2019 16:50:50 |
![]() 2095 forum posts 75 photos | Silly question gentlemen, Apart from replacing a thread with a rack you still have to twiddle a wheel to move it and surely a thread is a lot more accurate than a rack. Martin P |
Cornish Jack | 23/02/2019 18:03:14 |
1228 forum posts 172 photos | Meunier is quite correct - I do have one (Cowells) fitted to my ML7. Excellent as compared to the handwheel and bought it to replace a basic 'home-brew', made because I was fed-up with the original. rgds Bill |
Michael Gilligan | 23/02/2019 18:13:08 |
![]() 23121 forum posts 1360 photos | Posted by martin perman on 23/02/2019 16:50:50:
Silly question gentlemen, Apart from replacing a thread with a rack you still have to twiddle a wheel to move it and surely a thread is a lot more accurate than a rack. Martin P . But [assuming that you are using it as such] it's effectively a pillar drill lain on its back ... and you don't see many of those with a handwheel and screw thread. MichaelG.
Edited By Michael Gilligan on 23/02/2019 18:23:21 |
Hillclimber | 28/10/2019 18:18:16 |
![]() 215 forum posts 51 photos | Posted by HasBean on 23/02/2019 10:27:53:
Paul, have you completed that drawbar/ejector yet? And do you have any piccies/ drawings? I acquired one of these a couple of weeks ago. Spent 15 minutes fitting it this morning, and used it for its first job. My first thought was 'why did I not get one of these before'? The second was 'shame it doesn't self-eject, but upside is that it will take a drawbar'. And the final one was, 'I bet you could make a combined drawbar/ejector' - before remembering that google is my friend. So any and all help welcome with that design.....? Cheers, Colin |
Meunier | 28/10/2019 19:42:33 |
448 forum posts 8 photos | Posted by Peter Spink on 23/02/2019 16:02:28:
Thanks chaps for all your replies, my mind is made up and I have a birthday coming up!...../ Did you eventually treat yourself for your birthday Peter and, if so, what was your feedback ? |
Peter Spink | 28/10/2019 20:52:51 |
![]() 126 forum posts 48 photos | Hi Dave, Yes I did get one and very pleased with it - I too wish I'd bought one years ago. As regards extraction, so far I must admit to using lump of M12 studding as a rapping bar - crude but works until I get round to making something more sophisticated! Peter |
Rod Renshaw | 28/10/2019 21:12:48 |
438 forum posts 2 photos | I have one these ( same as HasBeans, except mine has 1/16" graduations) and I prefer it to the handwheel. I can estimate a depth to about 1/64" which seems accurate enough for drilling holes. The standard Myford handwheel tailstock has no graduations on the handwheel and the depth has to be estimated from the 1/8" graduations on the barrel itself. The other advantages are that the taper in the barrel is very easy to clean out and one can use a drawbar to secure collets and turrets in the tailstock. I have made a "bumper out" from a length of 1/2" steel bar with a brass tip on one end and a simple, but weighty, steel handle on the other. I keep this loose in the tailstock barrel and I don't miss the self-eject facility. The same bumper out is also useful in the headstock. Rod
HasBean | 29/10/2019 11:00:56 |
141 forum posts 32 photos | Hi Colin, I'm afraid not, the bits are still sitting on the bench. Work seems to be getting in the way of everything these days |
Hillclimber | 29/10/2019 11:53:46 |
![]() 215 forum posts 51 photos | Paul, I've been busy in the last few weeks finishing small projects that have equally been on or around my workbench, so I could get back to doing the things they were intended to help me with! If you have a sketched idea kicking around, it would be great to share. Otherwise expect to my thoughts next week or so.... Cheers, Colin |
