square file
Philip Burley | 21/02/2019 20:34:05 |
![]() 198 forum posts 1 photos | can anyone please recommend a supplier of a small tapered square file of decent quality ? I need to file a hole a bit less than 1/8 inch square regards Phil |
Michael Gilligan | 21/02/2019 20:47:22 |
![]() 23121 forum posts 1360 photos |
https://www.cooksongold.com/Jewellery-Tools/-Range=Files/-Size=0/-Type=0/-Brand=Vallorbe/-Font=0/&prdsearch=y&prdsearch=y&numperpage=25&pagenum=0&show=N&orderby=size&refurl=y Last two items on the page. MichaelG. |
Mike Crossfield | 21/02/2019 20:56:12 |
286 forum posts 36 photos | I’ve been very pleased with the Swiss pattern Tome Feteira needle files sold by Arc Euro Trade. Cheaper than Vallorbe, and good quality. Mike |
dcosta | 21/02/2019 23:04:42 |
496 forum posts 207 photos | Hello Mike, |
HOWARDT | 21/02/2019 23:09:42 |
1081 forum posts 39 photos | No he stated Swiss pattern not Swiss made, another option is USA pattern.
dcosta | 21/02/2019 23:24:09 |
496 forum posts 207 photos | Hello Howardt, |
Pete. | 22/02/2019 01:00:46 |
![]() 910 forum posts 303 photos | Have a look on amazon, Pferd is one of the brands they offer on Prime deals, there is currently one on there that I think is what you're looking for at £3.50 as an add on item meaning you need to spend £20 if you can find a few you want, you can get some at massively reduced prices, I've bought half a dozen pottance files for hardened material ranging from £2.70 to £10 these files retail at about £30 each. Best quality files I've ever used. |
Philip Burley | 22/02/2019 08:28:03 |
![]() 198 forum posts 1 photos | Thanks I will follow up some of those , Problem is the advertisers don't say what the sizes are , Regards |
Philip Burley | 22/02/2019 08:34:08 |
![]() 198 forum posts 1 photos | I have sent for the ARC one . see what that looks like Regards |
ega | 22/02/2019 11:45:12 |
2805 forum posts 219 photos | Peter F: Thanks for introducing me to the "pottance file". This seems to be a type of Swiss or toolmaker's file with the cut designated by a number and, as you suggest, harder than standard. In trying to chase this down I came across a reference to Peter Stubs' files being measured in French inches or "pouces" (longer than the English inch). |
roy entwistle | 22/02/2019 14:55:53 |
1716 forum posts | Just a point but if I was filing a square hole I would use a three square file ( triangular ) not a square one Roy |
Pete. | 22/02/2019 15:00:09 |
![]() 910 forum posts 303 photos | Posted by ega on 22/02/2019 11:45:12:
Peter F: Thanks for introducing me to the "pottance file". This seems to be a type of Swiss or toolmaker's file with the cut designated by a number and, as you suggest, harder than standard. In trying to chase this down I came across a reference to Peter Stubs' files being measured in French inches or "pouces" (longer than the English inch). Yes, they range 0 to 4, 4 being the finest, a #1 pottance is about the same as a normal fine file, and a #4 you can file your finger nails with its so fine. |
Michael Gilligan | 22/02/2019 16:51:25 |
![]() 23121 forum posts 1360 photos | Posted by roy entwistle on 22/02/2019 14:55:53:
Just a point but if I was filing a square hole I would use a three square file ( triangular ) not a square one Roy . Me too ... but that wasn't the question MichaelG. |
Russell Eberhardt | 23/02/2019 10:57:22 |
![]() 2785 forum posts 87 photos | Posted by ega on 22/02/2019 11:45:12:French inches or "pouces" (longer than the English inch).
That used to be the case many years ago but now the French pouce (thumb) is defined as 2.54 mm, exactly the same as the Imperial inch. Russell |
ega | 23/02/2019 11:25:30 |
2805 forum posts 219 photos | Posted by Russell Eberhardt on 23/02/2019 10:57:22:
That used to be the case many years ago but now the French pouce (thumb) is defined as 2.54 mm, exactly the same as the Imperial inch. Russell Thank you for pointing that out. My 1943 Machinery's Handbook gives the then metric equivalent of 25.4001 but, according to Wikipedia, " In 1930, the British Standards Institution adopted an inch of exactly 25.4 mm. " I remember having a discussion some years ago with an elderly relative who was a qualified engineer and having some difficulty in persuading him of your point. The difference must have been regarded as very slight and I think the use of a 127 tooth gear for metric pitches pre-dated harmonisation. |
Raymond Anderson | 23/02/2019 14:26:21 |
![]() 785 forum posts 152 photos | Agree with Peter F, Pferd are fantastic files. I have quite a few and some are years old and still cut very well even though they have seen a lot of use over the years. Top notch files |
Brian H | 23/02/2019 15:16:44 |
![]() 2312 forum posts 112 photos | Posted by Russell Eberhardt on 23/02/2019 10:57:22:
That used to be the case many years ago but now the French pouce (thumb) is defined as 2.54 mm, exactly the same as the Imperial inch. Russell Sorry to be a pedant but that should be 2.54 centimeters or 25.4 millimeters. Brian |
Russell Eberhardt | 23/02/2019 16:17:13 |
![]() 2785 forum posts 87 photos | Posted by Brian H on 23/02/2019 15:16:44:
Sorry to be a pedant but that should be 2.54 centimeters or 25.4 millimeters. Brian Oops! Russell |
ega | 23/02/2019 16:33:31 |
2805 forum posts 219 photos | Posted by Russell Eberhardt on 23/02/2019 16:17:13:
Sorry to be a pedant but that should be 2.54 centimeters or 25.4 millimeters. Brian Oops! Russell Oops all round. I shan't be pursuing a career in pharmacy! |
