Neil Wyatt | 10/01/2019 17:03:15 |
![]() 19226 forum posts 749 photos 86 articles | I've just had a telephone query about how to reverse a sewing machine motor. The issue is that the Ricca motor (YM260A-9) originally used by GHT for his pillar tool is no longer available, but plenty of people have had success using sewing machine motors with variable speed foot switches. The down side is that these require a crossed belt for a neat installation. The question I was asked is, are these motors easily reversible and if so, how, which would allow the use of a toothed or poly-v belt? I am sure a source for the original motor would also be of interest. Neil <edit> it seems the original motor 'number' is actually for a 1960s Singer sewing machine. Edited By Neil Wyatt on 10/01/2019 17:04:21 |
Joseph Noci 1 | 10/01/2019 17:17:14 |
1323 forum posts 1431 photos | Yes, reverse either the connections to the rotor ( brushes) OR the end connections to the field coil, as per any universal motor. Joe |
Keith Long | 10/01/2019 17:40:39 |
883 forum posts 11 photos | Most likely NOT reversible from experience. The motor that I bought in the last 3 years or so has offset brushes so is optimised for single direction operation. Also to get at the connections for the brushes or the coil would have needed some serious surgery to moulded plastic parts. The motors are sold as unidirectional but you can get either clockwise or anti clockwise versions. I sourced my motor from a sewing machine and spares supplier via EBay and bought the uprated (100 watt) version rather than the normal 60/70 watt type. |
Howard Lewis | 11/01/2019 12:42:50 |
7227 forum posts 21 photos | If anyone wants a sewing machine motor, with speed control pedal, PM me for how to come and collect from East Anglia. Howard |
Gerard Beattie | 27/06/2020 22:18:30 |
1 forum posts | I have a SEIG nano lathe with a sewing machine motor. The bushings went in the motor so I got a replacement motor , but the replacement motor was rorating in the wrong direction. So after trying to reverese the direction of the motor I got the idea to flip the motor over on its axis and the motor spins in the correct direction. The only problem with this method is that the motor had to be mounted out the side of the lathe,and I had to modify the mounting bracket , but it worked for me.This method might not work for everyone. If you do not understand what I mean by flipping over the motor I can post a photo the motor flipped over. |
Hopper | 28/06/2020 07:20:36 |
![]() 7881 forum posts 397 photos | GHT and co used sewing machine motors because thats all that was available. These days you are better off to search on Aliexpress for machine spindle, cnc router motor etc and a matching motor controller with reverse. This automation stuff is so commonly used in industry in China that prices are stupid cheap. You can have infinitely variable speed with reversing for the price of a couple of beers. |
Dave Halford | 28/06/2020 10:00:06 |
2536 forum posts 24 photos | Posted by Keith Long on 10/01/2019 17:40:39:
Most likely NOT reversible from experience. The motor that I bought in the last 3 years or so has offset brushes so is optimised for single direction operation. Also to get at the connections for the brushes or the coil would have needed some serious surgery to moulded plastic parts. The motors are sold as unidirectional but you can get either clockwise or anti clockwise versions. I sourced my motor from a sewing machine and spares supplier via EBay and bought the uprated (100 watt) version rather than the normal 60/70 watt type. Wonder if all they do is turn the brush carrier around? I have a 1/4hp brushed motor from the Great War that reverses by rotating the brush carrier. |
Roderick Jenkins | 28/06/2020 10:09:08 |
![]() 2376 forum posts 800 photos | These guys supply 120W motors that run in a clockwise direction **LINK**. I use one to drive a milling spindle
My solution to driving the pillar tool drill was a cheap grinder with the stones removed Now I have my tool post milling spindle I may well transfer the sewing machine motor to the Pillar tool for a more compact set up Stay well, Rod |
Bazyle | 28/06/2020 10:53:16 |
![]() 6956 forum posts 229 photos | Good grief that workshop is clean! But I like the idea of using a grinder motor for certain things as they are sealed, though that makes for a cooling problem in some instances. |
Cornish Jack | 28/06/2020 11:14:47 |
1228 forum posts 172 photos | Recently had the same problem but realised that mounting options were the answer. With the preferred direct drive vertical mounting, the rotation was wrong, but by mounting the motor horizontally and driving via jockey pulleys, the spindle output was correct. Don't have piccies at the moment but can produce if wished. rgds Bill |
Buffer | 04/12/2020 10:24:16 |
430 forum posts 171 photos | Hi I have just finished a George Thomas Pillar Tool and like a complete idiot I never gave a moments notice to the direction of the motor until I found my drill going backwards that is! After much swearing I have looked online to try and find out how to reverse it. I have seen that it can be done and it seems to be the case that just moving one connection will do it. My question is does anyone know if its done in the foot switch or in the motor? I did try swapping the blue and brown under the motor cover and no surprise it didn't do it. So if there's anyone or a few of you who find this stuff easy I would really appreciate the advice. Thanks These are the two wires that go to the motor however it is connected to the foot switch by a 3 pin plug.
Edited By Buffer on 04/12/2020 10:25:00 |
Keith Long | 04/12/2020 10:57:35 |
883 forum posts 11 photos | Hi Buffer - to reverse that motor you'll need to do it inside the motor - and you probably won't be able to get at the connections inside without destroying the motor, as everything seem to be moulded in - been there and gave up when I realised what I'd need to do! If you can access the brushes there is a good chance that you'll find that they are offset to favour the running direction so they won't be at all happy if you do manage to reverse the motor. Sewing machine motors of that type are generally built for single direction rotation and are sold as being set for clockwise or anti-clockwise rotation. Y Your options would seem to be buy another motor that goes the way you want or re-jig the motor mountings so that you get the rotation that you need on the spindle. If you mount the motor slightly skewed then you can just use a crossed drive belt to get the rotation direction that you want. That would also give you the option of bi-directional rotation if you ever need it. Don't believe everything that see on the internet, I think older motors CAN be dismantled and reversed but the newer ones are made using modern techniques and materials to keep the price down. Reverse on a sewing machine is a mechanical operation to keep the timing right through the needle shuttle interaction, rather than just driving the whole machine backwards. Edited By Keith Long on 04/12/2020 11:03:44 Edited By Keith Long on 04/12/2020 11:04:57 |
Les Jones 1 | 04/12/2020 11:48:36 |
2292 forum posts 159 photos | If you can open the motor it should be possible to reverse it. The mains is fed to one end of each field winding. the other end of each field winding is connected to one of the brush holders. To reverse it you need to swap over the connections between the field windings and brushes. This will probably involve extending the wires from the field windings to reach the opposite brush holder. It is possible that there are also small RF chokes and capacitors fitted inside the motor to reduce interference. If this is the case you will probably have to post pictures of the inside of the motor so we can tell you if this has any bearing on the way you swap over the connections. Les. |
John Hinkley | 04/12/2020 12:03:34 |
![]() 1545 forum posts 484 photos | If you follow Roderick Jenkin's link, the wording of the advert. suggests that they will supply motors giving either rotational direction. Might be worth further investigation if it proves too difficult or too daunting to delve into the inside and re-knitting the wiring. Tried that a few years ago and gave up! John Edited to alter gobbledegook into something approaching English Edited By John Hinkley on 04/12/2020 12:05:12 Edited By John Hinkley on 04/12/2020 12:05:34 |
Buffer | 04/12/2020 13:49:17 |
430 forum posts 171 photos | Thanks guys. I have just phoned up the supplier Beds sewing and knitting and they have a reverse direction motor same type for an extra tenner, I'm picking it up on the school run. Regards Rich. |
Howard Lewis | 04/12/2020 19:15:54 |
7227 forum posts 21 photos | If the motor has brushes, another method springs to mind. Insert a suitably rated (in terms of voltage and current ) bridge rectifier followed by a double pole changeover switch. In this way the motor will be fed DC and the changeover switch, correctly wired will provide the facility to reverse the direction of rotation. Howard |
John Haine | 04/12/2020 20:04:32 |
5563 forum posts 322 photos | Howard, unfortunately not. When you reverse the voltage you reverse the current in both armature and stator. After all it runs on ac when the voltage is reversing 50 times a second. |
Howard Lewis | 04/12/2020 20:15:10 |
7227 forum posts 21 photos | A motor with brushes is often referred to as a universal motor, because it will run on either AC or DC. As a small boy I found that reversing the DC connections made the series wound motor for my construction set reverse. Howard |
Peter Spink | 04/12/2020 20:28:42 |
![]() 126 forum posts 48 photos | Coincidentally I'm in the process of repurposing a Makita laminate edge trimmer for the same reason. Had to dismantle it to reverse the brush connections which was a 'do or die' situation but it went back together OK and now runs in the correct direction. Hopefully the cooling fans will also work in reverse but will not be in continuous use so fingers crossed. Fortunately the brushes are at right angles to the commutator on this motor so a quick rub down to take the edges off should keep them happy. The speed plate says 28000rpm (!) so I'm using a Velleman speed controller which works a treat with this type of motor and will allow it to run at a more manageable speed. |
John Haine | 05/12/2020 08:05:35 |
5563 forum posts 322 photos | Posted by Howard Lewis on 04/12/2020 20:15:10:
A motor with brushes is often referred to as a universal motor, because it will run on either AC or DC. As a small boy I found that reversing the DC connections made the series wound motor for my construction set reverse. Howard Howard the motor for your set would have been a permanent magnet type, it has brushes on the rotor and a commutator but a permanent magnet to provide the stator field. A universal motor has a wound field in series with the armature so the current flows the same way in each. If you reverse the current you reverse it in both so the motor runs the same way. This obviously has to be the case if the motor is to run on ac. |
