Does anyone recognise this blade ? ....
Michael Gilligan | 20/12/2018 21:12:32 |
![]() 23121 forum posts 1360 photos | Here's a screen grab from the latest epidode of "Digging for Britain" ... featuring a [presumably] Diamond saw, on a transparent disc. . Does anyone recognise it, please ? MichaelG. |
SillyOldDuffer | 20/12/2018 21:26:22 |
10668 forum posts 2415 photos | Could it be an optical illusion due to holes in the disk? Something like these dremel diamond cutters on amazon. Dave |
Dalboy | 20/12/2018 21:29:17 |
![]() 1009 forum posts 305 photos | Could it be one with holes but due to the speed it appears as though it is a clear material. If it was plastic any heat build up may effect the clear plastic and distort the disc. Edit cross post with SOD above and they are what I was thinking of Edited By Derek Lane 2 on 20/12/2018 21:30:07 |
Michael Gilligan | 20/12/2018 21:36:42 |
![]() 23121 forum posts 1360 photos | Thanks, gentlemen ... I did wonder that. I have already written to Dr Madgwick, and will report back if/when he advises me. MichaelG. |
colin wilkinson | 20/12/2018 22:57:25 |
71 forum posts | On eBay, from China, but for £3 I will take a chance. https://www.ebay.co.uk/itm/10x-Mini-Diamond-Cutting-Discs-Wheel-Blades-Set-Drill-Bit-For-Dremel-Rotary-Tool/332731011825?epid=1854079303&hash=item4d785052f1:g:fzkAAOSwYq5bVhpY. Colin |
Bill Pudney | 21/12/2018 02:13:19 |
622 forum posts 24 photos | Or try a lapidary shop, they use fine diamond discs to cut stones, rocks etc. They also cut composites which is why I got mine!! cheers Bill |
JasonB | 21/12/2018 07:04:30 |
![]() 25215 forum posts 3105 photos 1 articles | The amount of "solid" around the edge looks a lot thinner than most of the drilled discs that are about would show when spun up but you may want to look at the dental ones such as this which only have a small amount of diamond coating around the edge |
Ron Laden | 21/12/2018 09:06:59 |
![]() 2320 forum posts 452 photos | Posted by JasonB on 21/12/2018 07:04:30:
The amount of "solid" around the edge looks a lot thinner than most of the drilled discs that are about would show when spun up but you may want to look at the dental ones such as this which only have a small amount of diamond coating around the edge I think Jason is probably right, my brother in law was a dental technician at the local hospital. He once showed me around his workshop and I can remember seeing a small holder with a range of very thin small cutting discs, not the type you would normally see for sale. |
Michael Gilligan | 21/12/2018 09:12:54 |
![]() 23121 forum posts 1360 photos | Well folks ... as you may have noticed, he was sectioning a tooth MichaelG.. |
Ron Laden | 21/12/2018 09:25:25 |
![]() 2320 forum posts 452 photos | Michael, have a google for Kerr diamond cutting discs Ron |
Michael Gilligan | 21/12/2018 09:59:58 |
![]() 23121 forum posts 1360 photos | That looks promising, Ron https://www.kerrdental.com/kerr-rotary/diamond-discs Some of their's are slotted, rather than being perforated with big round holes ... so the optical illusion would probably be more convincing. . MichaelG. . Edit: Thanks also to Jason Edited By Michael Gilligan on 21/12/2018 10:09:11 |
Martin W | 21/12/2018 10:55:08 |
940 forum posts 30 photos | I haven't watched the programme yet Michael but are you sure its a tooth and not a bone that he is sectioning? It doesn't look to have the right structure and shape for a tooth. Martin W |
Michael Gilligan | 21/12/2018 15:06:14 |
![]() 23121 forum posts 1360 photos | Posted by Martin W on 21/12/2018 10:55:08:
I haven't watched the programme yet Michael but are you sure its a tooth and not a bone that he is sectioning? It doesn't look to have the right structure and shape for a tooth. Martin W .
... His department also does a lot of work on teeth Apologies for the sloppy error on my part MichaelG. Edited By Michael Gilligan on 21/12/2018 15:32:09 |
Michael Gilligan | 21/12/2018 15:09:34 |
![]() 23121 forum posts 1360 photos | Helpful resonse from Dr Richard Madgwick : [quote] It's not actually transparent - it has spokes, but you can't see them. It's a flexible diamond wheel that dentists use. I get them from prestige dental and they're about £12 each I think. [/quote] Thanks for the interest, everyone MichaelG. |
JasonB | 21/12/2018 16:03:57 |
![]() 25215 forum posts 3105 photos 1 articles | So are you taking up DIY dentistry as a hobby for the new year? |
Michael Gilligan | 21/12/2018 16:17:15 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 21/12/2018 16:03:57:
So are you taking up DIY dentistry as a hobby for the new year? . Maybe about 2:30
