David Noble | 08/12/2018 15:28:41 |
![]() 402 forum posts 37 photos | I have a number of years experience in engineering but have never made a clock, which is something that I have been wanting to do for a while. After much looking I think that the John Wilding Great Wheel Clock has taken my fancy. ( hence the title of this thread) Does anyone know the approximate diameter of the large wheel? Many Thanks, David |
lfoggy | 08/12/2018 16:12:23 |
![]() 231 forum posts 5 photos | I was in a similar position a few years ago and decided to make the John Wilding eight day wall clock. I found that adjusting from engineering to clock-making wasn't as easy as I had anticipated. The main difference is the importance of minimising friction which is crucial as the power output of the clock is very small. This means adopting 'clock-maker's tolerances' as opposed to 'engineer's tolerances' and ensuring all contact surfaces have been polished and hardened. Very satisfying once you get into it. I've now made a number of JW's clocks and can attest to the excellence of his designs. Don't know the size of the great wheel in the great wheel clock. Its not one I have every fancied making as the crrossing out of all the wheels to the level of cosmetic perfection required is a bit of an ordeal ! |
David Noble | 08/12/2018 16:19:23 |
![]() 402 forum posts 37 photos | Cheers lfoggy |
stephen. | 08/12/2018 17:08:21 |
26 forum posts 12 photos | Hi David, I believe the great wheel is somewhere around 8 1/2" to 8 3/4" in diameter. I believe it has 290 teeth. Hope that's of some help, Stephen
David Noble | 08/12/2018 17:35:03 |
![]() 402 forum posts 37 photos | Thank you Stephen, yes it does help. |
Ian S C | 09/12/2018 11:48:39 |
![]() 7468 forum posts 230 photos | If you come from model engineering to clocks, maybe if you can build Stirling Engines that run freely straight after assembly you are well on your way, I think some call it a rattling fit. Ian S C |
David Noble | 09/12/2018 16:59:32 |
![]() 402 forum posts 37 photos | Hello Ian, I don't have a model engineering background more of an experience in engineering toolroom and maintenance. I'm thinking along the same lines though and have started to build a Stirling engine. We'll see how it goes |
Sam Stones | 09/12/2018 20:52:10 |
![]() 922 forum posts 332 photos | Hi David, My guess is you’ve already done this … but, when you finally get around to building the clock, or even before, try a few keywords in the Model Engineer Forum (title) Search; e.g. Wilding, clock, ... Entering ‘clock’ reveals several pages of threads dating back to August ‘09. More specifically, there’s a ‘Clocks’ section in the drop-down list to the right of the keywords block. Another place to visit and where you’ll find some quality videos on building John Wilding’s Great Wheel Clock , is … **LINK** Scroll down to the bottom of the page for Part 1 of Chris’s series “Making the Clock Frames’. I hope you get as much out of this Forum as I have. Sam Edited By Sam Stones on 09/12/2018 20:53:19 |
David Noble | 09/12/2018 21:43:14 |
![]() 402 forum posts 37 photos | Hello Sam, Thank you for your reply. I haven't checked all the forum titles yet but I will, thank you. I have seen to Clickspring video and must admit to being a little intimidated! However, we will see. Thanks, David |
Sam Stones | 09/12/2018 23:27:13 |
![]() 922 forum posts 332 photos | Hi David, With your combined skills you’ll have no difficulty. In fact, you’ve come on deck at just the right time. I couldn’t work out how to undo these, and since I’m not a member of the Magic Circle are you in a position to help?
Sam |
Fowlers Fury | 10/12/2018 00:47:08 |
![]() 446 forum posts 88 photos | |
Sam Stones | 10/12/2018 01:34:21 |
![]() 922 forum posts 332 photos | Now that is clever FF. I'd take my hat off to you if I had one! Sam |
David Noble | 10/12/2018 08:22:36 |
![]() 402 forum posts 37 photos | Brilliant, Love it |
Michael Gilligan | 10/12/2018 08:32:30 |
![]() 23121 forum posts 1360 photos | Posted by Sam Stones on 10/12/2018 01:34:21:
Now that is clever FF. . +1 |
