chuck grinder
celso ari schlichting01/12/2018 14:17:25
145 forum posts
I made this adaptation:
greetings from Brazil
Celso Ari
Brian Wood01/12/2018 15:51:02
2742 forum posts
39 photos
Hello Celso,
Just out of interest, what was the thread at the back of the chuck machined to before you tapped it out 14 mm?
clogs01/12/2018 16:32:04
630 forum posts
12 photos
Celso,
I like ur idea BUT unless it's the vari speed model it's just to fast for anything bigger than 5mm.......the vari speed is used by a few stonemasons I know.....not much need woith steel.......
in steel or ally bit to dangerous.....
clogs............be careful out there......
peak401/12/2018 20:07:11
2207 forum posts
210 photos
It was only when I saw you using a drill bit at the end of the video that I realised the purpose.
From the thread title, I thought you were going to use a mounted stone point and use it for grinding the inside of some lathe chuck jaws, using it as a toolpost grinder.
I've done that with the motor off a Bosch POF 500a router, fixed in the toolpost on my Myford.
A cheal old router, but with a removable motor unit on a standard 43mm collar.
Bill
Ian Skeldon 201/12/2018 21:40:15
543 forum posts
54 photos
Why? Sorry but I just don't see the need to spend so much time re-inventing a drill, what am I missing?
Mike Poole02/12/2018 06:28:44
3676 forum posts
82 photos
Useful for drilling joists where you have to get in a space too narrow for a normal drill.
Ian S C02/12/2018 09:29:36
7468 forum posts
230 photos
Drill chucks are available for most brands of angle grinder. One of the main uses I'v managed to find is drilling holes in logs to inoculate the log with mushrooms, as used in that form of mushroom farming.
Ian S C
Ian Skeldon 202/12/2018 09:31:12
543 forum posts
54 photos
Ahh ok I haven't drilled joists so not come across that requirement and I suppose being able to remove the chuck easily will be useful should the grinder function be needed.
celso ari schlichting02/12/2018 19:39:06
145 forum posts
Posted by Brian Wood on 01/12/2018 15:51:02:
Hello Celso,
1/2 20tpi
celso ari schlichting02/12/2018 19:44:10
145 forum posts
Posted by Ian S C on 02/12/2018 09:29:36:
Ian S C
Here in Brazil does not exist to buy, we have to build it
