Here is a list of all the postings celso ari schlichting has made in our forums. Click on a thread name to jump to the thread.
Thread: a machinist making a knife |
14/07/2023 23:42:49 |
a machinist making a bowie knife |
Thread: diy zinc plate |
01/07/2023 12:04:30 |
diy zinc plating https://youtu.be/bG1Sg5pHaxE Greetings from Brazil Celso Ari |
Thread: shop tour part 2 |
23/06/2023 23:24:12 |
shop tour part 2 https://youtu.be/63402xqmCVE Greetings from Brazil Celso Ari |
Thread: shop tour part 1 |
21/06/2023 13:09:38 |
Posted by Chris Evans 6 on 19/06/2023 19:19:11:
Impressive kit and loads of space. thanks |
18/06/2023 21:06:35 |
Shop tour part 1 https://youtu.be/RpiQO3wU2_Q Greetings from Brazil Celso Ari |
Thread: horizontal milling attachment |
02/06/2023 20:30:45 |
Installing a horizontal milling attachment https://youtu.be/rS86Bxir59Y Greetings from Brazil Celso Ari |
Thread: DIY compressed air torch |
27/05/2023 22:56:47 |
how i built my compressed air torch
https://youtu.be/AlaAuJcTc9o
Gretings from Brazil
Celso Ari |
Thread: my alternative sensitive knurling tool |
21/05/2023 22:59:44 |
Posted by Chris Crew on 21/05/2023 22:10:34:
I believe this type of knurling tool was originally a Marlco product. It's very good up to a point in relieving the pressure put upon the work and lathe spindle by a tool-post mounted knurling tool but there is a flaw in the design. I made the 'standard' size version when it was described some years ago in a model engineering publication and also a double sized one to knurl the large index ring on a Quorn I was making (still yet another unfinished symphony!). This was a little less successful as the knurls tended to wander a little due to the increased flexing in the elongated arm. The problem, in my experience, lies in the eccentric at the rear of the upper arm as when the lever is operated to increase the pressure on the knurls the top arm is moved slightly which tends to destroy any nice pattern generated when the knurls are rolling in 'synchronism'. Other than that, providing you bear this issue in mind, some nice results can be achieved when the knurl pattern emerges and no further adjustment is made. Edited By Chris Crew on 21/05/2023 22:11:28 Thanks for the info
21/05/2023 22:59:00 |
Posted by Nigel Bennett on 20/05/2023 16:27:46:
That's an excellent piece of work, Celso Ari; well done. It is always interesting to see how other people make things! Is there another video of it actually working on your lathe? see my chanel in you tube. Sorry for my English, here in Brazil we speak Portuguese, so I might misspell some words
21/05/2023 22:56:22 |
Posted by Simon Johnson 2 on 21/05/2023 12:24:52:
I'm really pleased you posted this, I had not come across your channel but have now subscribed -some very interesting videos I'm looking forward to watching Thanks friend greetings from Brazil Celso Ari |
21/05/2023 22:54:48 |
That's an excellent piece of work, Celso Ari; well done. It is always interesting to see how other people make things! Is there another video of it actually working on your lathe? thanks friend greetings from Brazil Celso Ari |
19/05/2023 21:24:02 |
I decided to build a knurling tool and chose the Hemingway model, but I didn't have the plans so create my own. I made it 25% bigger than the English model and modified some parts... I left the main measurements in the video.
Thread: A differential gearbox for my hobbing machine |
16/05/2023 16:13:21 |
Hello Gustavo
I found your project a few years ago on YT.
I live in Brazil, and import fees for plans are very high. I saw you built your gear hobber its made of solid metal. In addition to making the project more accessible, it seems to me that your version is more robust. Do you have an email so we can talk? I would like to build your version of the machine.
my email is celsoari@hotmail.com
my YT page is https://www.youtube.com/@fazeremcasa520
Thread: homemade nickel plating with coins |
11/05/2023 20:24:45 |
In this video I used pure nickel coins to finish some mechanical parts. Greetings from Brazil Celso Ari |
Thread: hot black oxidation |
02/05/2023 20:09:08 |
@Fulmen, Exactly, your explanation was perfect.
29/04/2023 16:29:35 |
I made a couple of clamps and gave it a black oxidized finish, similar to those made on firearms. https://youtu.be/AQegF40xbWU I hope you enjoy the video
Celso Ari
Thread: bench grinder chamfer |
21/04/2023 21:50:41 |
how i made my chamfer: Greetings from Brazil Celso Ari |
Thread: Another sandblasting |
03/04/2023 22:41:28 |
Recently I saw in a forum the project of a youtuber friend of mine, Victor Lobato from the Victor's Shop channel, so I decided to make a similar one, using his measurements. I hope you enjoy
Gretings from Brazil |
Thread: Diy adaptive soft jaws |
10/03/2023 19:57:58 |
Posted by Oldiron on 10/03/2023 19:35:53:
Very nice job. Could be really useful. I bet they did not cost the average $8000 that Adaptix charge for theirs. regards Here in Brazil, it doesn't even exist to buy...
regards
10/03/2023 17:53:14 |
How i built my adaptive soft jaws |
