duncan webster | 27/11/2018 17:34:14 |
5307 forum posts 83 photos | Having modelled my loco wheels in Alibre I've worked out that I need some really heavy stuff for balance weights. What I think I want is Tungsten/nickel/copper alloy, which has a trade name of Densalloy. Anyone got any idea where I might get small quantities, I've tried Ebay. Finished size is thick tube, 2.8" OD, 1" ID, 3/16" slices, 2 off. In the end I'll probably just accept the out of balance, but it's an interesting exercise to work out how good I could get it. |
pgk pgk | 27/11/2018 17:59:02 |
2661 forum posts 294 photos | I'm not sure i understand but guess you'd be slicing those two pieces in half for 4 balance weights? If so cannot you thicken up the size and use lead? Or a quick trip to some forgotten recent war zone for a chunk of depleted uranium (just a tad toxic)?
pgk |
Niels Abildgaard | 27/11/2018 18:00:03 |
470 forum posts 177 photos | In good old days where EDM meant sink sparking the elektrodes were sometimes made of wolfram-kupfer that is easy to machine.Density about 17 I think. |
Neil Wyatt | 27/11/2018 18:22:13 |
![]() 19226 forum posts 749 photos 86 articles | I suggest you read Duncan Webster's article in the latest ME. He would probably suggest copying the 9F and fitting balance weights to the axle. Neil |
JasonB | 27/11/2018 18:24:12 |
![]() 25215 forum posts 3105 photos 1 articles | have a look back at Andrews posts about his Tungsten balls Other option is to drill out the opposite side pop in a granule of polystyrene and then filler over the top. |
not done it yet | 27/11/2018 19:23:14 |
7517 forum posts 20 photos | TIG electrodes? |
duncan webster | 27/11/2018 19:31:45 |
5307 forum posts 83 photos | I can't make them thicker, they would clash with the frame. I'm looking at drilling lightening holes, but I really need both holes and more weights. See my article in ME some time ago. The manual calc of balance available in the existing design was wrong, too low, I've now got manual calc agreeing with Alibre fairly well. Edited By duncan webster on 27/11/2018 19:32:11 |
Neil Wyatt | 27/11/2018 20:32:21 |
![]() 19226 forum posts 749 photos 86 articles | Drill out the crankpins and halve their weight. Can you lighten any other parts?
Pete Rimmer | 27/11/2018 20:43:07 |
1486 forum posts 105 photos | How about grinding down some spent carbide milling/turning tips? They are quite heavy for the size. |
SillyOldDuffer | 27/11/2018 20:50:17 |
10668 forum posts 2415 photos | How about 'Tungsten Fishing Weights'? ebay sells weight stuff ranging from tungsten loaded putty up to 97% solid Tungsten in various shapes up to 50g. No idea how to machine it though!
Trevor Crossman 1 | 27/11/2018 20:59:30 |
152 forum posts 18 photos | Duncan, it might be worth you trying businesses that deal with aviation scrap/used parts. The flight control surfaces use very dense material for the balance weights, sometimes on light aircraft this is lead but more highly stressed aircraft use other heavy metals such as tungsten rich materials, many years ago when I repaired British military aircraft, we would often make up special rivet bucking blocks from discarded balance weights. Aviation tool suppliers stock Tungsten rich riveting bars in a variety of sizes, shapes and weights. Trevor. |
Anthony Knights | 27/11/2018 21:02:28 |
681 forum posts 260 photos | Googled "UK tungsten suppliers" and got 18 pages of hits. |
Jeff Dayman | 28/11/2018 19:33:06 |
2356 forum posts 47 photos | I'm surprised no one has mentioned depleted uranium as a candidate heavy metal for balance weights..... Unfortunately there's no DU Mart's still open in the UK as far as I know..... maybe still one in Skipton...... Anyone fancy a quick trip to Iraq to literally "pick some up"? (I'll get me coat and hat now) |
JasonB | 28/11/2018 19:40:38 |
![]() 25215 forum posts 3105 photos 1 articles | Jeff you mist this in one of Duncan's posts "I've seen the post Jason linked, that went into why I'm not even thinking about DU even tho' I worked in the nuclear industry most of my career." |
pgk pgk | 28/11/2018 23:27:19 |
2661 forum posts 294 photos | I note tungsten powder is available on ebay and other sources... just wondering if mixing it with epoxy into a mould would work?
pgk |
duncan webster | 28/11/2018 23:45:34 |
5307 forum posts 83 photos | I'd been googling Densalloy, tried UK tungsten suppliers and rang one up. Minimum order charge £280. I now have a lead in Manchester and one in Wales which I will follow up tomorrow. I suspect that tungsten power/epoxy mix would be no heavier than lead, and would be even less of an engineering material. I've looked at tungsten fishing weights, totally the wrong shape. I'll probably finish up with more conventional metals, brass or monel are heavier than steel (and I've got both) |
Michael Gilligan | 29/11/2018 00:04:02 |
![]() 23121 forum posts 1360 photos |
https://www.ebay.co.uk/itm/AIRCRAFT-TOOLS-HEAVY-TUNGSTEN-BUCKING-BAR-721-GRAMS-1LB-91-2-ounce/273557225151 ... You could probably sell the offcuts and swarf. MichaelG. . Alternatively: https://www.lasaero.com/products/article/A00IMGATV Edit: Yes, I realise that none of these is actually to your dimensional spec. "Finished size is thick tube, 2.8" OD, 1" ID, 3/16" slices, 2 off." Edited By Michael Gilligan on 29/11/2018 00:30:12 |
duncan webster | 29/11/2018 11:51:49 |
5307 forum posts 83 photos | Thanks Michael, at that price which I'm sure is typical, I'll stick to monel which I've had for 40 years. Originally part of an electrolysis cell I think, bought for peanuts in club auction. |
duncan webster | 29/11/2018 18:39:37 |
5307 forum posts 83 photos | So this is what it looks like with extra weights and lightening holes. A lot better than original design for balance, and I'm bored with it now, as I'm sure everyone else is! Is it possible to insert png images? having to go via Paint to convert to jpg is a pain. And does anyone know why when I press return on this site the cursor goes back to the start of the document, not to the next line? I have to press shift/return
Niels Abildgaard | 29/11/2018 19:01:23 |
470 forum posts 177 photos | Seek (tungsten pine car) on the USA Ebay |
