Mikron F75
Spindle removal
Bill York25/10/2018 10:49:10
55 forum posts
58 photos
Good morning guys.
I have recently purchased a Mikron F75 milling machine and I have started the process of stripping down and restoration, everything is going fine apart from removal of the spindle, I have loosened all bolts, screws and retaining rings but the thing will not come out or even move although it still has free movement to spin, any help on the process of removal would be greatly appreciated. Thanks Bill.
Rod Ashton25/10/2018 10:56:35
344 forum posts
12 photos
Bill - If this is the belt driven horizontal head. I tried for a long time to figure it out. In the end I converted it to something else. Not too helpful I know!!
John Haine25/10/2018 11:18:12
5563 forum posts
322 photos
Have you contacted David Samways at Anglo-Swiss Tools?
Bill York25/10/2018 11:39:16
55 forum posts
58 photos
Thanks for the reply Rod,It is the horizontal head and every thing is fine I just want to get the spindle out to polish it. every thing about the machine is great, the build and finish is what you would expect from the Swiss. There must be someone out here that knows how to dismantle this thing.
Bill York25/10/2018 11:43:26
55 forum posts
58 photos
Thanks John I have spoken to Anglo-Swiss but David said he has never had to remove the spindle and does not know how to do it nor can I find any literature on the subject.
Bill York25/10/2018 11:51:32
55 forum posts
58 photos
I have added some pics in albums if any one would like to cast an eye over them and maybe have a suggestion.
Pete Rimmer25/10/2018 15:14:03
1486 forum posts
105 photos
I think the answer probably lies with that off-set square drive fitting in the cone pulley. Have you figured out it's purpose Bill?
Ady125/10/2018 15:24:27
6137 forum posts
893 photos
Ady125/10/2018 15:29:52
6137 forum posts
893 photos
loosen all the screws to disengage the pulleys from the spindle, the pulley will probably be on a long key so still cannot be turned independently
The main thing is the direction of removal, usually a spindle exits on the load side but that's with lathes
Then get a big hammer....
Edited By Ady1 on 25/10/2018 15:36:46
Michael Gilligan25/10/2018 15:56:57
23121 forum posts
1360 photos
Given the oiling point in the small step of the pulley ... is there a backgear built in ?
surprise MichaelG.
Bill York25/10/2018 16:26:45
55 forum posts
58 photos
Yes it is an oil port and yes there is a 3-1 back gear in the large step.
Bill York25/10/2018 16:29:27
55 forum posts
58 photos
Posted by Pete Rimmer on 25/10/2018 15:14:03:
The square bolt you refer to is released to engage the back gear that is located in the large step pulley and as far as i can see does not locate on the spindle
Bill York25/10/2018 16:34:29
55 forum posts
58 photos
Posted by Ady1 on 25/10/2018 15:29:52:
I have released every screw nut and bolt but there is no lateral movement at all, i have given it several gentle taps with a lead hammer but still no movement, I am reluctant to give it the big hammer treatment as often the result is irreversible.
Michael Gilligan25/10/2018 19:23:58
23121 forum posts
1360 photos
Posted by Bill York on 25/10/2018 16:26:45:
... and yes there is a 3-1 back gear in the large step.
Nice !!
Neil Wyatt25/10/2018 20:20:34
19226 forum posts
749 photos
86 articles
I suspect you have to undo the ring nuts with c-spanners in a co-ordinated manner as the spindle slowly edges left or right through whichever is the largest diameter hole...
But... if it ain't broke, why take it apart?
Michael Gilligan25/10/2018 20:36:07
23121 forum posts
1360 photos
Bill,
It appears that the headstock is similar to that of the T90 lathe
... You may find more information about that.
Bill York25/10/2018 20:58:28
55 forum posts
58 photos
Posted by Neil Wyatt on 25/10/2018 20:20:34:
It's all about the finish, easier to polish the pulley off the head than on and once I know how to do it I can pass it on.
Bill York25/10/2018 21:01:08
55 forum posts
58 photos
Posted by Michael Gilligan on 25/10/2018 20:36:07:
Bill,
Yes all the heads on the T90 will fit the F75 and vice versa the only difference is the t90 heads tend to have 4 speed step pulley, but still cannot find any info on strip down.
Michael Gilligan25/10/2018 21:22:33
23121 forum posts
1360 photos
Hardly a service manual, but ... The last few pictures on this page might help, a little:
http://www.lathes.co.uk/mikron/page4.html
Ady126/10/2018 10:10:11
6137 forum posts
893 photos
Posted by Michael Gilligan on 25/10/2018 21:22:33:
ooooh, scary bearings
They look like pultra 1590 ultra high precision bearings
1 Buy a manual
2 Consider not opening them up unless very very necessary
Edited By Ady1 on 26/10/2018 10:10:54
