Gunnar M | 17/09/2018 20:49:06 |
8 forum posts 1 photos | Hi! Is there anyone that have ever replaced the front spindle bearing on a Colchester Chipmaster? If so do you have the procedure for this? I had some axial clearence in the front bearing. I try to tighten it and it get mutch better. But i think the bearing is worn since i used a lot of force to tigheten it. So i wonder if i shell replace it. Gunnar |
Nick Taylor 2 | 17/09/2018 21:01:16 |
102 forum posts | Hi Gunnar, The bearings are VERY expensive if they are still available. How did you adjust your bearings? |
Gunnar M | 17/09/2018 21:32:23 |
8 forum posts 1 photos | Hi Nick! I have got a price for the front bearing 444.-€ + shipping. Yes they are expensive. The rear bearing 292.-€. I open the side cower and loose the set screw on the c-spanner nut that are close to the gear 1087. Then loosen the c-spanner nut a littel.I then loose the set screw on the c-spanner nut that are close to the front bearing. Used a hammer and a brass bolt and gave the c-spanner nut some punch. I then manage to remove the clearence. Gunnar |
Ian Burgess 1 | 18/09/2018 00:11:31 |
7 forum posts | Posted by Gunnar M on 17/09/2018 21:32:23:
I have got a price for the front bearing 444.-€ + shipping. Yes they are expensive. The rear bearing 292.-€. From Global Bearings in the UK? That price is likely to be the same across all dealers in Europe. How much movement did you detect and how did you measure? |
Nick Taylor 2 | 18/09/2018 10:11:08 |
102 forum posts | That’s very cheap for the bearings, are you sure they are selling you the pre-assembled dual row version, and not just the single row? That is the entire front bearing assembly, the same bearings as fitted to the 12 inch students. Edited By Nick Taylor 2 on 18/09/2018 10:11:43 |
Gunnar M | 18/09/2018 19:57:11 |
8 forum posts 1 photos | Hi! It's not from Global Bearing's in the UK. I am in contact with the company to be sure that it's the correct bearing. I will be back with the comapny name when i have received one, if i order it. How mutch movement it was i can't remember. But i measure it with an dial indicator on the end of the spindle after i run it for abouth 20min. I just push it wiht my hand. I hear a knocking sound when i push from one side to the other. It get OK after i tighten it as described in the second message. But i am worried that the bearing is damaged since i was able to muve it and i got the knocking sound Regards Gunnar |
Jon | 18/09/2018 22:06:38 |
1001 forum posts 49 photos | Here you go done some searching for you. £186 and UK Gamet double row. Look like old stock
ronan walsh | 18/09/2018 22:08:35 |
546 forum posts 32 photos | The price of spares for colchesters is a scandal, one of many reasons not to buy one. |
Nick Taylor 2 | 19/09/2018 13:15:53 |
102 forum posts | Not sure where you got that part number Jon, but its not the correct bearing for the chipmaster. Ronan – not sure scandal is the right word. The bearings are expensive because of quality. Also don’t forget we are talking about a 60+ year old design here, the fact that there are spares at all is impressive. |
ronan walsh | 19/09/2018 21:20:26 |
546 forum posts 32 photos | Posted by Nick Taylor 2 on 19/09/2018 13:15:53:
Sorry i have a very low opinion of colchesters, having used them for many years professionally, and foolishly taking one home, free from where i was working. Should not have done that, noisy rattly thing with a rapid wear bed. Someone told me the old round head machines were better, i do not know, but i avoid colchester now at all costs |
Nick Taylor 2 | 19/09/2018 23:02:19 |
102 forum posts | Ah if you’re referring to the newer square ‘Mk2’ machines then I agree, they obviously made a choice during the design and focused on price heavily. A friend of mine runs a predominantly CNC business but needed a large swing centre lathe and looked at a few Colchester’s, finding machines less than 5 years old which were complete wrecks! The Roundheads seem to command much better prices though! |
ronan walsh | 20/09/2018 00:34:08 |
546 forum posts 32 photos | Posted by Nick Taylor 2 on 19/09/2018 23:02:19:
Ah if you’re referring to the newer square ‘Mk2’ machines then I agree, they obviously made a choice during the design and focused on price heavily. A friend of mine runs a predominantly CNC business but needed a large swing centre lathe and looked at a few Colchester’s, finding machines less than 5 years old which were complete wrecks! The Roundheads seem to command much better prices though! Indeed Nick. At work years ago, a decision was made to buy a cnc lathe. A colchester was selected, despite the objections of the turner who had to use it, the manager of the machine shop, and even me. We were proved correct shortly after it was installed. The thing would not hold much of a tolerance. The company who sold it were called back out. After much head scratching, fancy measuring kit being used, too-ing and frowing, it turned out the bed was badly bent. It was a brand new machine fresh out of the crate. |
Mark Rand | 20/09/2018 02:35:01 |
1505 forum posts 56 photos | Posted by ronan walsh on 20/09/2018 00:34:08:
And set up properly?? |
thaiguzzi | 20/09/2018 06:56:20 |
![]() 704 forum posts 131 photos | Round head Colchesters = marvelous (but noisy) bits of kit. I ran two in my UK workshops for 15 years. By the time i sold up, they were both over 35 years old. Regret not keeping one. |
Ian Burgess 1 | 23/09/2018 10:55:47 |
7 forum posts | Posted by Jon on 18/09/2018 22:06:38:
Here you go done some searching for you. £186 and UK Gamet double row. Look like old stock Wrong bearing. Correct bearing is 113060X/113101XHE+10, 60.325mm internal/101.6mm external.
Ian Burgess 1 | 23/09/2018 11:04:53 |
7 forum posts | Read and weep: https://axxacnc.com/113060X-113101XHE-10
KWIL | 23/09/2018 12:17:20 |
3681 forum posts 70 photos | Link to AXXA, says "out of stock"!! |
Pete Rimmer | 23/09/2018 14:17:09 |
1486 forum posts 105 photos | I thought I had posted this reply, but it didn't appear so I must have messed up, Gunnar, before you go spending lots on new bearings check that your difficult adjustment isn't just the bearing inner being very tight on the spindle. I had a lathe that was like this and it was impossible to adjust the bearing due to the extreme stiction. I had to ease the fit a little with very fine emery, and after that the adjustment was easy to achieve. If you pull the spindle out of the bearing and it creaks loudly then it's a good sign of the above. |
ronan walsh | 23/09/2018 18:35:27 |
546 forum posts 32 photos | Posted by Mark Rand on 20/09/2018 02:35:01:
And set up properly?? As far i as i am aware, it was yes. All we did was remove an old machine and clear the area generally. The agents who sold us the machine did the installation, and took two days to do it if i remember correctly. |
Tiger | 07/04/2020 21:19:00 |
15 forum posts 4 photos | Hi all and Gunnar! |
