Transitional Engine
JasonB11/09/2018 07:17:22
If 4-stroke then it is possible to use a "steam" engine type eccentric but you need a way to half the amount of times the eccentric moves as you only want the exhaust to open every other rev of the crankshaft. A "Star Wheel" is one method that was used on the early engines, an epicyclic gear box inside the eccentric strap is another. Or you simply need to add 2:1 gearing to drive the exhaust valve and a lobed cam.
The inlet valve is easiest dealt with as an atmospheric one where it is held closed by a light spring and the suction of the moving piston on the induction stroke will pull it open drawing the fuel/air mix with it, again found on most open crank engines so typical of this type of engine.
Star Wheel in action on an Sphinx
Epicyclic gearbox on my Robinson X-type
Inside the gearbox ( made on an x series mill)
Ian S C11/09/2018 13:22:05
7468 forum posts
230 photos
I remember something in ME in the 1990s I think of some(maybe Tubal Cain) built an IC motor using a horizontal Stuart Turner steam engine.
I wonder if it would be possible to make it double acting, I know there would be the problem of sealing the piston rod gland.
Ian S C
Brian Oldford11/09/2018 20:53:36
686 forum posts
18 photos
Posted by Ian S C on 11/09/2018 13:22:05:
Ian S C
It would also make for an odd-ball shaped combustion chamber too.
JasonB11/09/2018 21:00:08
The Mery is a double acting engine and a bit of a half breed being built early on in the evolution of IC engines, and not too odd looking.
JasonB12/09/2018 07:49:06
Posted by Nigel on 11/09/2018 20:43:41:
The eccentric will result in a sinusoidal motion and simple comparison to a cam profile shows it is close. I will see if I can do a full comparison.
Simply leave a large tappet gap between rocker arm and valve stem, this will make part of your sinusoidal motion zero where there is a gap and then a peak where the rocker and valve are in contact. It won't give the quick opening and closing times of a lobed valve but will work. I would still make the intake an atmospheric one as then that will open and snap shut faster.
Edited By JasonB on 12/09/2018 07:49:29
Gary Wooding12/09/2018 08:23:33
1074 forum posts
290 photos
Jason's post of 11/09/2018 07:17:22 appears to be a response to an earlier post which doesn't show in my system. It's the first one in this thread - what's happened to the others?
Brian H12/09/2018 08:28:00
2312 forum posts
112 photos
Jason, thanks for putting on the video on the 1895 Mery Explosive Engine. I've never seen a double acting ignition engine before.
JasonB12/09/2018 11:00:49
Gary, there is some moderating going on.
Ian S C12/09/2018 15:23:46
7468 forum posts
230 photos
I was doing some reading today on converting a double acting steam engine to IC, the front side of the piston being used as a compressor to supply cooling air for the cylinder.
Ian S C
