Martin King 2 | 19/08/2018 16:29:24 |
![]() 1129 forum posts 1 photos | Hi All, Got this today at my local car boot along with a lot of other instrumentation. To avoid mis describing it when I list it could someone please tell me the correct name for this nice item. I THINK it is a Comparator Table for checking heights etc but do not want to get it wrong. Regards, Martin
Brian Wood | 19/08/2018 16:37:24 |
2742 forum posts 39 photos | Yes Martin, quite correct, and very nice too. Regards Brian |
Howard Lewis | 19/08/2018 18:31:36 |
7227 forum posts 21 photos | Yes, a Comparator. Presumably the clock reads in tenths of a thou, or an equivalent metric increment? Unless it has been abused, or is worn, it looks to be a good bargain. Lots of envy from us watchers, no doubt. Now you need to find a set of slips (Jo Blocks as some call them) to be able to set it up to whatever dimension you want to check. Unless horribly worn/abused, even if they no longer "Wring" together, they were made to a level of accuracy greater than almost every one of can measure, let alone match, (millionths of an inch). Howard |
Martin King 2 | 19/08/2018 18:37:10 |
![]() 1129 forum posts 1 photos | Brian & Howard, Thanks so very much! Of no use to me so onto that auction site! Cheers, Martin |
Mike E. | 19/08/2018 19:44:29 |
![]() 217 forum posts 24 photos | Posted by Martin King 2 on 19/08/2018 18:37:10:
Have you considered that it could be converted to a hand tapping machine ?
Adam Mara | 19/08/2018 19:58:49 |
198 forum posts 1 photos | We sold a couple to a local cannery in the 50's, used to check height of bottles and tins against a master copy. Sadly the cannery has long gone, and now is a housing estate, like so much of our industry. |
Howard Lewis | 19/08/2018 20:54:44 |
7227 forum posts 21 photos | Mike E Sacrilege to turn a precision instrument into a drilling machine derivative. You can make a Tapping Machine from some pipe fittings (Tee pieces) Would you use a Rolls Royce Silver Cloud for ploughing? Martin, Are you sure that you will have no use for it in the future? If NO, make sure that it goes to someone who will respect it and use it for its intended purpose! Howard |
Michael Gilligan | 19/08/2018 21:08:27 |
![]() 23121 forum posts 1360 photos | Howard, Whilst I admire your attitude of respect ... The sacrilege might be very small, and entirely harmless; depending on the size of tapping involved. ... How much harm would a watchmaker or scientific instrument maker actually do to this stand ? MichaelG. . Just for design inspiration [should anyone be so inclined]: https://www.hswalsh.com/product/bergeon-16200-bushing-tool-swiss-made-clocks-and-alarm-clocks-hb72 http://www.nielsmachines.com/en/bergeon-6200-clock-bushing-tool-set-35411651.html
Edited By Michael Gilligan on 19/08/2018 21:20:37 |
Emgee | 19/08/2018 21:14:47 |
2610 forum posts 312 photos | Whatever you choose to do I think the knurled ring should be below the DTI mount, used as an aid to lower the assembly, with the knob released the weight will allow the assembly to fall. + 1 for a tapping device. Emgee Edited By Emgee on 19/08/2018 21:16:01 |
ronan walsh | 19/08/2018 22:09:35 |
546 forum posts 32 photos | Chuck it up for sale here and let it be used for its intended purpose. It would be terrible to use it for anything other than it was intended for. A bit like idiots using micrometers as G-clamps. |
Martin King 2 | 20/08/2018 09:18:17 |
![]() 1129 forum posts 1 photos | Posted by Mike E. on 19/08/2018 19:44:29:
Mike E, That did occur to me but it came with another smaller similar item that I might well convert to a tapping machine. (IF I ever have the time...) Howard, sadly I have absolutely no way of making sure it goes to a 'good' home. Ronan: because we sell our items on EBay by way of a (very small!) commercial enterprise it is against the policy on here to use the personal classified ads which I completely understand. We do not have enough volume to afford a business ad and a lot of what we sell is more woodwork or general collectable related than engineering, mainly planes etc and so on. Cheers, Martin
Swarf, Mostly! | 20/08/2018 09:35:53 |
753 forum posts 80 photos | I do admire the way the design separates the pillar guidance from the clamping action. Best regards, Swarf, Mostly! |
Nicholas Farr | 20/08/2018 10:07:24 |
![]() 3988 forum posts 1799 photos | Posted by ronan walsh on 19/08/2018 22:09:35:
Chuck it up for sale here and let it be used for its intended purpose. It would be terrible to use it for anything other than it was intended for. A bit like idiots using micrometers as G-clamps. Hi ronan, with all due respect to your opinion, if one obtains items with their own personal finance, why should they be labelled as an idiot when they use them for something they were not designed for. (all safety factors accounted for) In a previous employment I had, there were people who buy brand new kit and had them stripped off part of it and use it for something completely different to the original manufacturers intention. Of course they void all warranty, but it does the job they require. Regards Nick. P. S. Personally I see no problem for someone to modify this item to suite one's purpose. Edited By Nicholas Farr on 20/08/2018 10:17:20 |
Mike E. | 20/08/2018 12:08:18 |
![]() 217 forum posts 24 photos | Posted by Howard Lewis on 19/08/2018 20:54:44:
Mike E Sacrilege to turn a precision instrument into a drilling machine derivative. You can make a Tapping Machine from some pipe fittings (Tee pieces) Would you use a Rolls Royce Silver Cloud for ploughing? Martin, Are you sure that you will have no use for it in the future? If NO, make sure that it goes to someone who will respect it and use it for its intended purpose! Howard Although I have many fine quality tools, I never considered that they needed to be put on an Alter. To me there is nothing sacrilegious about using a fine quality item to make a fine quality tool, and yes, I would use a Rolls Royce for towing a plow if I needed to; but I don't, I have a Kubota. I take very good care of my tools and vehicles, but they are there to serve me in life, not me to serve them. Cobbling pipe fittings for a tapping machine would suffice if the need arises, but personally, I would prefer to make something a little more refined if possible. |
Neil Wyatt | 20/08/2018 21:19:16 |
![]() 19226 forum posts 749 photos 86 articles | Better a useful life than the scrap bin. |
Jeff Dayman | 20/08/2018 21:34:06 |
2356 forum posts 47 photos | "Would you use a Rolls Royce Silver Cloud for ploughing?" If it started at -10 deg C and the tractor didn't, yes, I would...... |
