British empire lathe
My latest lathe
Spencer Ord09/08/2018 16:26:46
14 forum posts
14 photos
Hi guys.
Just thought I'd post a couple of pictures of my latest lathe. A British empire. Just started the strip down and rebuild.
Edited By Spencer Ord on 09/08/2018 16:28:01
Nick Clarke 309/08/2018 21:17:41
1607 forum posts
69 photos
Can't see the pictures
NJH09/08/2018 23:54:15
2314 forum posts
139 photos
Nick - you need to login to see the pictures.
Norman
Bodger Brian10/08/2018 09:06:58
187 forum posts
40 photos
Posted by NJH on 09/08/2018 23:54:15:
I'm logged in & I can't see them either. Normally I can see pictures in posts without needing to log in.
Edited By Bodger Brian on 10/08/2018 09:07:11
fizzy10/08/2018 09:42:03
1860 forum posts
121 photos
Defo no pictures
Neil Wyatt10/08/2018 09:47:43
19226 forum posts
749 photos
86 articles
The pictures are in his album, not his post.
You don't need to be logged in.
John Hinkley10/08/2018 10:07:35
1545 forum posts
484 photos
I looked at those pictures and assumed - wrongly, it seems - that it was a different lathe as it was titled "Mellor lathe". Similarly, I assumed there were no pictures in the thread as there isn't really a British Empire anymore!
Michael Gilligan10/08/2018 10:38:25
23121 forum posts
1360 photos
Posted by John Hinkley on 10/08/2018 10:07:35:
I would concur with your original assumption, John
Probably only Spencer can clarify.
Spencer Ord10/08/2018 18:43:21
14 forum posts
14 photos
Hi guys. Sorry for the miss understanding. Those pictures are of my Mellor lathe.how do I upload pictures to the post.
Michael Gilligan10/08/2018 18:57:01
23121 forum posts
1360 photos
Posted by Spencer Ord on 10/08/2018 18:43:21:
... .how do I upload pictures to the post.
Start with this forum's most-needed FAQ : **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1
Spencer Ord10/08/2018 18:57:04
14 forum posts
14 photos
I have made a new album. Empire lathe. I also uploaded some new pictures of my almost finished Mellor lathe
Michael Gilligan10/08/2018 19:02:12
23121 forum posts
1360 photos
That's a great start ... Now, if you wish to load them into a post, just use the camera icon on the top row of the posting window.
Spencer Ord10/08/2018 19:04:43
14 forum posts
14 photos
Ok that's great. Cheers.
daveb10/08/2018 19:39:21
631 forum posts
14 photos
I've seen a few Empire lathes over the years, some of them looking very much like South Bends, not sure about British though, I had a feeling they were made in Belgium. They all appeared to be decent quality machines. Dave
Spencer Ord11/08/2018 08:50:45
14 forum posts
14 photos
Yes your correct. Although mine is badged as British empire they are a Dutch machine made by Elliott. Mine is complete. I managed to find an original fixed steady for it. Still trying to find a travelling steady.
Clive Foster11/08/2018 10:40:46
3630 forum posts
128 photos
Had a Mk 2 version like that many years ago. Duff front bearing on mine which I had to change to get any sort of decent work out of it. Big Timken taper roller cost more than the lathe but still pretty reasonable really.
Objectively a fairly boring, bog standard lower end industrial lathe. Flat belt drive never really up to the theoretical capabilities of the machine. But at least drive slip reduced the chances of seriously damaging crashes.
Mondial design originally but pretty sure that at least some of the Mk 2's were UK made. As I recall it mine had made in UK stamped in a couple of places but it was a long time ago and memory is fallible. Tracing the actual provenance of machines made and/or supplied by Elliott Group tends to be "frustrating".
Clive.
Hopper11/08/2018 11:26:21
7881 forum posts
397 photos
Posted by Clive Foster on 11/08/2018 10:40:46:
... Flat belt drive never really up to the theoretical capabilities of the machine. But at least drive slip reduced the chances of seriously damaging crashes....
There's a lot you can do today with modern belt materials. You can even run a Poly-V belt straight on those old flat pulleys with very good results. Even better if you have a second lathe to turn the poly-grooves in the pulleys. Unslippable then.
Spencer Ord11/08/2018 19:05:53
14 forum posts
14 photos
Yes apparently the mk1 was prone to suffer from crash damage.but on the mk2 thinks have been improved. How good I don't no until I have finished refurbishing the machine. Being 40 inch between centres and 6 /12 swing. Plus having the gap bed should prove useful with a large face plate.
