Chester lathe help
Lead screw has stopped working.
Arthur Bell 216/05/2018 23:26:44
2 forum posts
Hi all. I'm new to lathe work an have owned a Chester 1236 for about six months with no problems. I have been practicing thread cutting today with good success. However the lead screw has stopped rotating with no apparent reason. I have checked everything is engaged but has no affect. Any pointers or ideas what could be wrong would be much appreciated.
I also can't fine any info on my lathe It has Chester 1236 gap bed lathe on the front and the only document i have, is an inspection record which has C06 Serial Family Bench Lathe. Model C06230c. MFG no 020968. Date 2002.5.
It look like an earlier model of the Chester Crusader but i can't find any reference to it anywhere.
Thanks in advance of any help. Arthur
John Rudd17/05/2018 07:12:10
1479 forum posts
Crusader manual here....
https://d28lcup14p4e72.cloudfront.net/171684/2071526/Compact_Crusader_Manual.pdf
Daniel17/05/2018 07:30:52
338 forum posts
48 photos
Hello Arthur,
Have a look at the following thread link.
I had a similar problem and this advice was spot on.
http://www.model-engineer.co.uk/forums/postings.asp?th=122735
Hope that helps,
Daniel
Edited By Daniel on 17/05/2018 07:32:08
Edited By Daniel on 17/05/2018 07:34:09
Edited By Daniel on 17/05/2018 07:34:42
Tony - CHUK17/05/2018 09:35:53
18 forum posts
Hi,
The usual culprit for this would be the Shear pin.
https://www.dropbox.com/s/30arizi64qhvo09/Chester%20Crusader%20Shear%20Pin.png?dl=0
Let me know if I can help any further, just PM me.
All the best,
Tony
(Chester Machine Tools)
Arthur Bell 217/05/2018 09:57:37
2 forum posts
Hi.Thankyou for the info. Spot on it is the sheer pin. Off to get some brass rod now.
Ian S C17/05/2018 11:16:15
7468 forum posts
230 photos
Look in the lathe's tool box, they usually put a couple of shear pins in there, along with a pin punch to knock the old one out. Well that's what happens this side of the rock.
Ian S C
Daniel17/05/2018 14:54:09
338 forum posts
48 photos
Also, do check that the pin isn't tapered.
