Pete Rimmer | 24/04/2018 20:01:14 |
1486 forum posts 105 photos | Evening! Does anyone know if the metric lead screw for the ML10 is trapezoidal thread or ACME? OD is 16mm with 3mm pitch but I don't know the form or if it's full form or stub form. If someone had a factory print that would make my day! Pete. |
John Haine | 24/04/2018 22:06:14 |
5563 forum posts 322 photos | If the ML10 follows the practice of the 7 series lathes, the leadscrew will not be metric though the x slide and topslide will be. The LS is probably 8 tpi though I don't know the threadform. |
Hopper | 25/04/2018 00:49:52 |
![]() 7881 forum posts 397 photos | Posted by John Haine on 24/04/2018 22:06:14:
If the ML10 follows the practice of the 7 series lathes, the leadscrew will not be metric though the x slide and topslide will be. The LS is probably 8 tpi though I don't know the threadform. Again, if it follows 7 series practice, the 8tpi leadscrew will be Acme threadform. |
Pete Rimmer | 25/04/2018 07:09:43 |
1486 forum posts 105 photos | I thought the same thing about them all being 8tpi because of the ML7 being so but the screw is certainly 3mm pitch. It's confirmed on the lathes page that they did make metric ones. I can't think why they would make a metric pitch screw with ACME form but you just never know. |
John Haine | 25/04/2018 07:36:28 |
5563 forum posts 322 photos | I found the lathes site ambiguous on this. "Available in both full metric and imperial versions each had compound-slide feed screws, micrometer dials and the leadscrew to the correct specification. To convert an imperial machine to metric screwcutting required only two 21t changewheels in addition to the normal set (it was not necessary to change the leadscrew) - while to convert the rest of the lathe to a metric specification (or the other way round) needed only the substitution of the correct cross and top-slide feed screws, nuts and micrometer dials. The lack of a tumble...". Seemed to imply that converting either way didn't need a different leadscrew. I guess you have a metric ml10 and have checked? If they actually made the 10 with a metric LS, it just confirms how peculiar Myford's approach to product engineering is that they didn't do the same for the 7 series. As far as I can see fro Wikipedia the main difference between Acme and the metric trapezoidal form is 1 degree on the flank angle. Assuming the screws were made in house, they could easily have used the same tooling for both. |
Michael Gilligan | 25/04/2018 07:44:00 |
![]() 23121 forum posts 1360 photos | Neither of these answers the opening question, but, here is evidence from 'Myford' that the leadscrew pitch of a 'Metric ML10' was 3mm: https://www.myford.co.uk/acatalog/ML10-LEADSCREW-NUT-ASSEMBLY-METRIC--10295-ACC-192.html https://www.myford.co.uk/acatalog/ML10-METRIC-LEADSCREW-MICROMETER--30-055-1429.html . That said: Thread profile gauges [to the standard required for this check] are not particularly expensive, or difficult to make Useful comparison of profiles here: http://bakergauges.com/product-detail/thread-gauge-profile/ MichaelG. Edited By Michael Gilligan on 25/04/2018 08:04:12 |
John Haine | 25/04/2018 08:45:31 |
5563 forum posts 322 photos | That seems to nail it Michael. |
Pete Rimmer | 25/04/2018 08:52:57 |
1486 forum posts 105 photos | It's certainly 3mm pitch. Assuming the screws were made in house, they could easily have used the same tooling for both. That's what concerns me, or rather that they might have used a 8tpi insert and set the lead to 3mm.
Edited By Pete Rimmer on 25/04/2018 08:53:27 |
Mick B1 | 25/04/2018 09:09:59 |
2444 forum posts 139 photos | +1 for the 3mm pitch. I'd've been nearly 7 thou per turn out on many things I made on my metric Speed 10 if it'd been 8 TPI. I always assumed it was Acme, but I'd never've picked up a 1 degree flank angle difference. |
Pete Rimmer | 25/04/2018 09:30:04 |
1486 forum posts 105 photos | Pretty easy to get the angle with a gear tooth caliper and some basic trig. I guess I'll grind a 30 degree tool in preparation and check the original screw when it gets here. |
not done it yet | 25/04/2018 09:30:22 |
7517 forum posts 20 photos | ACME is TPI and metric trapezoidal is pitch and never the twain shall meet - or at least they shouldn’t! |
Pete Rimmer | 25/04/2018 10:05:37 |
1486 forum posts 105 photos | Posted by not done it yet on 25/04/2018 09:30:22:
ACME is TPI and metric trapezoidal is pitch and never the twain shall meet - or at least they shouldn’t! True that, but then my Denford lathe had a cross slide screw that was 1/2" OD x 2.5mm pitch. They just used the same material and cut a 2.5mm thread in place of 10tpi. Weird things happen. |
Michael Gilligan | 25/04/2018 10:20:21 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 25/04/2018 09:30:22:
ACME is TPI and metric trapezoidal is pitch and never the twain shall meet - or at least they shouldn’t! .
Thread forms are, by convention, [always?] specified in terms of the proportion of their various features to a basline reference dimension ... the pitch. MichaelG. |
John Haine | 25/04/2018 10:42:34 |
5563 forum posts 322 photos | Posted by Michael Gilligan on 25/04/2018 10:20:21:
Thread forms are, by convention, [always?] specified in terms of the proportion of their various features to a basline reference dimension ... the pitch. MichaelG. If you look at the Wikipedia page on trapezoidal thread forms it shows that the basic definition is identical, given in terms of the pitch, except for the included flank angle. |
Pete Rimmer | 25/04/2018 10:51:23 |
1486 forum posts 105 photos | I just found a NOS set of half-nuts on eBay and the thread is quite roughly cast into the metal (zamak, possibly) half-nut. I guess that makes the half a degree half-angle difference immaterial. https://www.ebay.co.uk/itm/MYFORD-ML10-HALF-NUTS-3-0-PITCH-FOR-METRIC-LEADSCREW-/352300339399
Mick B1 | 25/04/2018 11:50:25 |
2444 forum posts 139 photos | Posted by Pete Rimmer on 25/04/2018 10:51:23:
I think so too. When I put that pic up on a largish screen and looked at the flank angle with my Lidl digital protractor, it came out a gnat's over 25 degrees included, so I reckon the flanks are in wide clearance and the halfnuts are riding on leadscrew crest to nut trough - I'm guessing to minimise the effects of oily crap on the leadscrew. During the 15 years I had my Speed 10, I found the engagement gritty and uncertain and took the halfnuts out, expecting to have to replace them. It wasn't necessary - once I'd poked out all the impacted crud, the inside thread came up shiny and unscored, so I put 'em back and had no more trouble Edited By Mick B1 on 25/04/2018 11:51:51 |
Neil Wyatt | 25/04/2018 12:22:38 |
![]() 19226 forum posts 749 photos 86 articles | Martin Cleeve recommended fitting a long grub screw to stop the half-nuts completely closing on the leadscrew as this give greater tolerance for gunk and greater repeat accuracy. Of course this is already a standard fitting on better class machines, like mini-lathes Neil |
Clive Foster | 25/04/2018 13:09:59 |
3630 forum posts 128 photos | Metric pitch ACME on imperial size bar stock doesn't seem uncommon. Pretty sure I measured my metric Bridgeport screws as being ACME form, not trapezoidal, when I gave it the post purchase scrub down, de-crud and spruce up treatment. Clive. |
Mick B1 | 25/04/2018 13:20:54 |
2444 forum posts 139 photos | Posted by Neil Wyatt on 25/04/2018 12:22:38:
Martin Cleeve recommended fitting a long grub screw to stop the half-nuts completely closing on the leadscrew as this give greater tolerance for gunk and greater repeat accuracy. Of course this is already a standard fitting on better class machines, like mini-lathes Neil Pete R's Ebay item already has that, and I *think* my Speed 10 did too. I might've wound it in a turn or two to minimise backlash - can't remember for certain. |
Michael Gilligan | 25/04/2018 13:22:31 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 25/04/2018 12:22:38:
Martin Cleeve recommended fitting a long grub screw to stop the half-nuts completely closing on the leadscrew as this give greater tolerance for gunk and greater repeat accuracy. . Interesting concept, Neil ... Could you please share the reference ? Whilst I can certainly accept that there are benefits in not closing the [slightly less than] half nuts onto the screw; the 'explanation' fails to impress. MichaelG. |
