How to paint aluminium
Martin Dowing05/04/2018 22:04:09
356 forum posts
8 photos
I have made of aluminium quite nice switchbox dedicated for motor control.
How to paint it? It is known that most of paints do not stick to aluminium and anodizing means much troubles. Chemistry is easy enough but I really want to avoid troubles related to purchasing appropriate chemicals and making appropriate bath, all just to make an odd item looking nice.
So any paints which will stick to aluminum well?
Martin
David Standing 105/04/2018 22:09:53
1297 forum posts
50 photos
Degrease well, then etch prime, then paint choice is the least of your problems - but choose something that works with the primer, not reacts with it.
Brian H05/04/2018 22:11:20
2312 forum posts
112 photos
What you need is an etch primer which are available from car shops. Then a top coat of your choice can be added after.
Tractor man05/04/2018 22:12:54
426 forum posts
U pol do an etch primer for aluminium available on line or from Halfords etc.
colin wilkinson06/04/2018 05:41:32
71 forum posts
Use a good mask when using etch primer, preferably outdoors as it is very nasty stuff. Only needs a very light coat, then conventional primer before top coating. Colin
Speedy Builder506/04/2018 06:51:41
2878 forum posts
248 photos
Question - Is it phosphoric acid in etch primer (I believe so), so, could you use a rust "eating" product such as JENOLITE which is Phosphoric acid based? MD may already have something like this in the workshop. If you do use it, don't leave it on for too long before washing it off.
This is a suggestion, others to comment before using this advice.
BobH
Robbo06/04/2018 08:06:47
1504 forum posts
142 photos
Try this previous thread - **LINK**
daveb06/04/2018 09:50:34
631 forum posts
14 photos
Avilable from car paint suppliers and shops in aerosol cans, works OK but use a filter mask, disgusting stuff to breathe!
MW06/04/2018 10:29:30
2052 forum posts
56 photos
why not just give it a good rub down with some steel wool before applying the paint of choice?
Michael W
JasonB06/04/2018 10:59:40
Michael, this is why you can't give it arub with wire wool, taken from Phoenix Paints site
"Brass, copper, aluminium and nickel silver, in fact all non-ferrous metals should be etch primed before applying any subsequent coats of paint. These metals have an oxide layer which paints do not adhere to very well. Even if abraded with abrasive paper, the oxide layer reforms within 2 or 3 seconds!! Etch Primer has an acid in it to microscopically eat through the oxide layer and into the metal thus providing a key for the paint."
Edited By JasonB on 06/04/2018 11:00:10
Clive Foster06/04/2018 12:13:36
3630 forum posts
128 photos
Another disadvantage of wire wool is ferrous metal surface contamination which is known to reduce paint adhesion to aluminium even if otherwise properly prepared and effectively etch primed. Pretty much impossible to stop microscopic particle common off the wire wool and becoming embedded in the alloy surface or reforming oxide layer.
Ian S C06/04/2018 12:22:31
7468 forum posts
230 photos
If you use steel wool, make sure it is stainless steel wool. The acid in etch primer is chromic acid, it used to be zinc chromate when I was in the aviation business. I think they now use Strontium Chromate.
Ian S C
Edited By Ian S C on 06/04/2018 13:40:43
Joseph Noci 106/04/2018 12:41:28
1323 forum posts
1431 photos
This was also asked in 2015 ( by Nick_G), 2016 ( Nick T...mmm, wonder if that's not the same fellow..?) and 2017 (by Robin Graham) with all the same answers..., so this one is the 'done-it' for 2018 it seems...There were lengthy, useful answers to those queries
Sometimes a simple search on the forums does it all..
Joe
David Standing 106/04/2018 13:08:00
1297 forum posts
50 photos
Posted by Joseph Noci 1 on 06/04/2018 12:41:28:
Joe
Joe
Thank goodness the question wasn't 'what lathe shall I buy?'. That's been asked about 500 times since 2015!! wink 2
Joseph Noci 106/04/2018 15:11:57
1323 forum posts
1431 photos
True, but I really do not think painting and buying a lathe are quite the same thing..There are a few appropriate ways to paint aluminium, and yet many different lathes and configurations to buy, so those questions are timeless..
Joe
Martin Dowing06/04/2018 15:16:50
356 forum posts
8 photos
Many thanks for suggestions.
I have purchased spray etchant in specialistic shop supplying car repair businesses. Seller is very confident about its performance.
Yes, it is sometimes good idea to search older threads.
Martin
Monoman06/04/2018 16:31:45
51 forum posts
7 photos
Ian SC
I have many years experience producing, testing and troubleshooting etch primers from all sorts of manufacturers in the UK. Formerly I worked for the company which introduced etch primers to the aircraft industry pre-WWII and have never found your formulation suggestions to be commercially available for use in any manufacturing or maintenance role in Europe or the Americas.
Jerry
