Sealey mighty mig 150
Liner
sean logie31/03/2018 13:24:42
608 forum posts
7 photos
Has anyone replace the liner in one of these ? I know how just not sure of which one . The one I took out of my welder was in 2 pieces which doesn't seem right to me . From where the liner enters the gun for about 1/2" in ,from there there was a another piece of liner the length of the gun up to the nozzle . Is this right or not . I've been a stick welder up to now ,so I'm not up speed on the mig welder and it's in's and outs . I would've thought it would need to be one continuous piece .
Sean
Hacksaw31/03/2018 15:41:31
474 forum posts
202 photos
I have one . Yes , mine is a separate piece , which is a right pain, as when loading a new wire ,invariably means taking the gun apart , as it never finds the hole in the tubing . Since it's on the bend in the nozzle it eventually wears through too..from the friction of the moving wire , and then the shroud goes live too !! Any old plastic tube kicking around that's the right bore seems to work as a replacement ok ...like a bit of airbrush airline blush..( cowbow , i am  )
Edited By Hacksaw on 31/03/2018 15:42:24
Hacksaw31/03/2018 15:50:15
474 forum posts
202 photos
Those red tubes that come with WD40 ..a bit of that works too on 0 .6 wire in an emergency ..
So i've heard...blush
sean logie31/03/2018 16:03:19
608 forum posts
7 photos
Which flux core do you chaps suggest .
Sean
Hacksaw31/03/2018 16:15:10
474 forum posts
202 photos
Gasless wire ? Never tried it . Don't you have to reverse the gun polarity with that stuff ? I've only ever used CO2 or Hobbyweld 5 gas
Neil Wyatt31/03/2018 17:06:35
19226 forum posts
749 photos
86 articles
Posted by sean logie on 31/03/2018 16:03:19:
Sean
Depends what you are welding!
sean logie31/03/2018 17:31:21
608 forum posts
7 photos
Mainly mild steel .
Sean
Neil Wyatt31/03/2018 18:04:35
19226 forum posts
749 photos
86 articles
Bog standard flux-cored mild steel wire then
sean logie15/04/2018 07:38:32
608 forum posts
7 photos
Now I don't know much about electronics,so I'll try and explain . The relay that powers the the wire feed kinda pleases it's self when it works lol . I noticed yesterday there was a hole in the side of the plastic cover ,I also noticed it was sparking and flashing when I pulled the trigger on the gun .Then when it didn't work it was clicking ,now I think even I know that's not how a relay should behave wink .
Here's the culprit
To replace the relay ,is it  a case of touching the connectors on the back of the PCB with the hot soldering iron  .I'm a little concerned about damaging the PCB in doing this . Any tips ?
Edited By sean logie on 15/04/2018 07:39:48
Gray6215/04/2018 08:34:49
1058 forum posts
16 photos
Ideally you need to remove as much solder as possible from each of the pads before trying to remove the relay from the board. Get yourself some solder wick. The wick will take up most of the solder and will also sink some of the heat so reducing the risk of damaging the pads on the board. Don't keep the iron on each pad too long, of all the solder is not removed, let the pad cool and do another one, then go back around. Too much heat in one go will risk lifting the pad and burning the pcb.
Nicholas Farr15/04/2018 08:37:41
3988 forum posts
1799 photos
Hi Sean, get yourself some de-soldering braid. If your hurry to a Maplin's shop, you maybe lucky to get some.
Regards Nick.
Graeme beat me to it.
Edited By Nicholas Farr on 15/04/2018 09:01:08
Doubletop15/04/2018 09:24:02
439 forum posts
4 photos
As the relay is completely stuffed. Take a note of all the markings to help you search for a replacement. Then carefully break off the outer case and using snips cut away as much as the relay as you can. You are trying to get it down to 4 separate connections coming out of the board.
Using pliers grip the connection on the component side and unsolder on the solder side and pull the connection free. Repeat for the other three.
It may seem a bit drastic at first but it is far easier than trying to wrestle out 4 connections at the same time.
Pete
Doubletop15/04/2018 09:26:50
439 forum posts
4 photos
It looks like it is one of these
Data Sheet here
http://www.hongfa.com/pro/pdf/HF102F_en.pdf
Beware when searching Ebay. You want a 24v version and they all seem to be selling the 12V version which appears to be JQX 102F. However some are advertising the HF 102F but as 12v which you don't want.
Pete
Edited By Doubletop on 15/04/2018 09:28:33
Edited By Doubletop on 15/04/2018 09:49:53
sean logie15/04/2018 11:42:39
608 forum posts
7 photos
Posted by Doubletop on 15/04/2018 09:24:02:
Pete
This was my plan Pete ,thanks
Sean
sean logie15/04/2018 11:43:22
608 forum posts
7 photos
Posted by Nicholas Farr on 15/04/2018 08:37:41:
Regards Nick.
All ready ordered wink
Sean
sean logie15/04/2018 11:44:45
608 forum posts
7 photos
Posted by Doubletop on 15/04/2018 09:26:50:
Data Sheet here
Pete
Thanks again Pete , I nearly fell foul on the 12v version .Mine is the HF102F 24v 20A
Sean
Edited By sean logie on 15/04/2018 11:47:14
Anthony Drake15/04/2018 21:00:45
10 forum posts
41 photos
On the subject of gas less wire I have used this type of wire with and without gas on 400 amp machines, I am using machine Marts 0.9mm wire which I have used on car body work on a 100 amp mig which is good wire compared to the industrial wire I have used.
Regards Tony laugh
SillyOldDuffer16/04/2018 09:37:17
10668 forum posts
2415 photos
Anyone got a theory as to why Sean's relay should fail like that? My first thought was that there's a dud capacitor across the contacts but the symptoms don't match. Could it be physical damage, something whacked into the case in the past?
I prefer a desoldering pump to wick; both are useful depending on the job.
Doubletop16/04/2018 12:10:13
439 forum posts
4 photos
Posted by SillyOldDuffer on 16/04/2018 09:37:17:
Here is the parts list with the circuit diagram **LINK**
The only thing the relay does is switch the power transformer, maybe the back emf of a lot of repeated heavy current welding (switch setting on MAX 1)  has finally killed the relay. Just a case of component mortality?
Pete
Edited By Doubletop on 16/04/2018 12:15:39
sean logie16/04/2018 16:23:18
608 forum posts
7 photos
The link for the welder is different setup to mine unfortunately.
Sean
