Member postings for Anthony Drake
Here is a list of all the postings Anthony Drake has made in our forums. Click on a thread name to jump to the thread.
Thread: mystery tool
07/08/2018 19:35:57
Treppanning is a very ancient form of surgery and as you can guess, the most noticeable in pre history context. I have made a Roman drill but do not have a photo, I have specialised in ancient medical instruments, you would be surprised at how advanced there were. One instrument is the cataract needle Acvs as well as the crouching one that is also used,
And also the Clyster,
Enema syringe, using good old castor oil. The list is endless of the amazing engineered equipment they came up with which are still used today.
This a beauifuly made Specvlvm
Used in child birth. From Pompeii 1st AD.
Regards Tony laugh
Edited By Anthony Drake on 07/08/2018 19:39:13
Thread: Sealey mighty mig 150
15/04/2018 21:00:45
On the subject of gas less wire I have used this type of wire with and without gas on 400 amp machines, I am using machine Marts 0.9mm wire which I have used on car body work on a 100 amp mig which is good wire compared to the industrial wire I have used.
Regards Tony laugh
Thread: What did you do Today 2018
29/03/2018 22:26:11
Been busy making some of the iron work for a heavy duty tripod for our torsion artillary as well as laminated hardwood legs, still some more pieces to do base plate for it to sit on then a bit of riveting to put it all together.
Regards Tony laugh
Thread: New member North East
22/03/2018 21:30:34
George I am in Sunderland, but not a native.
Regards Tony laugh
Thread: Identify a vertical steam engine
22/03/2018 21:27:29
Cheers Scrumpy it would be good to see it in action, I thought it was on the big side, just to be used to show how a steam engine worked.
Regards Tony laugh
21/03/2018 22:35:34
Thanks for your replies smiley Neil the label says "scrap" on it and yes lucky because it could of been on the back of a scrap van. To good to end its life like that. Eric cheers for the heads up it does look like the Nasmyths engine. I thought at first it may have been a apprentice piece made in a local yard.
Not bad for similarity, and at least it is a start. Will post when finished. Cheers once again.
Regards Tony laugh
21/03/2018 22:12:46
Thanks Dave smileyI will share things I make, I have a busy year ahead of me, I am into ancient engineering along with my blacksmithing kit I have just finished my carpenters kit, just a plane to make to finish. I have also worked on torsion artillary with full size replicas that fully work, range 3rd of a mile not bad for something without bang and a force of a small car hitting you.
Regards Tony laugh
20/03/2018 17:36:07
Hope this is the relevant place to put this. I have saved this beast from the scrap man, I was offered it for the metal for my work projects. There is nothing wrong with it I can see just the bright work needs cleaning up it has two perspex view panels to see the workings, and the blanking plates were stored in the wood base. It has no makers marks on it unless under the base. The paint is all good on it, so it just needs a good clean. Any help with make and date would be great.
As you can see it has some weight to it. Thanks in advance.
Regards Tonylaugh
20/03/2018 12:41:22
Thanks everyone laugh I have found the album bit so I have put a few up, I have been doing this for a few decades now and have lost count of the swords I have made without all the other items, I also fix a lot of fittings for obsolete items. I don't cast anything so have to make from a block of material. I do have a steam engine enquiry but will post separate.
Fullum sword I made a few years ago from finds London and Europe
Buckle and plate origonal British museum.
And finally a protective sheath for a Dololbra otherwise a pick axe.
Will post when I have taken a few photos of my steam engine to restore surprise
Regards Tony laugh
20/03/2018 09:55:05
Hi my I am Tony Drake and I am a armourer mostly but also do a lot of metal work and restoration. I trained in the shipyards and coal mines ( great career moves ) but they have gave me a love of working and making things in metal. I must admit I am not a model engineer but I love anything that runs on coal. I have read through some of the post and you have some very knowledgeable and excellent craftsman amongst yourselves. I myself use a lot of raw materials in my work and hope that if I need a special piece of material some one can put me in the right direction, I myself might be able to help with ideas to how to get round problems which was one of the elements I was trained to do with the work I do. I would post some photos of my work but need to work out how to do it first, so I will link a thread on a Craticvla I made,
https://www.romanarmytalk.com/rat/thread-30448.html
So I hope this works.
Regards Tony laugh
