BOB BLACKSHAW | 25/03/2018 17:15:16 |
501 forum posts 132 photos | I'm fitting a DRO on my lathe tailstock, with my lathe the all my centers when fitted will foul up when on my clamp DRO fixing when I take them out. All drill chucks and M2, M3 reducers have a tang on the end and are ok when I take them out. My question is why are tangs not fitted to centers, I can understand if no tangs are fitted to drill chucks as it will give around 15mm more on the tailstock, but why not centers. Edited By BOB BLACKSHAW on 25/03/2018 17:20:45 |
Dave Halford | 25/03/2018 17:44:46 |
2536 forum posts 24 photos | The tangs are used to drift out the taper via the slot cut in a drill press. Tailstocks do not have the slot and therefore the tang is deleted
Journeyman | 25/03/2018 17:52:35 |
![]() 1257 forum posts 264 photos | If you need a little extra length on the centre to avoid fouling the DRO mounting. Cut some discs same dia as the centre small end from brass or even plastic and stick them on. Will be plenty strong enough to eject the centre. John |
not done it yet | 25/03/2018 20:07:55 |
7517 forum posts 20 photos | As Journeyman - or drill, thread and insert a suitable bolt/screw/threaded bar to eject them earlier. Hardness might be deciding factor... Edited By not done it yet on 25/03/2018 20:09:13 |
Lambton | 26/03/2018 09:47:59 |
![]() 694 forum posts 2 photos | Use a smaller centre in a Morse taper adapter sleeve that has a tang. The adapter & centre are then ejected together. Arc sell a variety at very reasonable prices. (page 6 of the current number 10 catalogue. Usual disclaimer Eric. |
Neil Wyatt | 26/03/2018 11:02:26 |
![]() 19226 forum posts 749 photos 86 articles | You can get screw in tangs. I have a rotating centre that has a screw in button |
not done it yet | 26/03/2018 11:09:33 |
7517 forum posts 20 photos | Sure you can (Arc do them), but angs are only really needed where extraction is by wedge? Simple bolts are far cheaper for this problem? Edited By not done it yet on 26/03/2018 11:10:48 |
Jon | 26/03/2018 14:18:01 |
1001 forum posts 49 photos | All aboves a lot of faffing about, just buy what you want with MT tangs job done and self eject.
Martin Dowing | 26/03/2018 15:52:54 |
![]() 356 forum posts 8 photos | All my MK2 tangs are slotted and threaded M8 to have both worlds. Martin |
Neil Wyatt | 26/03/2018 18:59:33 |
![]() 19226 forum posts 749 photos 86 articles | Posted by not done it yet on 26/03/2018 11:09:33:
Sure you can (Arc do them), but angs are only really needed where extraction is by wedge? Simple bolts are far cheaper for this problem? Edited By not done it yet on 26/03/2018 11:10:48 The scew in button gives you the extra retraction but avoids the 'fouling up' the original poster mentioned. |
