Boiler Bri | 30/01/2018 19:32:31 |
![]() 856 forum posts 212 photos | I have now turned my attention to stripping and painting the tender for my 5" Class 7 loco. There is no tool tunnel fitted and i would like to add one.
I searched out the series by Doug Hewson, and found the article.
Using his template and dimensions i have cut and folded the parts, but they do not look correct. It all looks bit over size and the front end looks different when folded to the picture in the article. Can anyone help please.
Brian |
Boiler Bri | 31/01/2018 06:35:37 |
![]() 856 forum posts 212 photos | Bump |
Weary | 31/01/2018 09:20:36 |
421 forum posts 1 photos | PM in your inbox. Phil |
Boiler Bri | 22/07/2018 19:43:46 |
![]() 856 forum posts 212 photos | Finally finished the tender rebuild and its now ready for some transfers and lining.
I thought i might have a bash at lining myself. A club friend lent me some lining pens and i had some humbrol left from a 00 model paint job. So this is what i want to paint>>>>>>>>
And this is my over confident practice on an old loco roof. LOL.
Now i know it dont look good, and i need to practice.
so this is my plan:- 1. the pen does not hold a lot of paint. Need a better application tool. 2. the paint was a bit thin. Buy some more. 3. you have to start very carefully or you get flooding. This one is practice. 4. its not put me off trying again. when i dont know, daughter comes tomorrow form NZ for three weeks with children. If all else fails i might try Fox transfers!!! Don't all laugh too loudly, i don't want to hear you all in Huddersfield.
JasonB | 22/07/2018 20:01:30 |
![]() 25215 forum posts 3105 photos 1 articles | You need a Border pen if you want to hold more paint, they are a lot wider.
Michael Gilligan | 22/07/2018 20:04:43 |
![]() 23121 forum posts 1360 photos | You have my sympathy, Brian ... and my respect for trying !! I remember [decades ago] watching the chap in BSA, lining a petrol tank. Tank supported on his left hand, and a fully loaded dagger brush in his right The classic D shaped line was produced in a matter of seconds; then he flipped the tank around on his hand and did one to match on the other side [these are of course, mirror images!]. MichaelG. |
roy entwistle | 22/07/2018 20:17:38 |
1716 forum posts | The draughting pen would normally use ink which I suspect would be a lot thinner than paint. Also you appear to have done the job freehand. I would recommend using a straight edge even if you use a border pen as suggested by JasonB Roy |
Jon Lawes | 22/07/2018 20:38:40 |
![]() 1078 forum posts | Can I just say what a fantastic job you have made on that tender. I'll be attempting a 3.5 BR1D soon and if I can come close to the finish and fit of the one you have made I would be very happy. Nice work. |
Boiler Bri | 22/07/2018 21:35:05 |
![]() 856 forum posts 212 photos | I did use a ruler on a small part and then really just played around.
I will have a look at the border pen than you.
Bri |
Boiler Bri | 22/07/2018 21:37:04 |
![]() 856 forum posts 212 photos | Ah, i have one of those in the pens i was given, i thought it was too large! I will have to give it a go.
Bri |
pgk pgk | 22/07/2018 21:46:55 |
2661 forum posts 294 photos | Would low-tack pinstriping tape help? It might be awkward for the curves so perhaps this I've not tried the latter. When i did some lining on my RC heli canopies I used the thin blue 3m tape and eyballed two parallel linesarond the curves
pgk |
Paul Lousick | 22/07/2018 22:57:17 |
2276 forum posts 801 photos | Drafting pens are not suitable for applying paint. They are used with thin ink. Pin striping is best done with a special pen with a roller at the end like a Beugler (rollers are available in different widths and combinations for painting double lines) or special brushes with very long and thin bristles. http://beuglereurope.com/english/index.html Lots of videos on Youtube showing the application of pin striping. You should also use a thicker paint, used by sign writers which contains more pigment than ordinary paint which is applied in one application only. Second layer difficult to apply. Paul.
Edited By Paul Lousick on 22/07/2018 23:06:22 |
Nick Clarke 3 | 23/07/2018 07:45:43 |
![]() 1607 forum posts 69 photos | Posted by Michael Gilligan on 22/07/2018 20:04:43:
You have my sympathy, Brian ... and my respect for trying !! I remember [decades ago] watching the chap in BSA, lining a petrol tank. Tank supported on his left hand, and a fully loaded dagger brush in his right The classic D shaped line was produced in a matter of seconds; then he flipped the tank around on his hand and did one to match on the other side [these are of course, mirror images!]. MichaelG. In a previous life I sold lining tape, both the type where a centre section was torn out leaving a strip either side and also the type that left a line of colour when you pulled a carrier tape away - Perhaps if the first type is still available it might help? - mind you I also remember a TV documentary about Van den Plas where they showed a strip being applied the full length of a BMC 1300 in one go with a long brush loaded with paint, like Michael saw on the tank. No guide or anything - just a steady hand and years of experience. I am deeply envious of course! |
Boiler Bri | 04/08/2018 21:10:03 |
![]() 856 forum posts 212 photos | Succumbed and bought some transfers from Fox, and now i need to sit down and work out how to replace the amount of dosh they cost me
I will probably cover them with Humbrol clear gloss, has anyone used the stuff? I have a new unopened bottle. Does it level out good or will i end up having to paint the whole job?
Brian |
Boiler Bri | 04/08/2018 21:21:08 |
![]() 856 forum posts 212 photos | I have answered my own questions:
https://www.youtube.com/watch?v=ByMhacC5vAE
Got to give this a try. Hope i get the same results |
Ian Hewson | 04/08/2018 21:25:55 |
354 forum posts 33 photos | Like Michael g, I too have memories of the BSA painter doing the tank, fabulous skill. On a visit with the electricity board students association, first time most of us had seen a melon for lunch, guessing how to tackle it without looking a fool. Different world going from Leeds to Brum as a 16 year old apprentice. |
Boiler Bri | 06/04/2019 20:08:42 |
![]() 856 forum posts 212 photos | 5" Britannia
Does anyone have an automatic cylinder drain design for 5" loco's. Just watched a video on YouTube of the Sale area model engineers running day. A 9f looked to have auto drains. Mine are worked by a push pull rod from the cab and do not always work very well.
Brian |
Simon Collier | 07/04/2019 10:53:32 |
![]() 525 forum posts 65 photos | Brian, you'd do better on the MECH Forum for stuff about actual models. This is really a workshop forum and questions about locos usually result in the digital equivalent of blank stares. You stay logged on over there as well. I don't post here often because of the pain of logging in. There are Brit threads on MECH. |
victor mcconville | 07/04/2019 11:28:38 |
20 forum posts | Hi Brian, |
RMA | 07/04/2019 17:23:09 |
332 forum posts 4 photos | Getting back to the tunnel on the tender, from my drawings the tunnel is parallel along it's length. Yours seem to expand into a cone shape. The cross section is a strange shape because it fits within the coal chute. I'm building a 3.5 inch Brit and the tender is a laser kit which doesn't have the chute, although he's cut a hole in the bulkhead. I am trying to make the complete tunnel, which looks much better. Looking at your photos, there seems to be a front bulkhead missing. |
