Cheapo Lidl drill press, could be useful
Ady120/01/2018 01:21:09
6137 forum posts
893 photos
This has been lying in a corner since I got other better gear but it occurred to me tonight that it may have portable uses in the right circumstances, especially if you have knackered hands/thumbs
They do still appear from time to time
If you're forced to do loads of holes by hand in a steel plate, concrete, or a remote location then read on
The drill can be set to drill beneath the bottom plate, up to 60mm travel is possible and you can preset the depth as well
You can also stand on the plate while it drills the hole
The plate is a nice solid heavy casting, not tinfoil
Just thought I'd share
Edited By Ady1 on 20/01/2018 01:24:05
ega20/01/2018 10:00:03
2805 forum posts
219 photos
Ady 1:
Yes, they are versatile and useful on occasion. I used to have a similar Bosch device permanently mounted at the rear of my woodwork bench with the base screwed up to the underside of the bench so that the only obstruction was the column.
larry Phelan20/01/2018 10:09:51
544 forum posts
17 photos
Yes,they are useful,the only problem I found with them,is that the clamp tends to compress the bearing and this prevents the spindle from running smooth. Still,for the price,they are handy to have.
Ian S C20/01/2018 11:03:03
7468 forum posts
230 photos
I'v got a similar device from Black and Decker, got it some time in the 1970s I think, have often thought of making it into a tapping stand.
Ian S C
Hopper20/01/2018 11:37:20
7881 forum posts
397 photos
Brilliant! Ideal for hammer drilling holes into concrete floors for bolting down lathe benches etc.
Alistair Robertson 120/01/2018 11:52:42
154 forum posts
6 photos
A few (many!) years ago I managed to drill and ream 4 holes in the crankshaft flange of a tractor engine to fit strengthening dowels to the crank/flywheel connection using a Black and Decker version of the drill stand.
I was able to bolt the stand to the engine backplate and used a jig to align the holes. The cost to strip the engine and do the job on a horizontal borer was going to be over £200 so that stand paid for itself many times over and I still have it (somewhere!)
Neil Wyatt20/01/2018 13:41:02
19226 forum posts
749 photos
86 articles
Posted by Ady1 on 20/01/2018 01:21:09:
Bit of an extreme approach to removing corns...
Edited By Neil Wyatt on 20/01/2018 13:41:10
Michael Gilligan21/01/2018 15:53:50
23121 forum posts
1360 photos
I don't want to start yet another Lidl thread, so I hope it's O.K. to digress slightly.
Has anyone tried one of these ?
https://www.lidl.de/de/parkside-winkelbithalter/-bohrvorsatz-4-teilig/p264332
^^^ That's a German link, but I bought one last week in U.K. for £5.99
At first sight it is nicely balanced and well-proportioned, BUT there is a lot of rock in both the input and output bearings; and of the three supplied drills, one runs reasonably true and the others both have runout which exceeds the diameter of the drill surprise [this is, I think, because they are held magnetically and the end of the hexagon is not ground 'square'].
Overall, rather disappointing ... but I'm tempted to try making a silk purse out of this particular sow's ear.
Any thoughts ?
P.S. What appears to be the Screwfix equivalent is reviewed here: **LINK**
https://www.screwfix.com/p/erbauer-angled-screwdriver-bit-holder/2658h
Muzzer21/01/2018 16:11:18
2904 forum posts
448 photos
I've got a proper cordless angle driver (Panasonic equivalent of this) which is invaluable eg for putting in (wood)screws between joists, drilling holes in tight spaces etc. In those circumstances and with only a std drill driver, one of these things might get you out of a tight(!) scrape but it wouldn't be much fun. You are trying to stop the thing rotating in 2 axes at once and I expect it's as wobbly as a very wobbly thing.
Murray
Michael Gilligan21/01/2018 16:52:19
23121 forum posts
1360 photos
Quite so, Murray
But the Lidl one is very compact and I do think it has [limited] potential.
