jimmy b | 08/01/2018 10:01:35 |
![]() 857 forum posts 45 photos | I've treated myself to a new granite surface plate, the old one from Axminster was getting too crowded, (it was one odf the 300x200x50 ones). Not sure how good this will be, **LINK** It's coming on Wednesday, so I'll find out then! Jim |
fizzy | 08/01/2018 10:39:54 |
![]() 1860 forum posts 121 photos | I broke mine in three pieces by accident yesterday - gutted!
Mike Poole | 08/01/2018 10:57:15 |
![]() 3676 forum posts 82 photos | Posted by fizzy on 08/01/2018 10:39:54:
If it doesn't give away anything too embarrassing how did you manage that Fizzy? Mike |
Howard Lewis | 08/01/2018 15:31:30 |
7227 forum posts 21 photos | Fizzy, If it is any consolation, I made one for The WaterWorks Museum in Hereford. Bought a slab of marble from a stonemason in a local town. Made up a sturdy angle iron frame, with internal cross bracing, to provide a flatt(ish) surface on which the marble could sit. Each corner had an adjustable levelling screw, at the bottom of a vertical piece of angle to prevent the marble from moving off the base. Placed a sheet of hardboard on it, which was covered with wet, rather sloppy plaster / wall filler, before placing the marble slab onto it. In that way, the marble should be "floating" and free of stresses. The 18" x 24" slab of marble cost me £30. Larger would have been too heavy to place / remove from, the boot of the car! You may be able to get a better deal. Then made up, and varnished, a simple plywood cover for it. Howard
John Haine | 08/01/2018 16:33:41 |
5563 forum posts 322 photos | Given that the Chronos one is 18" sq and 4" thick, and the price includes delivery, that sounds quite reasonable to me! |
Enough! | 08/01/2018 17:20:08 |
1719 forum posts 1 photos | They don't seem to specify the weight - which is a bit of an omission for something like this. |
I.M. OUTAHERE | 08/01/2018 17:54:51 |
1468 forum posts 3 photos | C'mon Fizzy spill the beans ! How did you break your surface plate ? Ian. |
Dullnote | 08/01/2018 18:15:56 |
![]() 94 forum posts 29 photos | Hi I got granite composite cutting board from Tesco very flat, well flat for my skills, cost £12. |
Michael Gilligan | 08/01/2018 18:38:45 |
![]() 23121 forum posts 1360 photos | Posted by Bandersnatch on 08/01/2018 17:20:08:
They don't seem to specify the weight - which is a bit of an omission for something like this. . The density of granite is fairly consistent, so; unless they have milled it out [which seems highly unlikely] it should be a simple matter to estimate the weight. MichaelG. |
jimmy b | 08/01/2018 18:40:09 |
![]() 857 forum posts 45 photos | According to UPS it's 56kg, Jim |
Enough! | 08/01/2018 22:19:00 |
1719 forum posts 1 photos | Posted by Michael Gilligan on 08/01/2018 18:38:45: .......it should be a simple matter to estimate the weight.
I don't doubt it. Why should I need to? This is a sales page and the weight seems rather a critical characteristic for what they are selling. |
fizzy | 08/01/2018 23:05:07 |
![]() 1860 forum posts 121 photos | I had it propped on its sude against the hydraulic press....moved predd, plate dropped and kaput! Ordered a new one but that one had sentimental value - gutted
Matt Harrington | 09/01/2018 00:05:53 |
![]() 212 forum posts 16 photos | Well, I have just received my one from Chronos - 400 x 250 x 80 @ £52 (free delivery) - 25Kgs (bargain) I haven't put it in the workshop yet but it appears to be good and certainly good enough for me!! Matt |
jimmy b | 10/01/2018 17:02:35 |
![]() 857 forum posts 45 photos | Mighty impressed! Its a big un! Measures 18" x 18" x 3 1/2".
The poor chap from UPS carried it up the drive! I've had a quick check of it, looks perfect, the enclosed "certificate" gave a max error of 2.5 microns. I've ran my "tenth" clock across it and get almost zero error. With a discount code, it was about £78, delivered
Happy chap today
Jim Edited By jimmy b on 10/01/2018 17:03:35 |
I.M. OUTAHERE | 10/01/2018 17:19:35 |
1468 forum posts 3 photos | Posted by fizzy on 08/01/2018 23:05:07:
Ian. |
Neil Wyatt | 10/01/2018 18:01:30 |
![]() 19226 forum posts 749 photos 86 articles | Posted by fizzy on 08/01/2018 23:05:07:
Oh dear! I trust the sentimental value wasn't because it had 'In Loving Memoriam...' carved on one side! Neil Edited By Neil Wyatt on 10/01/2018 18:01:46 |
James Wilkinson 3 | 10/01/2018 19:20:03 |
![]() 28 forum posts 4 photos | Hooorah! I bought one on Friday from Chronos as well, SCT 400 x 250x 80 Granite surface plate. It will be here tomorrow. Can't wait! :D I also managed to bag a unused 1981 670mm Chesterman vernier height gauge the other week as well in mint condition with box and everything. 2018 is looking like a proper job :D |
jimmy b | 10/01/2018 19:28:40 |
![]() 857 forum posts 45 photos | Posted by James Wilkinson 3 on 10/01/2018 19:20:03:
Hooorah! I bought one on Friday from Chronos as well, SCT 400 x 250x 80 Granite surface plate. It will be here tomorrow. Can't wait! :D I also managed to bag a unused 1981 670mm Chesterman vernier height gauge the other week as well in mint condition with box and everything. 2018 is looking like a proper job :D Excellent. I hope you are as pleased as me!
Jim |
Neil Wyatt | 10/01/2018 20:39:15 |
![]() 19226 forum posts 749 photos 86 articles | > 2018 is looking like a proper job Or you'll end up miserable because now you can check everything you make you will see how wonky it all is... Neil |
James Wilkinson 3 | 10/01/2018 20:49:03 |
![]() 28 forum posts 4 photos | Neil, I am a professional and it will be used as evidence against those who doubt my skills Cheers Jim! |
