One Hand Operated Depth Gauge
Stewart Hart06/01/2018 19:04:38
674 forum posts
357 photos
I came across this in an old American Machinist Magazine, and thought it would make a simple project, that would produce a handy bit of kit.
This is what I came up with :-
Its very Simple to use
Just press the rod until its reaches the bottom, the spring loaded plunger keeps the rod in place.
Then zero the digi vernier on the thick bar and then take the direct measurement of the hole depth,
I knocked this up in a couple of hours this morning.
Stew
Brian H06/01/2018 19:10:12
2312 forum posts
112 photos
That looks to be an excellent idea.
Oldiron06/01/2018 19:13:06
1193 forum posts
59 photos
Why is it when you swear that you will not add any more to the list of things to do some smart Alec (or Stew) comes up with another thing you want to make.
Nice job Stew.
regards
Neil Wyatt06/01/2018 19:22:57
19226 forum posts
749 photos
86 articles
Should work well, its working principle is identical to my smaller one! (The pin is only necessary if you want to take the probe out).
Jim Nic21/02/2018 21:28:41
406 forum posts
235 photos
Today I managed to cross something off my "To-do" list when I turned this:
into this:
Happy days.
Thanks for the drawing Stew.
Jim
Stewart Hart22/02/2018 09:16:11
674 forum posts
357 photos
Nice Job Jim smiley
Stew
Ian Hewson22/02/2018 09:28:06
354 forum posts
33 photos
Just a thought, would a 118 degree taper on the end of the pin be better for the depth of a drilled hole?
Stewart Hart23/02/2018 07:45:01
674 forum posts
357 photos
Posted by Ian Hewson on 22/02/2018 09:28:06:
Depends where you want to measure:- depth of full diameter or to the point also the point is a radius so I guess a pin with a radius would be the way to go. For full diameter simply drop a rod in of known diameter and length and measure to the top of that, but to be honest most jobs wouldn't require that amount of precision.
Stew
John Hinkley23/02/2018 09:59:59
1545 forum posts
484 photos
Neat bit of kit, but ......
My digital caliper gauge does the measurement directly with a sticky-out bit on the end. No machining required.
John H.
Ian S C23/02/2018 11:21:02
7468 forum posts
230 photos
I'v got a depth gauge somewhere, it spans 6" and I made it when I was wood turning 30 years ago, handy for gauging the depth of bowls, and other cup shape turnings.
Ian S C
