Now that's a big un
Tractor man02/01/2018 10:01:29
426 forum posts
I picked this inspection square up on e pay recently. Quite a hefty thing for the workbench.20180102_094221.jpg
Harry Wilkes02/01/2018 11:12:17
1613 forum posts
72 photos
Remind's me of when I worked in a steel works the 'Roller' the guy who measured the hot steel on the mill floor had the largest pair of outside calipers I have ever seen when closed from top to tips had to be 36" !
H
Mick B102/01/2018 11:50:34
2444 forum posts
139 photos
Yes, but being a model engineer, surely you've accepted that size is one of the things you have to compromise on...devillaugh
not done it yet02/01/2018 12:41:32
7517 forum posts
20 photos
The longer the better for making checks on a near red hot lump of steel, I would have thought!. A sensible fellow, I would say.
vintagengineer02/01/2018 21:54:55
469 forum posts
6 photos
Moore and Wright used to make 48" squares. I used to have 36" one. They were used mainly in plate layers shops.
Tractor man02/01/2018 22:39:16
426 forum posts
This is a chesterman 1970 36 inch inspection square.
The stock has an engraved identification mark:
DECCA RADAR INSP B101
Not sure if this identifies it as a tool room item.
It's a mighty thing and will be part of a display of unique tools in my home.
I.M. OUTAHERE03/01/2018 05:56:54
1468 forum posts
Toolmakers boomerang ! cheeky
Mick B103/01/2018 09:37:54
2444 forum posts
139 photos
Posted by Tractor man on 02/01/2018 22:39:16:
I'd think it possible but unlikely. Companies operating to DEFSTAN 05-21, which Decca Radar certainly would have been, were required to structure QA as a separate admin branch represented at Board level. This was to forestall the risk of commercial drivers overriding QA decisions.
It's possible that QA/Inspection might've had its own gaugemaking shop in such a large company, and it would have done the bulk of its own calibration and gauge maintenance, but I'd doubt that gauges belonging to either of those subdivisions would've just been marked 'INSP'. Your square was most likely a gauge used generally by Inspection on the shop floor.
Edited By Mick B1 on 03/01/2018 09:42:01
Tractor man03/01/2018 14:39:05
426 forum posts
I've popped a close up of the makers Mark in my albums that shows the name and model number and also the stamped inspection Mark. The stock is engraved DECCA RADAR insp. I cleaned it up a little this morning and put some beeswax on and it looks superb. SWMBO already has a spot picked out for it when the decorations come down.
Russell Eberhardt03/01/2018 16:32:12
2785 forum posts
87 photos
It's not how big it is that counts, it's what you do with it wink
Russell
Mick B103/01/2018 17:28:51
2444 forum posts
139 photos
Posted by Tractor man on 03/01/2018 14:39:05:
What's the stock made of? It looks like Tufnol or suchlike?
Tractor man03/01/2018 17:49:24
426 forum posts
Must be poor lighting. It's cast iron. The blade is actually a full L shape and the stock two separate sides riveted on to it. There is a separate steel piece held in the end of the stock by a screw which has a toothed outer edge like a grip piece, not sure if it's function.
Tractor man04/01/2018 19:48:48
426 forum posts
This is the square next to a 19 inch Moore and Wright micrometer. Will make a nice display!
Harry Wilkes04/03/2018 21:45:24
1613 forum posts
72 photos
Came across this youtube video around the 2 min mark you'll see the 'Roller' taking a measurement but as it's only a small bar being rolled he's smaller callipers
Posted by Harry Wilkes on 02/01/2018 11:12:17:
H
Edited By Harry Wilkes on 04/03/2018 21:47:15
Edited By Harry Wilkes on 04/03/2018 21:52:49
Bazyle05/03/2018 08:09:57
6956 forum posts
229 photos
Just s boilers have to have an ID mark for their annual inspection.to know which boiler is being tested the square would have had to have the ID mark for its annual or probably 9 monthly test and re-certification, even if that was done internally. The ID would have been recorded on the paperwork or perhaps to a particular inspector or test station and thus traceable through the paperwork. I guess a lot of us worked to 05-21 back in the day but we don't see it mentioned a lot.
