capstan sockets - other names for these ?
BW01/01/2018 20:56:16
249 forum posts
40 photos
Am looking for mt3 socket inside a straight tube. Googling revealed that capstan sockets are a good search term. The ones I have found seem to be very expensive compared to mt3/mt4 adaptors which are a fairly similar item.
Postage to Australia is also a consideration, I expected to be able to find something on ebay for approx 10 - 20 dollars with free postage. I can find sets of 4 in usa for 25 dollars but postage is a killer.
Any other search terms I could use ?
Mark Kilgore01/01/2018 21:20:00
9 forum posts
ArcEuroTrade calls them "Morse Taper Straight Sockets", but catalog them only in 1MT and 2MT. Still, that might broaden your search.
David George 101/01/2018 21:57:27
2110 forum posts
565 photos
try turret lathe socket.
David
Robbo02/01/2018 00:10:43
1504 forum posts
142 photos
Posted by David George 1 on 01/01/2018 21:57:27:
David
also capstan lathe socket
Hopper02/01/2018 08:09:54
7881 forum posts
397 photos
Chronos has them for 8 quid plus shipping, called MT3 socket. Link here **LINK**
I've been through the same thing before, inexplicably they are more expensive than the equivalent tapered adaptor. Maybe not used as much so lower volume = higher price?
Course, if you have a capstan lathe, you could crank a few dozen out yourself one afternoon.
Edited By Hopper on 02/01/2018 08:11:37
Ian S C02/01/2018 10:35:25
7468 forum posts
230 photos
If you have an ordinary lathe you might spend a day making one or two. If you get it right, don't stop at one, a couple of spares is good. If you are lucky, as I was you will come across a MT-3 reamer to finish the taper, saves having to be supper accurate with boring, I just drill i stepped sizes down the hole, then skim the hole using a boring bar to ensure the hole is straight.
Ian S C
BW02/01/2018 11:18:52
249 forum posts
40 photos
Thanks for all the help.
Bill
