Damaged Back Gear on Malcar 41/2" Lathe
AndyC16/11/2017 14:10:49
5 forum posts
Good afternoon all,
I have a MALCAR 4 1/2" Lathe that I inherited from my Grandfather, it was built by the Wragg Brothers circa 1954. I have unfortunately damaged the driven backgear on the main spindle. Does anyone have knowledge of this lathe, an idea of where I may be able to get a replacement gear or possibly have a lathe for parts.
Many thanks in anticipation
Andy
Brian Wood16/11/2017 14:54:43
2742 forum posts
39 photos
Hello Andy,
I can't be of direct help with spares but it is possible to braze in steel segments and form replacement teeth in them as a means of salvage. The gear has to be free of the lathe in that case of course.
An alternative method is to drill into the broken teeth and insert silver steel pegs to reshape afterwards as teeth. They don't need hardening in case you are wondering. That method can be used for a fix where stripping down is not convenient or best avoided
I have used both methods with success.
Regards Brian
Ady116/11/2017 15:01:35
6137 forum posts
893 photos
not done it yet16/11/2017 15:17:43
7517 forum posts
20 photos
I have a gear with a row of grubscrews shaped to the tooth profile. I would prefer to insert grub screws, shape to a bit less than the tooth profile, then fill with braze and recut the teeth.
Brian Wood17/11/2017 09:16:46
2742 forum posts
39 photos
Hello again Andy,
Thinking a little more about finding a gear for your lathe, be careful if you approach people like HPC in Chesterfield. to supply a new one
New gears these days by HPC and others will almost certainly be made to the modern 20 degree pressure angle whereas your damaged gear is almost certainly made to the earlier 14.5 degree angle and while they will mesh, it will not be a happy mix. Whoever you approach would need to be made aware of that and will charge accordingly if they are prepared to make a 'special'
There are some on this forum who could supply a custom made copy, myself included, if all else fails.
Regards Brian
larry Phelan17/11/2017 11:05:11
544 forum posts
17 photos
I broke the back gear on my Craftsman lathe some years ago,while trying to remove the chuck [never repeated !].
I had to buy a replacement,kept the damaged one with the intention of having it repaired sometime.
I would do so now if I could find it [It was put away "safe" ]
I thought it would have to be welded with cast iron rods,never thought about brazing.
Now,where did I put it???
Neil Wyatt17/11/2017 20:28:08
19226 forum posts
749 photos
86 articles
Some good advice on brazing CI in Keith Hales book on silver solderings. Without giving away everything he suggests burning off surface carbon before fluxing.
Hopper17/11/2017 22:37:00
7881 forum posts
397 photos
It might be worth measuring up the gear and determining the DP and number of teeth. It may be possible to find a more readily available gear off a Myford etc etc that can be machined to fit by boring out the centre etc.
peak417/11/2017 23:17:44
2207 forum posts
210 photos
Posted by Brian Wood on 17/11/2017 09:16:46:
Hello again Andy,
Regards Brian
No experience of these myself, but Tony has a comment on his web site requesting any owners get in touch with him, presumably so he can add more machine details to his database.
Regarding the pressure angles etc. assuming the gears are say 20dp, they always run as a pair on a backgear, so if one were to replace both gears as a pair pair from HPC, then the pressure angle wouldn't be an issue.
If they have internal splines, then bore out the new gears to a larger ID, and turn the teeth off the old ones. Pin and Loctite the two parts together and re-fit.
Bill
duncan webster18/11/2017 00:03:39
5307 forum posts
83 photos
I found that getting bespoke gears cut by a chap in Manchester was surprisingly cheap. Unfortunately I can't remember his name, but yellow pages might find one local to you. Make your own blank and tell them it's a banker job (ie no hurry) and no QA required
Edited By duncan webster on 18/11/2017 00:04:03
